I have int num set to 43, however when I print it in the serial thing it shows up as 30061. Why do that? and how can I fix it? Attached is a photo.
No you don’t.
You need
int num = 43;
For that.
Never post a photograph of code, always post the code copied from the IDE using the copy for forum option.
You don’t even do that because you print ‘num’ and that means the single character represented by num, drop the single quotes.
int num(43); What does this even compile to? A function called num? Doesn't throw an error.
-jim lee
[quote[/quote]
jimLee:
int num(43); What does this even compile to? A function called num? Doesn't throw an error.-jim lee
alternate initialisation syntax
of course all the cool kids are doing this int num{43};
now
A fight broke out on stack overflow over which was best recently, it was rubbish.
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom... ![]()
jimLee:
It matches constructor syntax.
jimLee:
Function prototype maybe? Have not checked to see if it generates a warning.
As the previous post stated, it is an initialization.
It is his attempt:
Serial.println( 'num' ) ;
which has caused his unexpected result.
'um' = 0x756D = 30,061 (dec)
