Interfacing an Arduino WAN MKR 1300 with with an Arduino UNO
I'm trying to send sensor data between two nodes. One node has an Arduino WAN MKR 1300 connected to a pressure sensor while the second node has an Arduino UNO connected to RYLR890 module. Is it possible to send the data across the nodes or should I just get a second Arduino WAN MKR 1300?
Given that both LoRa devices use the same frequency range (and the correct one for your location), this should be possible.
