Interfacing with opto isolator
Hello. I'm new to the Arduino but have a background in c/c++ programming. I want to interface an existing circuit to the Arduino. Please see the attached for a picture of the circuit diagram. Basically it is an opto-isolator in an existing piece of equipment that drives a led via a 1k resistor from 5v. When certain events happen in the equipment, the led flashes briefly. I want to interface this to a digital pin (configured as an input) on the Arduino so that I get an interrupt everytime the led flashes. Programming-wise at the moment all I want to do is to display on the serial monitor a count of how many pulses have been received when one arrives.
Please would some kind person advise as to how I should interface this circuit to the Arduino. Can I just connect a lead to one end of the resistor (which one?) to say digital pin 2 and take 5v and ov from the Arduino board? I can change the layout of the resistor/led but can't change the opto-isolator. I would like to keep the led for a visual indication that events are happening.
Thank you for your time.
http://arduino.cc/en/Reference/AttachInterrupt
Hook the bottom of the resistor(s) to the Arduino. If you want to count both LEDs, hook one to pin 2 (INT0) and the other to pin 3 (INT1). Remember to connect the equipment ground to the Arduino ground. Detect the interrupts with the attachInterrupt() function as fungus has indicated. A negative-going pulse will occur each time an LED illuminates, so set the interrupt(s) to detect falling edges.
Use
pinMode (pinX, INPUT_PULLUP);
on the pins so you have a reliable high level when the LEDs are not fired.
Thank you all so much for your helpful replies. I've now got a count showing in the serial monitor for the pulses received. :slight_smile:
If the LEDs aren't red or orange add a 10k resistor in parallel with each to help pull-up
the voltage (blue LEDs have too high a forward voltage).
The leds are red and green. Is that OK without the 10k parallel resistor because as suggested I've used
for the 2 data lines (pin 2 and pin 3) to which I have them connected. It's now been running for a couple of hours and everything seems OK. I'm powering the opto-isolators and the leds from 0 & 5v on the Uno board.
Now to the next phase! I'm adding an RTC so that I can log the date/time of the pulses, an ethernet/sd shield so that I can log to the sd and retrieve the data over the network (local) for analysis.
One further question if I may. If I power the Arduino from a power pack and then unplug the USB connection, does the program still run? And if the power is switched off does the program resume running when power is re-applied even if not connected to a computer via a USB lead? Once I have the data being written to the sd card and accessed via the network I don't need a computer attached anymore. Is this possible?
Thanks again for the help provided.
Using the internal pullup resistors should be fine.
2kaud:
Yes indeed.
Yes, the microcontroller will reset at power-on and begin executing the program from the start.
Absolutely.
You bet, have fun!
