I used the sketch at https://docs.arduino.cc/tutorials/opta/mac-address/ to check the mac addresses on my Opta Wifi device. The ethernet mac address returned was only 11 characters (not 12). I believe this is a problem with the code because if info->mac_address[2]
= 10 for example, the HEX value returned is only a
instead of 0a
, which should be the same decimal value of 10 but gives you the correct HEX value represented in two characters needed for the mac address.
The following sketch seems to fix the ethernet mac address issue by adding a printMacAddress
function to add leading zeros where needed:
(the code for the wifi mac address is still a mystery as that value is incorrect)
From: https://docs.arduino.cc/tutorials/opta/mac-address/
Opta device information retrieval
Purpose: Retrieve information of an Opta device such as its bootloader version, hardware functionalities, external memory size, and MAC address.
@author Arduino PRO Content team
@version 1.0 27/03/22
// Include the necessary header files and define macros
uint8_t* bootloader_data = (uint8_t*)(0x801F000);
uint8_t* bootloader_identification = (uint8_t*)(0x80002F0);
#if __has_include("opta_info.h")
#include "opta_info.h"
#define GET_OPTA_OTP_BOARD_INFO
OptaBoardInfo* info;
OptaBoardInfo* boardInfo();
#endif
while (!Serial) {}
delay(2500);
Serial.println("Opta Device Information");
uint8_t currentBootloaderVersion = bootloader_data[1];
String currentBootloaderIdentifier = String(bootloader_identification, 15);
if (!currentBootloaderIdentifier.equals("MCUboot Arduino")) {
currentBootloaderIdentifier = "Arduino loader";
Serial.println("- Bootloader identifier: " + currentBootloaderIdentifier);
Serial.println("- Magic number (validation): " + String(bootloader_data[0], HEX));
Serial.println("- Bootloader version: " + String(bootloader_data[1]));
#if defined(GET_OPTA_OTP_BOARD_INFO)
printOptaSecureInfo();
#endif
Checks if the magic number is 0xB5. If it is, prints the secure information of the device in the Serial Monitor.
@params none
@return none
void printOptaSecureInfo() {
info = boardInfo();
if (info->magic == 0xB5) {
Serial.println("- Secure information version: " + String(info->version));
Serial.println("- Ethernet functionality: " + String(info->_board_functionalities.ethernet == 1 ? "Yes" : "No"));
Serial.println("- Wi-Fi module functionality: " + String(info->_board_functionalities.wifi == 1 ? "Yes" : "No"));
Serial.println("- RS-485 functionality: " + String(info->_board_functionalities.rs485 == 1 ? "Yes" : "No"));
Serial.println("- QSPI memory size: " + String(info->external_flash_size) + " MB");
Serial.println("- Secure board revision: " + String(info->revision >> 8) + "." + String(info->revision & 0xFF));
Serial.println("- Secure VID: 0x" + String(info->vid, HEX));
Serial.println("- Secure PID: 0x" + String(info->pid, HEX));
Serial.println("- Ethernet MAC address (can be incorrect): " + String(info->mac_address[0], HEX) + ":" + String(info->mac_address[1], HEX) + ":" + String(info->mac_address[2], HEX) + ":" + String(info->mac_address[3], HEX) + ":" + String(info->mac_address[4], HEX) + ":" + String(info->mac_address[5], HEX));
Serial.println("- Ethernet MAC address (no hex): " + String(info->mac_address[0]) + ":" + String(info->mac_address[1]) + ":" + String(info->mac_address[2]) + ":" + String(info->mac_address[3]) + ":" + String(info->mac_address[4]) + ":" + String(info->mac_address[5]));
Serial.print("- Ethernet MAC address (correct HEX): ");
printMacAddress(info->mac_address);
if (info->_board_functionalities.wifi == 1) {
Serial.println("- Wi-Fi MAC address: " + String(info->mac_address_2[0], HEX) + ":" + String(info->mac_address_2[1], HEX) + ":" + String(info->mac_address_2[2], HEX) + ":" + String(info->mac_address_2[3], HEX) + ":" + String(info->mac_address_2[4], HEX) + ":" + String(info->mac_address_2[5], HEX));
Serial.println("- No secure information available!");
printBootloaderInfo();
#endif
Prints clock source, USB speed, Ethernet functionality, Wi-Fi functionality, RAM memory size, QSPI memory size, video output functionality, and secure element functionality.
@params none
@return none
void printBootloaderInfo() {
Serial.println("- Clock source: " + getClockSource(bootloader_data[2]));
Serial.println("- USB Speed: " + getUSBSpeed(bootloader_data[3]));
Serial.println("- Ethernet functionality: " + String(bootloader_data[4] == 1 ? "Yes" : "No"));
Serial.println("- Wi-Fi functionality: " + String(bootloader_data[5] == 1 ? "Yes" : "No"));
Serial.println("- RAM size: " + getRAMSize(bootloader_data[6]));
Serial.println("- QSPI memory size: " + String(bootloader_data[7]) + " MB");
Serial.println("- Video output functionality: " + String(bootloader_data[8] == 1 ? "Yes" : "No"));
Serial.println("- Secure element functionality: " + String(bootloader_data[9] == 1 ? "Yes" : "No"));
Convert a flag in the bootloader data to USB speed information.
@param bootloader flag (uint8_t)
@return USB speed information as a String
String getUSBSpeed(uint8_t flag) {
switch (flag) {
case 1:
return "USB 2.0/Hi-Speed (480 Mbps)";
case 2:
return "USB 1.1/Full-Speed (12 Mbps)";
default:
return "N/A";
Convert a flag in the bootloader data to clock source information.
@return clock source information as a String
String getClockSource(uint8_t flag) {
switch (flag) {
case 0x8:
return "External oscillator";
case 0x4:
return "External crystal";
case 0x2:
return "Internal clock";
default:
return "N/A";
Convert a flag in the bootloader data to RAM size information.
@return RAM size information as a String
String getRAMSize(uint8_t flag) {
if (flag == 0) {
return "N/A";
return (String(flag) + "MB");
// ------------------- this was pulled from mac address code retrieval for the Arduino R4
void printMacAddress(uint8_t *mac) {
for (int i = 0; i < 6; i++) {
if (i > 0) {
Serial.print(":");
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
I finally discovered that the QR code on the back of my Opta device contains both the mac address for ethernet and wifi modules. The sketch in this post still does not return the correct wifi mac address (for me it reports back cc:cc:cc:cc:cc:cc
), so I have not tried to look into the sketch code further to see what the problem is since I am able to pull (what I assume to be) the correct wifi mac address from the QR code.
