interfacing nokia 6610
hi guys,
i have a cellphone nokia 6610 and i want to ask how to interfacing nokia 6610 to arduino? is there only connecting the tx-rx-gnd 6110 to the arduino or use rs232 to ttl adapters?? does anyone have wiring diagram connecting nokia 6110 to arduino?
Thanks,
best regards. :smiley:
the pinout http://pinouts.ru/CellularPhones-Nokia/nokia_pop_pinout.shtml
pins 6 & 7 used for serial comm. I'd guess u need a rs232-ttl adapter.
thanks knut, do you have wiring diagram how to connect nokia, rs232-ttl adapter and arduino? coz im newbie about electronics., my basic is refrigeration engineer..
is nokia use AT command or PDU?
thankss
Reading:http://www.ehow.com/how_7829941_send-port-using-nokia-1112.html
I'm not 100% certain, but I belive the nokia understand AT-commands
From search, it looks like the phone HAS TTL-level (u check this with a multimeter)
If its RS232-level, u need an adapter or build one yourself
others have ttl
Serial Communication With Cell Phones | Hackaday
The photo supports the ttl-lever theory
Thanks knut, i have tried the nokia 6610 with hyperterminal, and nokia 6610 use at command with text . (AT+CMGF=1 respon OK).
and i have tried to send sms from hyperterminal.
i use CA-42 cable for communicate between hyperterminal and nokia 6610.
i still dont understand how to connect and interface the nokia 6610 to the arduino.. :fearful:
anyone can help me please.. this is my last project for diploma :astonished:
thanks,
best regards
asmoro
Check voltage at comm-pins on your nokia (the internal 'dots') to verify that they are almost TTL-level
(0V ..3.5V ?) If this is the case, you can connect directly. (add a small resistors i series with arduinos TX)
I guess softwareserial can be used. Connect common groud,
Rx to Tx, both directions.
