Interrupt Issues with Mega2560 Rev 3
I am using an interrupt pin with a mechanical, 4-bit rotary encoder. The interrupt is monitoring the first pin of the encoder to detect when there is a CHANGE to trigger the ISR. The ISR updates an LCD display.
The issue is, when I was first messing with this, I was getting odd behavior where the interrupt would trigger multiple times in quick succession, so I figured it was switch debouncing issues. After scoping it, it definitely was. So a hardware, low-pass filter was added and the signal is now smooth as silk. The interrupt fires once, and only once, during each "click" of the encoder.
The part that has me scratching my head is this, the interrupt only works correctly when I have delay(1000) inside of the ISR. But that's strange because delay() isn't even supposed to work inside an ISR! The ISR certainly doesn't delay for 1000 ms, or I would surely notice it in the refresh on the LCD.
But when I removed delay(1000) it acts erratic. Here's what erratic means: the encoder is 4 bits (16 positions, 0 to 15). When incrementing the encoder is should count 0 to 15 going up and 15 to 0 going down, but without the delay() (and it can be delay(1000), delay(500), or delay(10), it all still works the same) the ISR doesn't work and the encoder count jumps around. Here is output from the two program variations: "Dec Pos" is just the position translated from 4-bit binary to a decimal position value
WITH delay() //Notice the numbers are sequential both up and down. I increment until 15 and then decrement until 4
Dec Pos: 10
Dec Pos: 11
Dec Pos: 12
Dec Pos: 13
Dec Pos: 14
Dec Pos: 15
Dec Pos: 14
Dec Pos: 13
Dec Pos: 12
Dec Pos: 11
Dec Pos: 10
Dec Pos: 9
Dec Pos: 8
Dec Pos: 7
Dec Pos: 6
Dec Pos: 5
Dec Pos: 4
WITHOUT delay() //Notice the numbers jump around. I increment until 15 and then decrement. But it's hard to know what the real position is.
Dec Pos: 8
Dec Pos: 9
Dec Pos: 10
Dec Pos: 11
Dec Pos: 14
Dec Pos: 15
Dec Pos: 10
Dec Pos: 11
Dec Pos: 8
Dec Pos: 15
Dec Pos: 6
Dec Pos: 7
Dec Pos: 4
Dec Pos: 5
I have attached 2 sketches to this post. One with the delay() and one without. Only the delay() work correctly. Any thoughts?
I read here that potentially some interrupts can't handle a ChangeIntterupt, but I am not sure if I interpreted that correctly. Problem with MEGA2560 and interrupts - Programming Questions - Arduino Forum
I have tried pins 2 and 3 as the interrupts.
Ionic_v01_noDelay.ino (2.31 KB)
Ionic_v01.ino (2.47 KB)
Read about interrupts and the limitations inside an ISR. gammon interrupts
No delay, no Serial.print, no Serial.write and be as fast as possible.
Set a flag in the ISR (volatile) to signal new data (also volatile).
In loop you grab the new value when the flag is set.
Remember to lock out interrupts while reading/writing entities bigger than one byte.
Serial.print() depends on interrupts, so it should not be in an interrupt service routine.
Writing to LCDs is typically slow, so that should not happen in an ISR, either.
What I would do is to stop doing stuff in the ISR that shouldn't be done in the ISR, to see if that solves the problem.
PaulS and Whandall,
I knew I was going to get dinged on the use of Serial and keeping the ISR simple (ideally with a flag).
Here is the updated version with the ISR as simple as I can make it. Still doesn't work. Works with delay() inside the ISR, but when not when delay() is removed.
//Libraries
#include <LiquidCrystal.h>
#include <PID.h>
#include <EEPROM.h>
////////////  Globals    //////////////////////////////////////
volatile int SETPOINT = 125;
boolean SETPOINT_CHANGE_flag = false;
boolean OUTLET_STREAM_UNSAFE_flag = false;
boolean REPLACE_CC_CARTRIDGE_flag = false;
boolean REPLACE_MG_CARTRIDGE_flag = false;
boolean HIGH_FEEDWATER_TDS_flag = false;
volatile boolean MINERAL_CHANGE_FLAG = false;
volatile byte ENC1 = 0, ENC2 = 0, ENC4 = 0, ENC8 = 0; //Encoder bits
/////////////  Pin Setup  //////////////////////////////////////
const int TANK_PRESSURE_pin = 1;
const int INLET_PRESSURE_pin = 2;
const int TDS_FEEDWATER_pin = 3, TDS_FEEDWATER_TEMP_pin = 4;
const int TDS_Ca_pin = 5, TDS_Ca_TEMP_pin = 6;
const int TDS_PRODUCT_pin = 7, TDS_TPRODUCT_TEMP_pin = 8;
const int ENC1_pin = 2, ENC2_pin = 4, ENC4_pin = 5, ENC8_pin = 6; //Encoder pins
const int SOL_SUPPLY_pin = 7, SOL_DOSER_pin = 8; //Solenoid pins
const int LCD_RS_pin = 9, LCD_RW_pin = 1, LCD_ENABLE_pin = 8, LCD_D0_pin = 14, LCD_D1_pin = 15, LCD_D2_pin = 16, LCD_D3_pin = 17, LCD_D4_pin = 18, LCD_D5_pin = 19, LCD_D6_pin = 20, LCD_D7_pin = 21;
////////////  LCD setup  ///////////////////////////////////////
LiquidCrystal lcd(LCD_RS_pin, LCD_ENABLE_pin, LCD_D0_pin, LCD_D1_pin, LCD_D2_pin, LCD_D3_pin, LCD_D4_pin, LCD_D5_pin, LCD_D6_pin, LCD_D7_pin);
byte block[8] = {
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111
 pinMode(ENC1_pin, INPUT);
 pinMode(ENC2_pin, INPUT);
 pinMode(ENC4_pin, INPUT);
 pinMode(ENC8_pin, INPUT);
 attachInterrupt(digitalPinToInterrupt(ENC1_pin), mineralChangeISR, CHANGE);
 //Bootup
 lcd.createChar(0, block);
 lcd.begin(16, 2);
 lcd.print("   OS v 0.10   ");
 lcd.setCursor(0, 0);
 lcd.print(" MINERALIZATION ");
 lcd.cursor();
 if (MINERAL_CHANGE_FLAG == true)
   noInterrupts();
   mineralChangeLCD();
   interrupts();
void mineralChangeLCD(){
 ENC1 = digitalRead(ENC1_pin);
 ENC2 = digitalRead(ENC2_pin);
 ENC4 = digitalRead(ENC4_pin);
 ENC8 = digitalRead(ENC8_pin);
 int ENC_POSITION = int(((ENC1) | ((ENC2) << 1) | ((ENC4) << 2) | ((ENC8) << 3)));
 for (int i = 0; i <= 15; i++) {
   lcd.setCursor(i, 1);
   if (i <= ENC_POSITION) {
     lcd.write(byte(0));
   else {
     lcd.write(" ");
void mineralChangeISR() {
 //delay(1000);
 MINERAL_CHANGE_FLAG = true;
Since when has a byte more than one byte?
Why do you want to run mineralChangeLCD() with interrupts disabled?
What values did you use? Schematic?
You are STILL trying to do stuff with interrupts disabled that you should not be doing.
Reading the encoder pins belongs in the ISR. Calculating the encoder value belongs in the ISR.
ENC_POSITION should be a global, volatile variable. Resetting it is the ONLY thing that should happen with interrupts disabled, if you need to reset it at all.
