Hello,
Currently I am trying to write an interpolating function, which connects individual dots I draw on my TFT ILI9341 Touch Screen. For some reason though, it behaves in a really buggy way.. It connects points at different parts, not where I draw and it behaves in a random way. It also stops working when I approach the maximum X value. Could anyone help me correcting my linearInterpolation function? I would be happy about any help! thank you. ![]()
My Display.cpp:
#include "Display.h"
// XPT2046_Touchscreen ts(CS_PIN); // Instanziierung eines ts Objekts der Klasse XPT2046_Touchscreen
// ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC);
#define TIRQ_PIN 2
#define CS_PIN 8
#define TFT_DC 9
#define TFT_CS 10
Display::Display() : ts(CS_PIN), tft(TFT_CS, TFT_DC)
// Original raw minimum and maximum values:
// X --> 340 bis 3900
// Y --> 200 bis 3850
boolean Display::isTouched()
  return touched = ts.touched();
int Display::getX()
  if (touched)
    TS_Point p = ts.getPoint(); // point getter function
      if (map(p.x, 340, 3900, 320, 0) <= 320)
        return map(p.x, 340, 3900, 320, 0);
      else if (map(p.x, 340, 3900, 320, 0) > 320)
        return maximumX;
      else if (map(p.x, 340, 3900, 320, 0) < 0)
        return minimumX;
          // return _beyondDisplay;
int Display::getY()
  if (touched)
      if (map(p.y, 200, 3850, 240, 0) <= 240)
        return map(p.y, 200, 3850, 240, 0);
      else if (map(p.y, 200, 3850, 240, 0) > 240)
        return maximumY;
      else if (map(p.y, 200, 3850, 240, 0) < 0)
        return minimumY;
void Display::drawButtons()
  for (int i{0}; i < 4; ++i)
    tft.fillRoundRect(_gap + (_gap + _widthSquare) * i, 220, _widthSquare, _heightSquare, _radiusOfRoundCorner, CL(250, 0, 0));
    tft.setCursor(26 + ((_gap + _widthSquare) * i), 227);
    tft.print(buttonNames[i]);
  tft.drawLine(0, 120, 320, 120, CL(255, 255, 255));
  tft.drawLine(0, 121, 320, 121, CL(255, 255, 255));
  tft.drawLine(0, 119, 320, 119, CL(255, 255, 255));
void Display::clear()
  tft.fillScreen(ILI9341_BLACK);
  drawButtons();
void Display::start()
  Serial.begin(38600);
  tft.begin();
  tft.setRotation(1);
  ts.begin();
  ts.setRotation(1);
  while (!Serial && (millis() <= 1000))
    ; // weiß nicht was das ist
boolean Display::pointInRect(int x, float y, float rectX, float rectY, float rectW, float rectH)
  boolean ret = false;
  if ((x >= rectX) && (x <= (rectX + rectW)) && (y >= rectY) && (y <= (rectY + rectH)))
    ret = true;
  return ret;
void Display::touchButton()
  if (pointInRect(_x, _y, _gap, (240 - _heightSquare), (_widthSquare), (_heightSquare)))
    tft.fillRoundRect(_gap, (240 - _heightSquare), _widthSquare, _heightSquare, _radiusOfRoundCorner, CL(250, 100, 0));
    clear();
    // clearArray();
void Display::draw(int x, int y)
  wave1Values[map(x, 0, 320, 0, 256)] = map(y, 0, 240, -32767, 32767);
  for (int i{0}; i < 257; ++i)
    tft.fillCircle(map(i, 0, 256, 0, 320), map(wave1Values[i], -32767, 32767, 0, 240), pointRadius, CL(255, 0, 0));
void Display::linearInterpolation()
  Serial.println(getX());
  for (int i = X_old; i < getX();)
    if (X_old <= getX())
      i++;
      i--;
    wave1Values[i] = map(i, X_old, getX(), wave1Values[map(X_old, 0, 320, 0, 256)], wave1Values[map(getX(), 0, 320, 0, 256)]);
  }Â
  X_old = getX();
Relevant loop part of my main code:
void loop ()
 if (display.isTouched())
  Serial.println(display.getX());
  if (previousIsTouched)
   display.linearInterpolation();
  display.touchButton();
  display.clear();
  display.draw(display.getX(), display.getY());
 previousIsTouched = display.isTouched();
 sequencer.stepButtons();
 sequencer.stepLED();
