I have had some unexplained odd behaviour using multiple interuppts so I wrote the attached code to try and sort out what was going on. I did find that the response to inputs on interupts 3,4,5. was different and the system locked up somtimes when using theses inputs. However I have done some more work and I found that 3,4,5 seem to need good clean signals ie no fast bounce whereas 0,1,2 seem more tolerant. Maybe its just the board I have. Interseting to know if anyone else has had any similar results.
/* This is a test routine to explore the working of Interrupts on the Mega2560.
* The results are output via the Serial Monitor.
* Switches will have to be wired to the inputs declared below with either
* pull up or down resistors as needed.
* Lines 26 thro 31 the command FALLING will need to be changed in accordance
* with how you want to operate the interrupts.
* Malcolm Page malcolm@gbapj.com March 2013 */
//====================DECLARATIONS=================
int button0=2;
int button1=3;
int button2=21;
int button3=20;
int button4=19;
int button5=18;
//==========================SET UP========================
Serial.println("Hello Computer");
pinMode(button0,INPUT);
pinMode(button1,INPUT);
pinMode(button2,INPUT);
pinMode(button3,INPUT);
pinMode(button4,INPUT);
pinMode(button5,INPUT);
attachInterrupt(0,Funct0,FALLING); //int 0 on Pin 2
attachInterrupt(1,Funct1,FALLING); //int 1 on Pin 3
attachInterrupt(2,Funct2,FALLING); //int 2 on Pin 21
attachInterrupt(3,Funct3,FALLING); //int 3 on Pin 20
attachInterrupt(4,Funct4,FALLING); //int 4 on Pin 19
attachInterrupt(5,Funct5,FALLING); //int 5 on Pin 18
//=============================MAIN==============================
Serial.println("Start of loop");
Serial.println("Start of 10 Secs delay");
delay(10000);
Serial.println("Start of 20 SEcs.delay");
delay(20000);
Serial.println("Start of 30 Secs. delay");
delay(30000);
Serial.println("End of loop");
//======================Subroutines (Functions)=========================
void Funct0() // Interrupt 0 here
showf0();
void Funct1() // Interrupt 1 here
showf1();
void Funct2() // intereupt 2 here
showf2();
void Funct3() // Interrupt 3 here
showf3();
void Funct4() // Interrupt 4 here
showf4();
void Funct5() // interrupt 5 here
showf5();
//=======================Subroutines / Functions =============
void showf0()
Serial.println("INTERRUPT 0");
void showf1()
Serial.println("INTERRUPT 1");
void showf2()
Serial.println("INTERRUPT 2");
void showf3()
Serial.println("INTERRUPT 3");
void showf4()
Serial.println("INTERRUPT 4");
void showf5()
Serial.println("INTERRUPT 5");
//---------------------END----------------------------
