Hmmm, odd. I attached the file itself, but didn't realize it wasn't in the posting.
#include <Wire.h>
#define gallon 5//145
unsigned long pushTime[2];
int buttonPin = 2;
volatile byte state = LOW;
//int timer = 0;
int pulseCounter = 0;
//int count[2];
int galCount = 0;
int resetPin = 3;
int systemState = 2;
int controlPin = 10;
int userStart = 0;
Wire.begin(); //Join i2c Bus
Wire.beginTransmission(0x71);
Wire.write(0x76);
Wire.endTransmission();
pinMode(buttonPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(buttonPin),blink,RISING);
pinMode(resetPin,INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(resetPin),resetValues,RISING);
pinMode(controlPin, OUTPUT);
//Code associated with timer interrupt
//pinMode(outputLED, OUTPUT);
// TCCR0A = (1<<WGM01); //Set the CTC mode
// OCR0A=0xF9; //Value for ORC0A for 1ms
// TIMSK0 |= (1<<OCIE0A); //Set the interrupt request
// sei(); //Enable interrupt
// TCCR0B |= (1<<CS01); //Set hte prescale 1/64 clock
// TCCR0B |= (1<<CS00);
//unsigned long deltaTime = pushTime[0] - pushTime[1];
while(galCount < 3 == true){
if(pulseCounter < gallon == true){
//if(timer>=100){
//condition=!condition;
//timer=0;
//float flowRate = ((float)pulseCounter / (float)gallon)/ ((float) deltaTime);
Serial.print("Number of pulses: ");Serial.println(pulseCounter);
//Serial.print("0: ");Serial.println(pushTime[0]);
//Serial.print("1: ");Serial.println(pushTime[1]);
//Serial.print("Flow Rate: ");Serial.println(flowRate);
//Serial.print("Delta Time: ");Serial.println(deltaTime);
//unsigned long deltaCount = count[0] - count[1];
//Serial.print("Delta count: ");Serial.println(deltaCount);
//Serial.print("currentTime: ");Serial.println((unsigned long)millis());
//Serial.print("currentTime - pushTime[0]: ");Serial.println(millis() - pushTime[0]);
float flowRate = (((float)pulseCounter)/ ((float)millis() - (float)pushTime[0]));
float volume = ((float)pulseCounter) / ((float)gallon);
Serial.print("Volume: ");Serial.println(volume);
//digitalWrite(outputLED, condition);
}else{
Serial.println("Gallon incremented");
galCount++;
Serial.print("Number of Gallons: ");Serial.println(galCount);
pulseCounter = 0;
//lastPulseTime = currentPulseTime;
//prevPulse = currentPulse;
delay(100);
if(galCount >= 3 == true){
//digitalWrite(outputLED, HIGH);
systemState = 1;
digitalWrite(controlPin, LOW);
Serial.println("Fluid at 3 gallon capacity");
do{
//Serial.println("Fill complete");
Wire.write(0x76);
Wire.write('d');
Wire.write('o');
Wire.write('n');
Wire.write('E');
systemState = 0;
}while(systemState = 1);
//Serial.print("Push Time: ");//Serial.println(pushTime);
// Serial.print("Push Time [0]: ");Serial.println(pushTime[0]);
// Serial.print("Push Time [1]: ");Serial.println(pushTime[1]);
// unsigned long deltaTime = pushTime[0] - pushTime[1];
// Serial.print("Delta Time: ");Serial.println(deltaTime);
void blink(){
state = !state;
pushTime[1] = pushTime[0];
pushTime[0] = millis();
//count[1] = count[0];
//count[0] = pulseCounter;
pulseCounter++;
//ISR(TIMER0_COMPA_vect){
// timer++;
void resetValues(){
pulseCounter = 0;
galCount = 0;
systemState = 0;
Wire.write(0x76);
for(int i = 0; i < sizeof(pushTime) / sizeof(pushTime[0]); i++){
pushTime = 0;
