I am having trouble interfacing the Atmega 2560 feeding outputs from Port K pins into the inputs for the inverting chip. Regardless of whatever the arduino is outputting to the chip's inputs, the chip is always outputting low. However, if I feed ground from the arduino board as a "test" input, the chip is able to invert that low voltage into a high voltage. I have tested the arduino outputs with an oscilloscope, and they indeed output high or low voltage as desired.
Here is the software I wrote (Before anyone asks, I'm not using library functions a. for a fundamental understanding of whats going on and b. I'm not supposed to)
// Define Port B Register Pointers
volatile unsigned char* port_b = (unsigned char*) 0x25;
volatile unsigned char* ddr_b = (unsigned char*) 0x24;
volatile unsigned char* pin_b = (unsigned char*) 0x23;
//Define Port K Register Pointers
volatile unsigned char* port_k = (unsigned char*) 0x108;
volatile unsigned char* ddr_k = (unsigned char*) 0x107;
volatile unsigned char* pin_k = (unsigned char*) 0x106;
int A;
int B;
int C;
int D;
*ddr_b &= 0x00; //set all pins to input
*port_b |= 0xFF;// enable poullup resistors
*ddr_k &= 0xFF;
if( *pin_b & 0x01 ){A = 1;}
else{A = 0;}
if( *pin_b & 0x02 ){B = 1;}
else{B = 0;}
if( *pin_b & 0x04 ){C = 1;}
else{C = 0;}
if( *pin_b & 0x08 ){D = 1;}
else{D = 0;}
if((B==1 || D == 1)&&(A == 1 || C == 0)&&(B == 0 || C == 0)&&(A == 0 || D == 1)&&(A == 1 || B == 0 || D == 0)&&(A == 0 || B == 1 || C == 1)) // Boolean equation if a is 1 FIXED
{*port_k = *port_k | 0x01;} //set pk0 high
{*port_k = *port_k & 0xFE;} // set pk0 low
if((A==1 || B == 1)&&(B==1 || D == 1)&&(A == 1 || C == 1 || D == 1)&&(A == 1 || C == 0 || D == 0)&&(A == 0 || C == 1 || D == 0)) // Boolean equation if b = 1 FIXED
{ *port_k = *port_k | 0x02;} //set pk1 high
{*port_k = *port_k & 0xFD;} // set pk1 low
if((A == 1 || C == 1)&&(A == 1 || D == 0)&&(C == 1 || D == 0)&&(A == 1 || B == 0)&&(A == 0 || B == 1)) // Boolean equation if c = 1 FIXED
{*port_k = *port_k | 0x04;} // set pk2 high
{*port_k = *port_k & 0xFB;} // set pk2 low
if ((A == 0 || C == 1)&&(A == 1 || B == 1 || D == 1)&&(B == 1 || C == 0 || D == 0)&&(B == 0 || C == 1 || D == 0)&&(B == 0 || C == 0 || D == 1)) //Boolean equation if d = 1 FIXED
{*port_k = *port_k | 0x08;} //set pk3 high
{*port_k = *port_k & 0xF7;} // set pk3 low
if((B == 1 || D == 1)&&(C == 0 || D == 1)&&(A == 0 || C == 0)&&(A == 0 || B == 0))// Boolean equation if e = 1 FIXED
{*port_k = *port_k | 0x10;} // set pk4 high
{*port_k = *port_k & 0xEF;} // set pk4 low
if((C == 1 || D == 1)&&(B == 0 || D == 1)&&(A == 0 || B == 1)&&(A == 0 || C == 0)&&(A == 1 || B == 0 || C== 1))// Boolean equation if f = 1 FIXED
{*port_k = *port_k | 0x20;} // set pk5 high
{*port_k = *port_k & 0xDF;} // set pk5 low
if((B == 1 || C == 0)&&(C == 0 || D == 1)&&(A == 0 || B == 1)&&(A == 0 || D == 0)&&(A == 1 || B == 0 || C == 1))// Boolean equation if g = 1 FIXED
{*port_k = *port_k | 0x40;} // set pk6 high
{*port_k = *port_k & 0xBF;} // set pk6 low
Serial.print(A);
Serial.print(B);
Serial.print(C);
Serial.print(D);
Serial.write("\n");
delay(250);
I have attached the full and partial schematics below.
Essentially my problem boils down to: why will the chip invert a low voltage from the ground pin from the Arduino, yet it won't invert a low voltage output from one of the Port K pins?
