Hello
I realized with a mega arduino and a LCD 20X4, a voltmeter that measures the voltage of several batteries.
My batteries are in parallel series so I measure the highest voltage (24V) and I have a midpoint to measure the voltage of each battery. My problem is that the values read on my LCD are unstable, they vary constantly.
Would you have a solution to my problem?
Do you have a idea
Please
Bumping your post within a few minutes will not gain you much sympathy... be patient, no one works here, everyone who answers is giving away personal free time ...
And double posting in different languages without any mention would definitely get you in trouble...
Said differently : WTF did you bump it here instead of answering my question to you in the French forum... stick to one thread. Hope someone else will b willing to help you out.
stev:
My problem is that the values read on my LCD are unstable, they vary constantly.Would you have a solution to my problem?
This is a common problem.
Battery voltage from the voltage divider is compared to a reference voltage, and that happens to be the 5volt supply.
If the 5volt supply dips 5%, voltage readout goes up by 5%.
The solution is to NOT use default Aref for voltage measurements, but one of the other buildin reference voltages.
A Mega has two. A 1.1volt and a 2.56volt Aref.
Learn about it in the Help>Reference section of the IDE.
You must change your voltage divider, so that it outputs e.g. 2.56volt max, then add:
analogReference(INTERNAL2V56);
to void setup()
And use 2.56 instead of 5.0 in the maths line of your A/D value to voltage conversion code.
Post your code if you want help with that.
Read forum rules about code tags first.
Leo..
hello wawa
I'm a beginner and I do not understand what you're telling me to do.
My code is attached.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F,20,4);
float rapport1 = 7.7 ;
float rapport2 = 7.7 ;
float rapport3 = 7.7 ;
float rapport4 = 7.7 ;
float rapport5 = 7.7 ;
float rapport6 = 7.7 ;
float rapport7 = 7.7 ;
float rapport8 = 7.75 ;
float rapport9 = 4.1 ;
const int ledPin = 13 ; // the number of the LED pin
// set the LCD address to 0x3F for a 20 chars and 4 line display
{ delay(500);
lcd.init();
lcd.backlight();
pinMode(ledPin, OUTPUT);
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
void loop ()
// read the input on analog pin 0:
int sensorValue0 = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage1 = (sensorValue0 * (5.0 / 1023.0))* rapport1;
// print out the value you read:
lcd.setCursor(0,0);
lcd.print(voltage1);
lcd.setCursor(6,0);
lcd.print("B");
lcd.print("1");
// read the input on analog pin 1:
int sensorValue1 = analogRead(A1);
float voltage2 = (sensorValue1 * (5.0 / 1023.0))* rapport2 - voltage1 ;
lcd.setCursor(0,1);
lcd.print(voltage2);
lcd.setCursor(6,1);
lcd.print("B");
lcd.print("2");
// read the input on analog pin 2:
int sensorValue2 = analogRead(A2);
float voltage3 = (sensorValue2 * (5.0 / 1023.0))* rapport3 ;
lcd.setCursor(0,2);
lcd.print(voltage3);
lcd.setCursor(6,2);
lcd.print("B");
lcd.print("3");
// read the input on analog pin 3:
int sensorValue3 = analogRead(A3);
float voltage4 = (sensorValue3 * (5.0 / 1023.0))* rapport4 - voltage3 ;
lcd.setCursor(0,3);
lcd.print(voltage4);
lcd.setCursor(6,3);
lcd.print("B");
lcd.print("4");
// read the input on analog pin 5:
int sensorValue5 = analogRead(A5);
float voltage5 = (sensorValue5 * (5.0 / 1023.0))* rapport5 ;
lcd.setCursor(11,0);
lcd.print(voltage5);
lcd.setCursor(17,0);
lcd.print("B");
lcd.print("5");
// read the input on analog pin 4:
int sensorValue4 = analogRead(A4);
float voltage6 = (sensorValue4 * (5.0 / 1023.0))* rapport6 - voltage5 ;
lcd.setCursor(11,1);
lcd.print(voltage6);
lcd.setCursor(17,1);
lcd.print("B");
lcd.print("6");
// read the input on analog pin 7:
int sensorValue7 = analogRead(A7);
float voltage7 = (sensorValue7 * (5.0 / 1023.0))* rapport7 ;
lcd.setCursor(11,2);
lcd.print(voltage7);
lcd.setCursor(17,2);
lcd.print("B");
lcd.print("7");
// read the input on analog pin 6:
int sensorValue6 = analogRead(A6);
float voltage8 = (sensorValue6 * (5.0 / 1023.0))* rapport8 - voltage7 ;
lcd.setCursor(11,3);
lcd.print(voltage8);
lcd.setCursor(17,3);
lcd.print("B");
lcd.print("8");
// read the input on analog pin 8:
int sensorValue8 = analogRead(A8);
float voltage8 = (sensorValue8 * (5.0 / 1023.0))* rapport9 ;
if (voltage8 < 7.4)
digitalWrite(ledPin, HIGH);
I do not know where to put my file so I put it directly in the message
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks. Tom..
#include <Wire.h>
{ delay(500);
lcd.init();
lcd.backlight();
void loop ()
lcd.setCursor(0,0);
lcd.setCursor(6,0);
lcd.print("B");
lcd.print("1");
lcd.setCursor(0,1);
lcd.setCursor(6,1);
lcd.print("B");
lcd.print("2");
lcd.setCursor(0,2);
lcd.setCursor(6,2);
lcd.print("B");
lcd.print("3");
lcd.setCursor(0,3);
lcd.setCursor(6,3);
lcd.print("B");
lcd.print("4");
lcd.print("B");
lcd.print("5");
lcd.print("B");
lcd.print("6");
lcd.print("B");
lcd.print("7");
lcd.print("B");
lcd.print("8");
if (voltage8 < 7.4)
}[code]
Arduino.pdf (18 KB)
OPs circuit.
Tom...
Have you tried putting 0.1uF capacitors between A0 and gnd and A1 and gnd?
Also when you read an analog input do it twice, this because there is only one AtoD converter, and it has to switch to each input pin.
The AtoD has a capacitor on its input and it needs time to charge to the new input as it is switched.
Reading the pin twice gives the capacitor time to charge.
lcd.setCursor(0,1);
Do this double read of each of your analogRead.
Tom...
So I test and I come back to you
Since the source impedance of the divider is about 220 ohms there is no point double reading or adding capacitors - those are workarounds for when the source impedance is >> 10k
so I tested the new sketch and now it's ok the stability is better
#include <Wire.h>
float rapport1 = 7.51 ;
float rapport2 = 4.93 ;
float rapport3 = 7.51 ;
float rapport4 = 4.93 ;
float rapport5 = 7.51 ;
float rapport6 = 4.93 ;
float rapport7 = 6.15 ;
float rapport8 = 4.93 ;
{ delay(500);
lcd.init();
lcd.backlight();
void loop ()
float voltage1 = ((sensorValue0 * (2.56 / 1023.0))* rapport1);
lcd.setCursor(0,0);
lcd.setCursor(6,0);
lcd.print("B");
lcd.print("1");
float voltage2 = ((sensorValue1 * (2.56 / 1023.0))* rapport2) ;
lcd.setCursor(0,1);
lcd.setCursor(6,1);
lcd.print("B");
lcd.print("2");
float voltage3 = ((sensorValue2 * (2.56 / 1023.0))* rapport3) ;
lcd.setCursor(0,2);
lcd.setCursor(6,2);
lcd.print("B");
lcd.print("3");
float voltage4 = ((sensorValue3 * (2.56 / 1023.0))* rapport4) ;
lcd.setCursor(0,3);
lcd.setCursor(6,3);
lcd.print("B");
lcd.print("4");
float voltage5 = ((sensorValue4 * (2.56 / 1023.0))* rapport5) ;
lcd.print("B");
lcd.print("5");
float voltage6 = ((sensorValue5 * (2.56 / 1023.0))* rapport6) ;
lcd.print("B");
lcd.print("6");
float voltage7 = ((sensorValue6 * (2.56 / 1023.0))* rapport7) ;
lcd.print("B");
lcd.print("7");
float voltage8 = ((sensorValue7 * (2.56 / 1023.0))* rapport8) ;
lcd.print("B");
lcd.print("8");
float voltage8 = ((sensorValue8 * (2.56 / 1023.0))* rapport9) ;
if (voltage8 < 7.4)
