Hello good mornig for everyone! I am trying to use the WifiManager library to save the data of my MQTT connection, but when I intend to start the client I receive the error "invalid conversion from 'char *' to 'uint16_t {aka short unsigned int}' [-fpermissive]"
I leave my code and I will be very grateful to anyone who can help me or suggest a change in the code
Im using ArduinoJson from Blanchon version 5.7.3, Ive tryed others, and Wifimanager 0.12.0
I couldnt post the hole code
THANKS
//Define Adafruit connection data
char MQTT_SERV[45] = "";
char MQTT_PORT[30] = "";
char MQTT_NAME[20] = "";
char MQTT_PASS[10] = "";
HERE IS THE ERROR
>>>>Adafruit_MQTT_Client mqtt(&client, MQTT_SERV, MQTT_PORT, MQTT_NAME, MQTT_PASS);
Adafruit_MQTT_Subscribe notifications = Adafruit_MQTT_Subscribe(&mqtt, MQTT_NAME "/f/notifications");
WiFiManager wifiManager;
wifiManager.setAPCallback(configModeCallback);
wifiManager.setSaveConfigCallback(saveConfigCallback);
// Adding an additional config on the WIFI manager webpage for the API Key and Channel ID
WiFiManagerParameter customMqtt_Serv("mqtt_serv", "MQTT SERVER", MQTT_SERV, 50);
WiFiManagerParameter customMqtt_Port("mqtt_port", "MQTT PORT", MQTT_PORT, 35);
WiFiManagerParameter customMqtt_Name("mqtt_name", "MQTT USERNAME", MQTT_NAME, 25);
WiFiManagerParameter customMqtt_Pass("mqtt_pass", "MQTT PASSWORD", MQTT_PASS, 15);
wifiManager.addParameter(&customMqtt_Serv);
wifiManager.addParameter(&customMqtt_Port);
wifiManager.addParameter(&customMqtt_Name);
wifiManager.addParameter(&customMqtt_Pass);
strcpy(MQTT_SERV, customMqtt_Serv.getValue());
strcpy(MQTT_PORT, customMqtt_Port.getValue());
strcpy(MQTT_NAME, customMqtt_Name.getValue());
strcpy(MQTT_PASS, customMqtt_Pass.getValue());
bool loadConfig() {
File configFile = SPIFFS.open("/config.json", "r");
if (!configFile) {
Serial.println("Failed to open config file");
return false;
size_t size = configFile.size();
if (size > 1024) {
Serial.println("Config file size is too large");
return false;
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
StaticJsonBuffer<200> jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
if (!json.success()) {
Serial.println("Failed to parse config file");
return false;
strcpy(MQTT_SERV, json["mqtt_serv"]);
strcpy(MQTT_PORT, json["mqtt_port"]);
strcpy(MQTT_NAME, json["mqtt_name"]);
strcpy(MQTT_PASS, json["mqtt_pass"]);
return true;
bool saveConfig() {
JsonObject& json = jsonBuffer.createObject();
json["mqtt_serv"] = MQTT_SERV;
json["mqtt_port"] = MQTT_PORT;
json["mqtt_name"] = MQTT_NAME;
json["mqtt_pass"] = MQTT_PASS;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("Failed to open config file for writing");
return false;
json.printTo(configFile);
return true;
