Do you have two shift registers wired up? I'll assume you do and that you have Q7 from the first daisy-chained to DS of the second.
You'd call your shiftOut function twice first with 0x5b and then 0x7c or B01011011 and B01111100 or 91 and 124 or what ever you favorite base is. In your program you'll most likely call it with a variable each time.
What I was talking about is that when you are initializing variables or defining constants, you can use the B format if it makes visualizing your data any easier of more clear.
In these situations, I use the "do what I mean" instruction.
Seriously though, I believe your array that indexes a number 0-9 into the 7 segment pattern is what you want to use. All you have to do is convert your decimal value 0-99 into two BCD digits. Then you use each BCD digit, 0-9 to index your array to return the proper 7 segment pattern.
Take a look at this. This is not necessarily the most efficient way to make the conversion but it demonstrates number bases and the equivalent of a decimal shift.
int x = 5386; // number to convert
char m[4]; // individual digits
int n; // exponent
int k; // 10 to power n
if (x < 10000) {
if (x >= 1000){ // first we need to find out how many digits are in our number.
n = 3;
k = 1000;
else if (x >= 100) {
n = 2;
k = 100;
else if (x >= 10){
n = 1;
k = 10;
else if (x >= 0) {
n = 0; // we'll use this for our array index as well so we'll start at zero
k = 1;
else n = -1; // this can flag an error when you make this a function
int temp = x; // don't destroy x
for (int i = n; i >= 0; i--) // break the number apart 1 decade at a time
m[i] = temp / k; // integer divide isolates MSD
temp = temp - (m[i] * k); // remaining digits
k = k / 10; // decrement decade
Serial.println(m[3],DEC);
Serial.println(m[2],DEC);
Serial.println(m[1],DEC);
Serial.println(m[0],DEC);
void loop(){
Thank you so much! Thats exactly what I needed. I hope you dont mind, I borrowed a bit of your code (I kept you in there, of course!).
#include <DallasTemperature.h>
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
int j = 1;
int toShift = 0;
char m[4];
byte data;
byte dataArray[10];
DallasTemperature tempSensor;
//set pins to output because they are addressed in the main loop
pinMode(latchPin, OUTPUT);
tempSensor.begin(9);
dataArray[0] = 0x3F; // 0
dataArray[1] = 0x06; // 1
dataArray[2] = 0x5B; // 2
dataArray[3] = 0x4F; // 3
dataArray[4] = 0x66; // 4
dataArray[5] = 0x6D; // 5
dataArray[6] = 0x7C; // 6
dataArray[7] = 0x07; // 7
dataArray[8] = 0x7F; // 8
dataArray[9] = 0x67; // 9
data = dataArray[0];
//ground latchPin and hold low for as long as you are transmitting
digitalWrite(latchPin, 0);
shiftOut(dataPin, clockPin, data); // shift 0 four times to clear the display
//return the latch pin high to signal chip that it no longer needs to listen for information
digitalWrite(latchPin, 1);
int n = 3; // exponent
int k = 1000; // 10 to power n
toShift = (tempSensor.getTemperature() * 100);
Serial.println(toShift);
// following code by EmilyJane of arduino.cc forums
int temp = toShift; // don't destroy x
for (int i = 3; i >= 0; i--) // break the number apart 1 decade at a time
//move 'em out
shiftOut(dataPin, clockPin, dataArray[m[0]]);
shiftOut(dataPin, clockPin, dataArray[m[1]]);
shiftOut(dataPin, clockPin, dataArray[m[2]]);
shiftOut(dataPin, clockPin, dataArray[m[3]]);
//no longer needs to listen for information
// the heart of the program
void shiftOut(int myDataPin, int myClockPin, byte myDataOut)
// This shifts 8 bits out MSB first,
//on the rising edge of the clock,
//clock idles low
//internal function setup
int i=0;
int pinState;
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, OUTPUT);
//clear everything out just in case to
//prepare shift register for bit shifting
digitalWrite(myDataPin, 0);
digitalWrite(myClockPin, 0);
//for each bit in the byte myDataOut?
//NOTICE THAT WE ARE COUNTING DOWN in our for loop
//This means that %00000001 or "1" will go through such
//that it will be pin Q0 that lights.
for (i=7; i>=0; i--) {
//if the value passed to myDataOut and a bitmask result
// true then... so if we are at i=6 and our value is
// %11010100 it would the code compares it to %01000000
// and proceeds to set pinState to 1.
if ( myDataOut & (1<<i) ) {
pinState= 1;
else {
pinState= 0;
//Sets the pin to HIGH or LOW depending on pinState
digitalWrite(myDataPin, pinState);
//register shifts bits on upstroke of clock pin
digitalWrite(myClockPin, 1);
//zero the data pin after shift to prevent bleed through
//stop shifting
Video:
Im very happy with this method! It does exactly what I want, and best of all, only uses four pins per temperature I want to display (3 for the shift registers and one for the sensor itself)! Thank you so much! ;D
Yes, the two sets of displays are going to be soldered to some perf-board. I also plan on designing a menu-like interface for the LCD (I wanted the temperature to be visible at all times, thats why I did it with 7-seg's) and putting everything into a nice box to be mounted on a wall, so Im sure I will have more questions when I delve into that.
Finally got 'er done! Even had it working on the first try. Oh boy, am I happy!
int bottomDataPin = 5;
int bottomLatchPin = 6;
int bottomClockPin = 7;
int topLatchPin = 3;
int topClockPin = 4;
int topDataPin = 2;
int j = 1;
int toShift_Top = 0;
int toShift_Bottom = 0;
char m[4];
byte data;
byte dataArray[10];
DallasTemperature tempSensor0;
DallasTemperature tempSensor1;
pinMode(topLatchPin, OUTPUT);
pinMode(bottomLatchPin, OUTPUT);
tempSensor0.begin(11);
tempSensor1.begin(12);
// clear both displays with 0's
// top
digitalWrite(topLatchPin, 0);
shiftOut(topDataPin, topClockPin, dataArray[0]);
digitalWrite(topLatchPin, 1);
//bottom
digitalWrite(bottomLatchPin, 0);
shiftOut(bottomDataPin, bottomClockPin, dataArray[0]);
digitalWrite(bottomLatchPin, 1);
int k = 1000;
toShift_Top = (tempSensor0.getTemperature() * 100);
// the following code is by EmilyJane of arduino.cc forums
int temp = toShift_Top;
m[i] = temp / k;
k = k / 10;
// end
shiftOut(topDataPin, topClockPin, dataArray[m[0]]);
shiftOut(topDataPin, topClockPin, dataArray[m[1]]);
shiftOut(topDataPin, topClockPin, dataArray[m[2]]);
shiftOut(topDataPin, topClockPin, dataArray[m[3]]);
k = 1000;
toShift_Bottom = (tempSensor1.getTemperature() * 100);
// again, the following code is by EmilyJane of arduino.cc forums
temp = toShift_Bottom;
m[i] = temp / k;
k = k / 10;
// end
shiftOut(bottomDataPin, bottomClockPin, dataArray[m[0]]);
shiftOut(bottomDataPin, bottomClockPin, dataArray[m[1]]);
shiftOut(bottomDataPin, bottomClockPin, dataArray[m[2]]);
shiftOut(bottomDataPin, bottomClockPin, dataArray[m[3]]);
//clock idles low
int i=0;
int pinState;
pinState= 1;
else {
pinState= 0;
//stop shifting
