IoT Cloud Messenger Widget - dynamic value
Hi Experts,
My equipment are the following;
  • Portenta H7.
  • Portenta Mid Carrier.
  • Connected to my lAN via Wi-Fi
I have been trying to send a message to the Messenger widget in the IoT cloud. This message must be a message that containes an ever changing interger value. Like the below few messages.
  • "Bale number 22432 has just been made"
  • "Bale number 22433 has just been made"
  • "Bale number 22434 has just been made"
And so it sends a message every 3 to 15 min when a bale was made.
To send the "Bale number" and the "has just been made" is not a issue but to add the changing interger value has been a problem to get right.
I did use the itoa() to convert the interger to asci but the value of 29148 becomes 70734 if I send this to the messenger widget without the other part of the message.
Have anybody tried to use the messenger widget in this way by sending a message that containes a changing interger value?
probably this is not the most elegant solution, but it should work (assuming your messenger widget is linked to cloudVar):
    cloudVar = "Bale number ";
    cloudVar += bale;
    cloudVar += " has just been made";
