int?
what does the int mean? I understand integer, but I still do not understand how it works with other things (syntax?) in the code.
http://arduino.cc/en/Reference/Int
The int is a datatype modifier for a variable.
The Arduino does not know that 34 is a number unless you tell it that it is.
Variables are described according to this format in C/C++:
datatype variablename = value
If you want a number with the value 34, this results in:
int variable = 34;
Where
int is the datatype
variable is the variable name
= is the assignment operator (it assigns the value to the right, into the variable on the left)
34 becomes the value of variable
You can read it as:
The number called variable becomes equal to 34
It sets up something called a "variable". For example:
int x;
int y;
int z;
x = 3;
y = 4;
z = x + y; // this is saying z = 3 + 4 = 7
x = 5; // change the value of x
z = x + y; // now z = 5 + 4 = 9
Hope that helps!
