IR Break Beam Sensors
Hello All.
I am working on a project with break beam sensors.
I have the sketch for one sensor (pair) and is working fine. However i need to use 12 sensors in my project, and i need help to edit the below sketch accordingly;
#define LEDPIN 4
  // Pin 4: Arduino has an LED connected on pin 4
  #define SENSORPIN 2
// variables will change:
int sensorState = 0, lastState=0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(LEDPIN, OUTPUT);
  // initialize the sensor pin as an input:
  pinMode(SENSORPIN, INPUT);
  digitalWrite(SENSORPIN, HIGH); // turn on the pullup
void loop(){
  // read the state of the pushbutton value:
  sensorState = digitalRead(SENSORPIN);
  // check if the sensor beam is broken
  // if it is, the sensorState is LOW:
  if (sensorState == LOW) {
    // turn LED on:
    digitalWrite(LEDPIN, HIGH);
  else {
    // turn LED off:
    digitalWrite(LEDPIN, LOW);
  if (sensorState && !lastState) {
    Serial.println("Unbroken");
  if (!sensorState && lastState) {
    Serial.println("Broken");
  lastState = sensorState;
Packe lastState und sensorState in eine struct und erstelle ein Array davon. Mit einem Beispiel kann ich leider nicht dienen, mir ist die C/C++ Syntax zu fremd.
Oder ein Array aus jeder Variablen:
int sensorState[12], lastState[12];
Dann alle Sensoren in einer Schleife abarbeiten.
Are you going to use 12 leds with the 12 sensors ?
You may have to deal with IR reflections causing spurious results. Possible solutions are either by the design of the physical enclosure or in code by switching the leds / sensors in sequence.
So what have you tried so far? Where are you stuck?
Before getting to code, have you thought about a plan for how to make this work?
Hello casinocip
Welcome to the worldbest Arduino forum ever.
Consider:
//https://europe1.discourse-cdn.com/arduino/original/4X/7/e/0/7e0ee1e51f1df32e30893550c85f0dd33244fb0e.jpeg
// make variables
constexpr uint8_t Inputs[] {A0,A1,A2};
constexpr uint8_t Outputs[] {9,10,11};
  for (auto Input:Inputs) pinMode(Input,INPUT_PULLUP);
  for (auto Output:Outputs) pinMode(Output,OUTPUT);
  uint8_t element=0;
  for (auto &Output:Outputs) digitalWrite(Output,digitalRead(Inputs[element++])?LOW:HIGH);
Hello Awneil,
The code attached works and does what i need but is only for one input. I am stuck on adding 11 more sensors as input.
Basically what i am aiming here, is to have 12 beams around and object. Whenever one of the beams is interrupted, a relay is activated and trigger and alarm in the Milestone VMS.
Again, everything works as described but only with one beam
Yes, I got that.
So what have you tried so far in extending it to 12 sensors?
Where are you stuck in extending it to 12 sensors?
Coding should be the final part - before you code, you need a design...
The what??
IR radiation is emitted in a wide angle and is heavily reflected by many materials, as you may know from your TV... remote control. Breaking one such "beam" may be undetected.
Thank you for the feedback DrDiettrich. I will place the sensors 8cm apart (as required in my project) and see if there are any interferences. Then i can test the beams one by one with the code i have. Just don't know enough about coding to enable 12 different input pins
Again, before getting to coding, you need to have a design - a plan - for how you are going to do this.
So what is your plan?
Start with the design (plan), then think about how to implement that in code...
Thank you!
Hello again,
After taking in consideration your advices and reading all related posts, i managed to figure this out for the most part.
All sensors working and detecting. The only inconvenience now is: If a beam is interrupted, the serial monitor is continuously displaying the "Broken" message. In my first code it would only print the message once.
int SENSORPIN [12] = {2,3,4,5,6,7,8,9,10,11,12,13};
int sensorState = 0, lastState= 0;         // variable for reading the pushbutton status
  for (int eachSensor = 0; eachSensor <= 11; eachSensor++) {
 pinMode(SENSORPIN [eachSensor] ,INPUT_PULLUP);
  // check the sensor array.
  for(int s = 0; s <= 11; s++) {
    sensorState = digitalRead(SENSORPIN[s]);
    Serial.println("Broken ,");
  lastState = sensorState;}
You have to have multiple lastState variables, one for each pin. It is best to use and array here.
Hi 6v6gt,
Can you please give me a hint on how to do this? This is literally the first time i am using Arduino
Of course (untested) :
int SENSORPIN [12] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13};
int lastState[ 12 ] = { 0 } ;
int sensorState = 0 ;        // variable for reading the pushbutton status
    pinMode(SENSORPIN [eachSensor] , INPUT_PULLUP);
  //  digitalWrite(SENSORPIN, HIGH); // turn on the pullup // redundant
  for (int s = 0; s <= 11; s++) {   // please use < 12 instead of <= 11
     // yes, it has the same effect but much nicer to look at when the array
     // is specified as arrayXX[ 12 ]
		// this isn't doing much
    if (!sensorState && lastState[ s ] ) {
    lastState[ s ] = sensorState;
Rather than having 12 as a Magic Number appearing in multiple places, you could (should?) make it a constant; eg,
#define NUMBER_OF_SENSORS 12
int SENSORPIN [NUMBER_OF_SENSORS] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13};
int lastState [NUMBER_OF_SENSORS] = { 0 } ;
  for (int eachSensor = 0; eachSensor < NUMBER_OF_SENSORS; eachSensor++) {
  for (int s = 0; s < NUMBER_OF_SENSORS; s++) {
EDIT
Note also that it's conventional to reserve ALL UPPERCASE names for #defines - so:
int sensor_pin[NUMBER_OF_SENSORS] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13};
    pinMode( sensor_pin[eachSensor] , INPUT_PULLUP );
  //  digitalWrite( sensor_pin, HIGH ); // turn on the pullup // redundant
Thank you so much! It works :slightly_smiling_face:
Thank you Awneil! Tested your suggestion and this also works as intended :pray:
functionally it's identical to @6v6gt's - just a couple of style changes.
