I am having issues in interfacing adafruit RA8875 Spi driver with arduino due.
I have checked all connections multiple times but no use. The buildtest exapmle of Adafruit_RA8875 library is still giving output like
RA8875 start -
255 -
RA8875 Not Found! -
I have tried using SPI pins and ICSP pins as well, but still i am not able to interface my tft successfully. I am sharing you guys all the connection details
and the program i am running. Kindly help me if anybody has prior interfaced 7 inch tft using RA8875- 800x480 driver with arduino due. any assistance regarding this issue will be highly appreciated.
// Connect SCLK to DUE SPI-3 (Hardware SPI clock)
// Connect MISO to DUE SPI-1 (Hardware SPI MISO)
// Connect MOSI to DUE SPI-4 (Hardware SPI MOSI)
// Connect INT to DUE Digital #3
// Connect CS to DUE Digital #10
// Connect RESET to DUE Digital #9
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
uint16_t tx, ty;
Serial.println("RA8875 start");
/* Initialize the display using 'RA8875_480x80', 'RA8875_480x128', 'RA8875_480x272' or 'RA8875_800x480' */
if (!tft.begin(RA8875_800x480)) {
Serial.println("RA8875 Not Found!");
while (1);
Serial.println("Found RA8875");
tft.displayOn(true);
tft.GPIOX(true); // Enable TFT - display enable tied to GPIOX
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft.PWM1out(255);
// With hardware accelleration this is instant
tft.fillScreen(RA8875_WHITE);
// Play with PWM
for (uint8_t i=255; i!=0; i-=5 )
tft.PWM1out(i);
delay(10);
for (uint8_t i=0; i!=255; i+=5 )
tft.PWM1out(i);
delay(10);
tft.PWM1out(255);
tft.fillScreen(RA8875_RED);
tft.fillScreen(RA8875_YELLOW);
tft.fillScreen(RA8875_GREEN);
tft.fillScreen(RA8875_CYAN);
tft.fillScreen(RA8875_MAGENTA);
tft.fillScreen(RA8875_BLACK);
// Try some GFX acceleration!
tft.drawCircle(100, 100, 50, RA8875_BLACK);
tft.fillCircle(100, 100, 49, RA8875_GREEN);
tft.fillRect(11, 11, 398, 198, RA8875_BLUE);
tft.drawRect(10, 10, 400, 200, RA8875_GREEN);
tft.fillRoundRect(200, 10, 200, 100, 10, RA8875_RED);
tft.drawPixel(10,10,RA8875_BLACK);
tft.drawPixel(11,11,RA8875_BLACK);
tft.drawLine(10, 10, 200, 100, RA8875_RED);
tft.drawTriangle(200, 15, 250, 100, 150, 125, RA8875_BLACK);
tft.fillTriangle(200, 16, 249, 99, 151, 124, RA8875_YELLOW);
tft.drawEllipse(300, 100, 100, 40, RA8875_BLACK);
tft.fillEllipse(300, 100, 98, 38, RA8875_GREEN);
// Argument 5 (curvePart) is a 2-bit value to control each corner (select 0, 1, 2, or 3)
tft.drawCurve(50, 100, 80, 40, 2, RA8875_BLACK);
tft.fillCurve(50, 100, 78, 38, 2, RA8875_WHITE);
pinMode(RA8875_INT, INPUT);
digitalWrite(RA8875_INT, HIGH);
tft.touchEnable(true);
Serial.print("Status: "); Serial.println(tft.readStatus(), HEX);
Serial.println("Waiting for touch events ...");
float xScale = 1024.0F/tft.width();
float yScale = 1024.0F/tft.height();
/* Wait around for touch events */
if (! digitalRead(RA8875_INT))
if (tft.touched())
Serial.print("Touch: ");
tft.touchRead(&tx, &ty);
Serial.print(tx); Serial.print(", "); Serial.println(ty);
/* Draw a circle */
tft.fillCircle((uint16_t)(tx/xScale), (uint16_t)(ty/yScale), 4, RA8875_WHITE);
