Input Pins strange behavior / or not
I need 2 pin inputs to determine 4 possible states. I came up with what I think straight forward test to determine the state.
switchstate = 00;
if (digitalRead(11))
switchstate = switchstate | 00000001;
if (digitalRead(12))
switchstate = switchstate | 00000010;
// swichstate should have a value between 0 and 3. It does not! Value is 0, 1, 8, and 9. Here is code for Arduino Uno. You can run it. Can anyone explain the 8 and 9? Following this code is a much lengthier solution which provides the correct switchstate.
I would prefer to use the above code. I can by changing 8 and 9 with if to 2 and 3.
// INPUT SWITCHES FOR MODE!!!!
byte switchstate = 0;
  // initialize digital pin 13 as an output.
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  // Want to determine 1 of 4 states based on input pins 11 and 12
  switchstate = 00;
  Serial.println("Initial State of Switchset");
  Serial.println(switchstate);
    Serial.println("PIN 11 is HIGH");
    Serial.println("PIN 12 is HIGH");
  Serial.println("Final State of Switchset");
Code that works.
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  if (!digitalRead(11) & !digitalRead(12))
    switchstate = 0;
  if (digitalRead(11) & !digitalRead(12))
    switchstate = 1;
  if (!digitalRead(11) & digitalRead(12))
    switchstate = 2;
  if (digitalRead(11) & digitalRead(12))
    switchstate = 3;
 Serial.print("Switchstate  ");
I forgot the B for binary! So obvious!! Thanks for time and I am sorry.
frolic
switchstate = (PORTB & 0b00011000) >> 3;
0b for binary as you figured out too.
Indeed 0b for binary. I prefer it over the single B because of it's 8-bit limit.
Only a leading 0 is the octal prefix :wink:
