Inputs
Hello,
I have hooked up my arduino to a 7 segment display. Currently the code is as follows
byte seven_seg_digits[10][7] = { { 0,0,0,0,0,1,0 },  // = 0
                                                           { 1,0,0,1,1,1,1 },  // = 1
                                                           { 0,0,1,0,0,0,1 },  // = 2
                                                           { 0,0,0,0,1,0,1 },  // = 3
                                                           { 1,0,0,1,1,0,0 },  // = 4
                                                           { 0,1,0,0,1,0,0 },  // = 5
                                                           { 0,1,0,0,0,0,0 },  // = 6
                                                           { 0,0,0,1,1,1,1 },  // = 7
                                                           { 0,0,0,0,0,0,0 },  // = 8
                                                           { 0,0,0,1,1,0,0 }   // = 9
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
    writeDot(0);  // start with the "ian" off
void writeDot(byte dot) {
  void sevenSegWrite(byte digit) {
  byte pin = 2;
  for (byte segCount = 0; segCount < 10; ++segCount) {
    digitalWrite(pin, seven_seg_digits[digit][segCount]);
//Ian officailly did something
{  int Count=5;
  if(digitalRead(12) == HIGH && digitalRead(11) == LOW);
   sevenSegWrite(Count+1);
   int Count=5;
  if(digitalRead(11) == HIGH && digitalRead(12) == LOW);
   sevenSegWrite(Count-1);
    //done
This program should if the switch is positive count upwards and if it is negative downwards
Here is a fritzing picture
THANKS
MICHAEL
Is there a question associated with this post?
Was there a question?
Why is count reinitialised every loop?
I would think that count should not be in the loop because every time it goes thru the loop it sets count back to 5!
Maybe something like this
 int Count=5;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  byte pin = 2;
count declared in setup is not in scope in loop
Even if it were in scope by declaring it as a global variable it is never updated in loop() anyway so the range of numbers displayed will be severely limited.
You would have to add or take away from count each time you go thru the loop
    Count++;
   sevenSegWrite(Count);
Count--;
Then if count is over or under a set number set it back to 0 or whatever
if (Count > 1024){
Count =0;
if (Count<0){
Count=1024;
Here is what I think would work!
int Count=5;
   pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  byte pin = 2;
    Count++;
   Count--;
   if (Count > 9){
   Count =0;
   if (Count<0){
   Count=9;
No, that isn't going to work.
sorry about the mess up the question was "Am i using inputs correctly?"
Here is my current changed code:
int count=0;
int led = 13;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  pinMode(led, OUTPUT);
  count = 2;
  byte pin = 2;
  for (byte segCount = 0; segCount < 7; ++segCount)
    ++pin;
void flashDot()
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
  if (count < 9 && digitalRead(12) == HIGH)
     sevenSegWrite(count++);
  else if(count > 0 && digitalRead(11) == HIGH)
     sevenSegWrite(count--);
    flashDot();
Thanks
MICHAEL
No idea because you have not said how you have wired them up.
Pull up resistor?
Pull down resistor?
No resistor?
No resistor
Michael
So how can you be sure whether the inputs are HIGH or LOW when the input pins are at a floating voltage most of the time ?
Your code looks like pins 11 and 12 are pulled HIGH then the buttons are pressed or the switches are operated but what voltage are they at when not pressed/operated ?
michael-schmid:
No resistor
Then no you are not using them right.
Read this:-
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
