Interrupt
Hi I am new to Arduino and i want to write these two pieces of interrupt codes to arduino but i get back error messages can anyone help me ?
//timer 0 compare ISR
interrupt ([TIM0_COMP] void timer0_compare(void))
if(~PINB & 0x01) timepress0++;
if(~PINB & 0x02) timepress1++;
if(~PINB & 0x04) timepress2++;
timecount++;
timedeflate++;
//Decrement each time tast if they are not already zero
//timing for sampling data at every 40 msec
if(timing>0) --timing;
//run time for different tasks
//run timerate for measuring heart rate
if(timerate<6000) ++timerate;
//run timerun_dias
if(timerun_dias<2000) ++timerun_dias;
//if(countlcd) timelcd++;
//run time for the display
if(timedisplay<2000) ++timedisplay;
// ADC Interrupt
interrupt [ADC_INT] void adc_complete(void)
data = ADCH;
//then calculate adc_data into float;
adc_data = (float)(((float)data)/256*Vref);
//if signal is above threshold, go to calculate systolic pressure
if(meas_state ==Sys_Measure)
if(former<=TH_sys && adc_data>TH_sys)
sys_count++;
former = adc_data;
else if(meas_state==Sys_Cal)
if(count<4)
accum_data=accum_data+adc_data;
count++;
if(count==4)
press_data=accum_data/4;
systolic = (press_data/DC_gain)*9375;//calculate from adc_data
meas_state = Rate_Measure;
countpulse=0;
former = 2.4; //set the initial point for rate measuring
count_average=0;
else if(meas_state==Rate_Measure)
if(count_average<5)
if(former<TH_rate && adc_data>TH_rate && countpulse==0)
timerate=0;
countpulse=1;
former=adc_data;
if(former<TH_rate && adc_data>TH_rate && countpulse==1)
total_pulse_period=total_pulse_period+timerate;
timerate=0;
count_average++; //finish reading one period
}//count_average
former=adc_data;
}// else if(meas_state=Rate_Measure)
else if(meas_state==dias_Measure)
if(adc_data>TH_dias)
{ timerun_dias=0; //reset time if the signal
//is still greater than threshold (so it will never reach 1999)
//if it doesn't reset,the time will stuck at 1999
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Dias measure");
if(timerun_dias>=2000)
meas_state = dias_Cal;//if done go back to Sys_Measure to be ready for next opt
else if(meas_state==dias_Cal)
diastolic = (adc_data/DC_gain)*9375;//calculate from adc_data
meas_state = Sys_Measure;
currentState = displayState;
//open valve
PORTD=0;
timing = 40;//set time for another conversion
// end of ADC interrupt
You can't be bothered to read the how to use the forum sticky, so I can't be bothered to answer even if I could figure out the question. You will need to post the errors.
Thank you for helping !!!! Just Didn't thought you'll need that many errors
Here are my errors :
error: 'interrupt' does not name a type
error: expected initializer before '.' token
In function 'void setup()':
error: 'lcd' was not declared in this scope
In function 'void start_state()':
In function 'void inflate1_state()':
error: 'lcd_output' was not declared in this scope
In function 'void inflate2_state()':
error: 'ADCSR' was not declared in this scope
error: 'delay_ms' was not declared in this scope
In function 'void deflatestate()':
In function 'void display_state()':
In function 'void reset_state()':
In function 'void sysmeasure()':
In function 'void syscal()':
In function 'void ratemeasure()':
error: 'lcd_clear' was not declared in this scope
In function 'void diasmeasure()':
In function 'void diascal()':
In function 'void initialize()':
error: 'TIMSK' was not declared in this scope
error: 'OCR0' was not declared in this scope
error: 'TCCR0' was not declared in this scope
error: 'PORTA' was not declared in this scope
I changed these two first lines in the previous codes:
"interrupt([TIM0_COMP] void timer0_compare(void)"
and "interrupt [ADC_INT] void adc_complete(void)"
with these
"interrupts ([TIM0_COMP] void timer0_compare(void));"
and "interrupts ([ADC_INT] void adc_complete(void));"
end the errors dropped to these few :
sketch_apr16a.ino:81:50: error: macro "interrupts" passed 1 arguments, but takes just 0
sketch_apr16a.ino:110:46: error: macro "interrupts" passed 1 arguments, but takes just 0
sketch_apr16a.ino:81:1: error: 'interrupts' does not name a type
sketch_apr16a.ino:82:1: error: expected unqualified-id before '{' token
sketch_apr16a.ino:110:1: error: 'interrupts' does not name a type
sketch_apr16a.ino:111:1: error: expected unqualified-id before '{' token
but now I am really confused what these mean does anyone know?
I am making a blood pressure meter and i didn't write the code so your guess is as better than mine they way i get it is when you power up the device is to check if the cuff is deflated
Delta_G:
Did you mean something like this:
ISR(TIMER0_COMPA_vect){
//Some code inside the ISR
Yes that help can you help me with the other condition how it should be written?
