Intermittent compile error 'Check_Water_Flow' was not declared in this scope
I compiled my sketch and there were no errors. I added an additional Water_Level_Sensor and recompiled the sketch and received the error - 'Check_Water_Flow' was not declared in this scope. I not sure how much detail is needed to help me solve this issue. Therefore, I will include the entire sketch.
Perhaps a little background as to the purpose of the sketch. I'm building a CNC machine that will have a water cooled spindle for the cutter. I had a router and the noise was deafening. Water is critical to keep the spindle at a safe operating temperature. To ensure this is accomplished I have 5 sensors on the machine to monitor the operation. The sensors are as follows:
1. Flow_Sensor - verifies water is being pumped through the cooling tubing.
2. Water_Pressure_Sensor - verifies pressure is at the proper level.
3. Water_Level_Sensor - verifies adequate water is in cooling reservoir.
4. Water_Level_Sensor_2 - verifies adequate water is in pumping reservoir.
5. Water_Temp - reports the temperature of the water.
I have a LCD display attached for showing current status of the CNC Machine. There are comments throughout the sketch. Some are for future functionality and others for sketch documentation.
Sketch:
/* Arduino DS18B20 temp sensor and YF ‐ S201 Water Flow Sensor
   for Openbuilds 1515 CNC machine with 220V water cooled spindle
   Water Flow Sensor output processed to read in "bool".
   HIGH = Water Flow, LOW = No Water Flow.
   Plastic PP Float Switch Tank Liquid Water Level Sensor, Model: DP5200
   1/4" DC 24V Low Pressure Switch for Water Filter System 0.01MPa
   SunFounder 2004 20x4 LCD Module IIC I2C Interface Adapter Blue Backlight */
   Water Flow Sensor output processed to read in "bool". HIGH = Water Flow, LOW = No Water Flow.
   1/4" DC 24V Low Pressure Switch for Pump Water Filters for Water Filter System 0.01MPa
//Include libraries
//Temperature sensor libraries
#include <OneWire.h>
#include <DallasTemperature.h>
// #include "Keyboard.h"
//Configure LCD display
LiquidCrystal_I2C lcd(0x27, 20, 4);
//Define Constants
  const int Buzzer = 2; //Assign buzzer to Arduino pin 2
  const int Flow_Sensor = 3; //Assign Water Flow Sensor Input to Arduino pin 3
  #define ONE_WIRE_BUS 4 //Assign ONE_WIRE_BUS to Arduino pin 4
  const int Overheat_Fan = 5; //Assign Overheat_Fan to Arduino pin 5
  const int Red_STOP = 6; //Assign Red_STOP to Arduino pin 6
  const int Amber_CAUTION = 7; //Assign Caution to Arduino pin 7
  const int Green_GO = 8; //Assign All_Systems_Go to Arduino pin 8
  const int Water_Pressure_Sensor = 9; //Assign Water Level Sensor Input to Arduino pin 9
  const int Water_Level_Sensor = 10; //Assign Water Level Sensor Input to Arduino pin 10
  const int Water_Level_Sensor_2 = 11; //Assign Water Level Sensor Input to Arduino pin 11
//Configure Variables
  float Water_Temp; // Variable to store temperature in Fahrenheit
  bool Water_Flow;
  bool Water_Level;
  bool Water_Level_2;
  bool Water_Pressure;
  bool Displayed_All_Systems_Go;
  bool TempOK;
//Configure  ONE_WIRE_BUS
  OneWire oneWire(ONE_WIRE_BUS); //Setup a oneWire instance to communicate with any OneWire device
  DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature.
  //Configure I/O Pins
  pinMode(Flow_Sensor, INPUT);
  pinMode(Water_Pressure_Sensor, INPUT);
  pinMode(Water_Level_Sensor, INPUT);
  pinMode(Water_Level_Sensor_2, INPUT);
  pinMode(Buzzer, OUTPUT); //Buzzer to Arduino pin 2
  pinMode(Overheat_Fan, OUTPUT); //Overheat fan Arduino pin 5
  pinMode(Red_STOP, OUTPUT); //RED WARNING LED Arduino pin 6
  pinMode(Amber_CAUTION, OUTPUT); //AMBER WARNING LED Arduino pin 7
  pinMode(Green_GO, OUTPUT); //ALL SYSTEMS OK! GREEN LED Arduino pin 8
//  digitalWrite(Water_Pressure_Sensor, 1); //Set pullup for Check_Water_Pressure High
  digitalWrite(Water_Level_Sensor, 1); //Set pullup for Water_Level_Sensor High
  digitalWrite(Water_Level_Sensor_2, 1); //Set pullup for Water_Level_Sensor High
  lcd.begin();
  lcd.clear();
  //Initate Serial Communicatioon.
void loop(){
// ADD KEYBOARD INPUT LATER TO TURN-ON DEBUG OPTIONS
//Write code to check temperature BEFORE displaying ALL GOOD!
//Check for water flow
**Water_Flow = Check_Water_Flow(); //THIS IS WHERE THE ERROR OCCURS**
Water_Pressure = Check_Water_Pressure();
Water_Level = Check_Water_Level();
Water_Level_2 = Check_Water_Level_2();
Water_Temp = Check_Water_Temp();
  Serial.print("Water_Level = ");
  Serial.print(Water_Level);
  Serial.print("\n");
  Serial.print("Water_Level_2 = ");
  Serial.print(Water_Level_2);
  Serial.print("\n");
  Serial.print("Water_Pressure = ");
  Serial.print(Water_Pressure);
  Serial.print("\n");
  Serial.print("Water_Temp = ");
  Serial.print(Water_Temp);
  Serial.print("\n\n");
    lcd.setCursor(0,3);
    lcd.print("CWTRL = ");
    lcd.print(Water_Level);
  if (Water_Temp>90){
    Temp_Over_90(); //GOSUB Temp Over 90
  else if (Water_Temp >= 80 && Water_Temp <= 90){
    Temp_Between_80_and_90(); //GOSUB Temp_Between_80_and_90
    Serial.print("TempOK = ");
    Serial.print(TempOK);
    Serial.print("\n\n");}
//Is Water_Flow Good
  else if(Water_Flow == 1){
    Display_All_Good();
    Serial.print("********************* \n"); //Print Openbuilds 1515 message
    Serial.print("*  Openbuilds 1515  * \n"); //Print Openbuilds 1515 message
    Serial.print("*    CNC MACHINE    *\n"); //Print CNC MACHINE message
    Serial.print("* All Systems Good! *\n"); //Print CNC MACHINE message
    Serial.print("\n");
//    delay(1000);}
  else{
//NO Water_Flow
//Call Warning Function for NO WATER FLOW
    lcd.clear();
    NO_WATER_FLOW();
    Serial.print("******************* \n"); //Print WARNING message
    Serial.print("*  W A R N I N G  *\n");
    Serial.print("* N O   W A T E R *\n");
    Serial.print("*     F L O W     *\n");
    Serial.print("\n");
    delay(500);}
  if (Water_Level == 1){
//    lcd.clear();
//    lcd.setCursor(10,3);
//    lcd.print("DWL = ");
//    lcd.print(Detect_Water_Level);}
 //Read Temperature sensor
//  if (Water_Temp >= 76 && Water_Temp < 80){
//    Temp_Over_76_and_Under_80(); //GOSUB Temp_Over_76_and_Under_80
  if (Water_Temp < 76){
    Temp_Under_76(); //GOSUB Temp_Under_76
**int Check_Water_Flow(){** This is where I receive the error c
//  bool result;
  Water_Flow = digitalRead(Flow_Sensor);
  return Water_Flow;
int Check_Water_Level(){
  Water_Level = digitalRead(Water_Level_Sensor);
  return Water_Level;
int Check_Water_Level_2(){
  Water_Level_2 = digitalRead(Water_Level_Sensor_2);
  return Water_Level_2;
int Check_Water_Pressure(){
  Water_Pressure = digitalRead(Water_Pressure_Sensor);
  return Water_Pressure;
float Check_Water_Temp(){
  sensors.requestTemperatures(); //Read temperature sensor
  Water_Temp = sensors.getTempFByIndex(0);
//  Serial.print("Water_Temp = ");
//  Serial.print(Water_Temp);
//  Serial.print("\n\n");
  return Water_Temp;
void Display_All_Good(){
  if(Displayed_All_Systems_Go == 0){
    lcd.clear();
    lcd.setCursor(3,0);
    lcd.print("Openbuilds 1515"); //Print Openbuilds 1515 message
    lcd.setCursor(5,1);
    lcd.print("CNC MACHINE"); //Print CNC MACHINE message
    lcd.setCursor(2,2);
    lcd.print("All Systems Good!"); //Print CNC MACHINE message
    digitalWrite(Green_GO, HIGH);
    digitalWrite(Buzzer, 0);
    digitalWrite(Red_STOP, 0);
    Displayed_All_Systems_Go = 1;}
  else{
      lcd.setCursor(3,0);
      lcd.setCursor(5,1);
      lcd.setCursor(2,2);
      digitalWrite(Green_GO, !HIGH);
    return 0;
void NO_WATER_FLOW(){
    lcd.clear();
    lcd.setCursor(3, 2);
    lcd.print("             ");
    lcd.print("NO WATER FLOW");
//    delay(1000);
    digitalWrite(Buzzer, 1);
    digitalWrite(Amber_CAUTION, 0);
    digitalWrite(Red_STOP, 1);
    digitalWrite(Overheat_Fan, 0);
    //Remove // below to run Debug code for no water flow
    //Debug_NO_WATER_FLOW(); //GOSUB Debug_NO_WATER_FLOW
    //^^^End Troubleshooting Volume and Flow Rate^^^^^
    return 0;
void Good_Water_Flow(){
  Serial.println("Entering Good_Water_Flow \t");
  lcd.clear();
  Display_All_Good();
  return 0;
void Debug_NO_WATER_FLOW(){
//Debug code
  lcd.setCursor(0,0);
  lcd.print("DEBUG NO WATER FLOW");
  return 0;
void Temp_Over_90(){
          lcd.clear();
          lcd.setCursor(0,2);
          lcd.print("Temp is > 90");
    digitalWrite(Overheat_Fan, 1);
    digitalWrite(Amber_CAUTION, 1);
    lcd.setCursor(3, 3);
    lcd.print("Water_Temp = ");
    lcd.print(Water_Temp);
    TempOK = 0;
  return TempOK;
void Temp_Between_80_and_90(){
      lcd.clear();
      lcd.setCursor(0,2);
      lcd.print("80 < Temp < 90");
      TempOK = 1;
  return TempOK;
What do you think that '**' in front of Water_Flow does?
Same question here. Why are you trying to return a pointer to a pointer to an int?
I was trying to make that line show up as BOLD to mark where the error is. I'm not familiar with is forum.
That is irrelevant, it is C/C++ code you are writing, so use C/C++ syntax.
There is no way to make a line bold in the C/C++ language, so don't even try.
Not sure about that error, but you are trying to return an awful lot of values from void functions.
It looks like LiquidCrystal_I2C .begin() takes 3 values, you are giving 0.
All of your function definitions are inside loop(). Use ctrl+t and make sure all function definitions start at the left hand column. Check your { and } to make sure they match.
Make sure all comments start with // not *
Your loop function doesn't end - missing at least one closing brace: }
Also, don't put garbage like this inside the Code Tags without making it a proper comment. That's just multiple lines of junk we have to fix before we attempt to compile it:
Sketch:
Commenting out a line with a '}' is going to cause problems.
