I am writing a program that changes the speed of a DC motor with encoder based on a potentiometer value, and that can measure the speed of the motor using the readings from the encoder outputs. The program works fully on tinkercad, however once I run the code on my Arduino uno (which has been wired up exactly the same as on tinkercad), the interrupt function no longer gets called and therefore cannot read the rpm of the motor.
Here is the code:
#define enA 9
#define in1 6
#define in2 7
#define button 4
#define enca 2
#define encb 3
volatile int count = 0;
int rotDirection = 0;
int pressed = false;
int prevT = 0;
float outCount = 0;
void encoderPulse()
count++;
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(button, INPUT);
pinMode(enca, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(enca), encoderPulse, RISING);
// Set initial rotation direction
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
int potValue = analogRead(A0); // Read potentiometer value
int pwmOutput = map(potValue, 0, 1023, 0 , 255); // Map the potentiometer value from 0 to 255
analogWrite(enA, pwmOutput); // Send PWM signal to L298N Enable pin
// Read button - Debounce
if (digitalRead(button) == true) {
pressed = !pressed;
while (digitalRead(button) == true);
delay(20);
// If button is pressed - change rotation direction
if (pressed == true & rotDirection == 0) {
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
rotDirection = 1;
delay(20);
if (pressed == false & rotDirection == 1) {
rotDirection = 0;
delay(20);
int currT = millis();
if ((currT - prevT) >= 200) {
outCount = (count*100)/(currT - prevT);
prevT = currT;
count = 0;
Serial.print(outCount);
Serial.print(" ");
Serial.print("RPM");
if (rotDirection == 1) {
Serial.print("Clockwise");
else {
Serial.print("Anti-Clockwise");
Serial.print("Trimmer Value : ");
Serial.print(pwmOutput);
And here is how the board is wired up:
Thanks for any help you can offer me!
