Dear All,
Here is the sketch
/* Emmision Monitoring IoT
* Mula W Wangsaputra
* YB1BUL
* 10 Jun 2022
#include <SPI.h>
#include <LoRa.h>
#define EngStsPin A1
#define ExtPwrPin A2
#define BatLevPin A3
#define FeedFFSPin 2
#define RetnFFSPin 3
#define ConnCheck 4
#define FuelTypePin0 8
#define FuelTypePin1 9
byte FeedSensInt=0; //0=digital pin 2
byte RetnSensInt=1; //1=digital pin 3
const long frequency=915E6; //LoRa Frequency
const int csPin=10; //LoRa radio chip select
const int resetPin=5; //LoRa radio reset
const int irqPin=6; //change for your board; must be a hardware interrupt pin
float fpc=0.46; //Feed Line Pulse Contstant in mL/p (mili-liter per pulse)
float rpc=0.46; //Return Line Pulse Contstant in mL/p (mili-liter per pulse)
//examples: 30 pulses/sec=1800 pulses/min=828 mL/min=0.828 L/m
//Engine Status variables
float engsts,min_engsts,d_engsts;
float v_min_engsts=7.0; //min_engsts=(R4)*V_real_engsts/(R3+R4), min_real_engsts=11V, min_engsts=2.62
float test_engsts,v_test_engsts=12.0;
float R3=15000;
float R4=4700;
//External Power level variables
float extpwr,d_extpwr; //extpwr=(R5+R6)*A2/R6, A2max=4.9V, extpwr_max=8.9V
float nom_extpwr=8.6;
float test_extpwr=8.7;
float R5=8200;
float R6=10000;
//Battery Level variables
float bl,d_bl,test_bl=8.4; //bl=(R7+R8)*A3/R8, A2max=4.9V, bl_max=8.9V
float R7=8200;
float R8=10000;
//Fuel Type, Fuel Burnt and Run Time variables
int fueltype;
bool ft0,ft1;
int feedpulsecount,retnpulsecount;
float flowrate,qtyml,f_burntml,f_burnt;
float run_time,run_time_min;
int samper=5;
unsigned long oldTime;
//LoRa Package
String s_fuel_type,s_engsts,s_ext_pwr_sts,s_ext_pwr,s_bl,s_f_burnt,s_run_time,s_del_pack;
int txtime=0,txint=4;
while (!Serial);
pinMode(EngStsPin,INPUT);
pinMode(ExtPwrPin,INPUT);
pinMode(BatLevPin,INPUT);
pinMode(FeedFFSPin, INPUT);
// digitalWrite(FeedFFSPin, HIGH);
pinMode(RetnFFSPin, INPUT);
// digitalWrite(RetnFFSPin, HIGH);
pinMode(ConnCheck,INPUT_PULLUP);
pinMode(FuelTypePin0,INPUT_PULLUP);
pinMode(FuelTypePin1,INPUT_PULLUP);
feedpulsecount=0;
retnpulsecount=0;
flowrate =0.0;
qtyml =0.0;
f_burntml =0.0;
f_burnt =0.0;
run_time =0.0;
oldTime =0;
d_engsts=(5.0/1024)*(R3+R4)/R4;
min_engsts=v_min_engsts*R4/(R3+R4);
test_engsts=v_test_engsts*R4/(R3+R4);
d_extpwr=(5.0/1024)*(R5+R6)/R6;
d_bl=(5.0/1024)*(R7+R8)/R8;
//___________________________Fuel Type__________________________________________________
ft0=digitalRead(FuelTypePin0);
ft1=digitalRead(FuelTypePin1);
if(ft0==false && ft1==false)
fueltype=0;
s_fuel_type=" FBD"; //Fuel: Bio Diesel
if(ft0==true && ft1==false)
fueltype=1;
s_fuel_type=" FRD"; //Fuel: Regular Diesel
if(ft0==false && ft1==true)
fueltype=2;
s_fuel_type=" FPL"; //Fuel: Pertalite
if(ft0==true && ft1==true)
fueltype=3;
s_fuel_type=" FPM"; //Fuel: Pertamax
//________________________________________________________________________________________
attachInterrupt(FeedSensInt, FeedPulseCounter, FALLING);
attachInterrupt(RetnSensInt, RetnPulseCounter, FALLING);
LoRa.setPins(csPin, resetPin, irqPin);
if (!LoRa.begin(frequency))
Serial.println("LoRa init failed. Check your connections.");
while (true);
Serial.println("LoRa init succeeded.");
Serial.println("LoRa Simple Node");
Serial.println("Only receive messages from gateways");
Serial.println("Tx: invertIQ disable");
Serial.println("Rx: invertIQ enable");
LoRa.onReceive(onReceive);
LoRa.onTxDone(onTxDone);
LoRa_rxMode();
//__________________________________Engine Status Check________________________________
engsts=analogRead(EngStsPin)*d_engsts;
// engsts=test_engsts;
if(engsts>min_engsts)
s_engsts=" ER"; //Engine Running
s_engsts=" EI"; //Engine Idle
while(engsts>min_engsts)
// _______________External Power Check____________________
extpwr=analogRead(ExtPwrPin)*d_extpwr;
// extpwr=test_extpwr;
s_ext_pwr=String(extpwr,1);
if(extpwr>nom_extpwr)
s_ext_pwr_sts=" EPG"; //External Power: Good
s_ext_pwr_sts=" EPL"; //External Power: Low
//________________Battery Level Check_____________________
bl=analogRead(BatLevPin)*d_bl;
// bl=test_bl;
s_bl=" BL"+String(bl,1); //Baterry Level
if((millis()-oldTime)>(1000*samper)) // Only process counters once samper x second
detachInterrupt(FeedSensInt);
detachInterrupt(RetnSensInt);
flowrate=((1000.0*samper)/(millis()-oldTime))*(feedpulsecount*fpc-retnpulsecount*rpc); //mili-Liter per second
oldTime=millis();
qtyml=flowrate*samper; //mili-Liter for (samper) seconds
f_burntml+=qtyml;
f_burnt=f_burntml/1000; //Liters
s_f_burnt=" FB"+String(f_burnt,2)+"L";
run_time=run_time+samper; //seconds
run_time_min=run_time/60; //minutes
s_run_time=" RT"+String(run_time_min,1)+"m";
s_del_pack=s_fuel_type+s_engsts+s_ext_pwr_sts+s_ext_pwr+s_bl+s_f_burnt+s_run_time;
feedpulsecount=0;
retnpulsecount=0;
attachInterrupt(FeedSensInt,FeedPulseCounter,FALLING);
attachInterrupt(RetnSensInt,RetnPulseCounter,FALLING);
txtime=txtime+1;
//___________________Send Monitoring Data Package via LoRa__________________
if(txtime==txint)
LoRa_sendMessage(s_del_pack); //send a message
// delay(5000);
Serial.println(s_del_pack);
txtime=0;
engsts=0;
//_____________________Interupt for Sensor Pulse Counter________________________________
void FeedPulseCounter()
feedpulsecount++;
void RetnPulseCounter()
retnpulsecount++;
//__________________________________Interupt for LoRa___________________________
void LoRa_rxMode()
LoRa.enableInvertIQ(); // active invert I and Q signals
LoRa.receive(); // set receive mode
void LoRa_txMode()
LoRa.idle(); // set standby mode
LoRa.disableInvertIQ(); // normal mode
void LoRa_sendMessage(String message)
LoRa_txMode(); // set tx mode
LoRa.beginPacket(); // start packet
LoRa.print(message); // add payload
LoRa.endPacket(true); // finish packet and send it
void onReceive(int packetSize)
String message = "";
while (LoRa.available())
message += (char)LoRa.read();
Serial.print("Node Receive: ");
Serial.println(message);
void onTxDone()
Serial.println("TxDone");
LoRa_rxMode();
boolean runEvery(unsigned long interval)
static unsigned long previousMillis = 0;
if (currentMillis - previousMillis >= interval)
return true;
return false;
