I have a sketch running on mega 2560 and two interrupts executing update code, one of the interrupts (4 on p19) triggers sporadically if I run a wire accross any of the other pins and touch the conductor, I have tried Rising/Falling/Low scenarios using 220r resistor but the result is the same.
The sketch switches the remaining pins high and low in a loop using port manipulation as well as there being an lcd matrix display,
Any help appreciated !
The interrupt is a push switch, I have tried pull up and down with 220r resistor connected to the ard 5v and gnd pins with rising and falling scenarios respec tively with the same result
tawn10:
t
also using internal pullup and both internal and external, lower r value minimises the effect ie it is worse with a 1k pullup
May be a hardware fault, I have just remembered that the reset button seems to be non functional,
unless there may be a common reason for this to happen ??
I have had interrupts triggered by switching in nearby wiring or ICs, in my case I was able to move my wires around to avoid the crosstalk - might be worth a try for you.
tawn10:
Can you draw a sketch (diagram) of your wiring? All this describing doesn't really work. And maybe post your code as well.
I have resolved the problem, In my port manipulation routine when closing a single port the loop was just setting all bits to zero, I masked the remaining bits and this resolved the problem, so to clarify an already low bit was being set to low in a loop. also altered the order in which pins were set high and low to reduce supply ripple.
