Hello,
I am trying to use IoT Remote App to display a value and use a button. This button ('reset'), works perfectly well and does its task. However, I am not able to receive any value. The 'value' widget just shows a constant "0".
Please let me know if you see anything obvious and why the dashboard is not updating.
I have attached my code below:
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/55e6fad5-b3e3-428e-9cf8-175c2c04550f
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
CloudLight reset_button;
CloudTime total_Time_Elapsed;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include "Arduino_GigaDisplay_GFX.h"
#include "Arduino_H7_Video.h"
#include <lvgl.h>
#include <ArduinoGraphics.h>
GigaDisplay_GFX display;
#define BLACK 0x0000
const int analogPin = A2;
unsigned long timer = 0;
unsigned long maxTimer = 0;
unsigned long interval = 1; // 1 millisecond
int timerMode = 0;
int timeMode = 0;
unsigned long startTime = 0;
unsigned long previousMillis = 0;
float threshold = 1.0; // Volts
unsigned long MaxTimer = 0;
bool printedFinalTimer = false;
void resetDevice() {
display.fillScreen(BLACK);
display.setCursor(0, 0);
display.setTextSize(3);
display.println("JHR");
display.println("Timer Starting");
display.println("Time Elapsed:");
timer = 0;
maxTimer = 0;
MaxTimer = 0;
timerMode = 0;
startTime = 0;
previousMillis = 0;
timeMode = 0;
display.begin();
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
resetDevice(); // Call the reset function during setup
ArduinoCloud.update();
if (((analogRead(analogPin)) > 200) && ((currentMillis - previousMillis) > interval)) {
int sensorValue = analogRead(analogPin);
float volt = sensorValue * (5.0 / 1023.0);
// Start the Timer when pressure signal is greater than 0.5 V
if ((volt > threshold) && (timerMode == 0) && (timeMode == 0)) {
startTime = millis();
timerMode = 1;
Serial.println("Recording Time");
if ((volt > 2.0) && (timerMode == 1)) {
timeMode = 1;
// If the pressure signal goes below 0.5V; the program will reset the timerMode = 0
if ((volt < threshold) && (timerMode == 1) && (timeMode == 1)) {
unsigned long currentTimer = millis() - startTime;
if (currentTimer > maxTimer) {
maxTimer = currentTimer;
startTime = 0;
timerMode = 0;
timeMode = 0;
Serial.println(sensorValue);
Serial.print(volt);
Serial.println(" V");
Serial.print("Timer Mode: ");
Serial.println(timerMode);
Serial.println(millis());
Serial.print("Start Time: ");
Serial.println(startTime);
Serial.println(maxTimer);
Serial.println(timeMode);
Serial.println("--");
// Check if the condition is no longer true and the timer has been recorded
if (((analogRead(analogPin)) < 215) && (maxTimer > 0) && (!printedFinalTimer) && (timeMode == 0)) {
printFinalTimerValue();
printedFinalTimer = true;
timerMode = 0;
void printFinalTimerValue() {
if ((maxTimer > 0) && (timerMode == 0)) {
MaxTimer = maxTimer;
display.print("Final Time: ");
display.print(MaxTimer);
display.print(" ms");
Serial.print("Max Time: ");
Serial.print(MaxTimer);
Serial.println(" ms");
CloudCounter total_Time_Elapsed = MaxTimer;
Serial.print("Total Time: ");
Serial.println(total_Time_Elapsed);
void onResetButtonChange() {
if (reset_button == true) {
display.print("Resetting Device");
delay (1500);
resetDevice(); // Call the reset function to properly reset the device
reset_button = false;
