IR decoding code stop working
Hi guys, i'm working on a project to control a peltier cell via PID using a IR remote receiver. But I have a problem decoding IR code. After a few loops the library stops to identify the codes and responds with the following message:
Attempting NEC decode:
Protocol failed because number of raw samples wrong.
With the example code all works fine.
The sensor is an ax-1838HS https://arduino-info.wikispaces.com/file/view/IR-Receiver-AX-1838HS.pdf/264668680/IR-Receiver-AX-1838HS.pdf
Can you help me ?
#include <IRLib.h>
#include <IRLibMatch.h>
#include <IRLibRData.h>
#include <IRLibTimer.h>
/*#include <IRremote.h>
//#include <IRremoteInt - Copia.h>
#include <IRremoteInt.h>*/
//#include <MemoryFree.h>
#include <CountUpDownTimer.h> //https://github.com/AndrewMascolo/CountUpDownTimer
#include <Wire.h>
#include <PID_v1.h>
//#include <dht11.h>
#include "DHT.h"
#if defined(ARDUINO) && ARDUINO >= 100
#define printByte(args)  write(args);
#else
#define printByte(args)  print(args,BYTE);
#endif
//DHT11 settings
//dht11 DHT;
//#define DHT11_PIN 7
#define DHTPIN 7     // what digital pin we're connected to
#define DHTTYPE DHT11   // DHT 11
DHT dht(DHTPIN, DHTTYPE);
//IR remote
#define RECV_PIN  3
IRrecv My_Receiver(RECV_PIN);
IRdecodeNEC My_Decoder;
unsigned int Buffer[100];
IBT-2 Motor Control Board driven by Arduino.
Speed and direction controlled by a potentiometer attached to analog input 0.
One side pin of the potentiometer (either one) to ground; the other side pin to +5V
Connection to the IBT-2 board:
IBT-2 pin 1 (RPWM) to Arduino pin 10(PWM)
IBT-2 pin 2 (LPWM) to Arduino pin 11(PWM)
IBT-2 pins 3 (R_EN), 4 (L_EN) to Arduino 5V pin
IBT-2 pins 7 (VCC),(GND), 5 (R_IS) and 6 (L_IS) not connected
#define RPWM_Output  10 // Arduino PWM output pin 10; connect to IBT-2 pin 1 (RPWM)
#define LPWM_Output  9 // Arduino PWM output pin 9; connect to IBT-2 pin 2 (LPWM)
#define FAN_RELAY  8 // Relay to control fan switch ON/OFF connected to pin 8
#define FAN1  5   // PWM pin to control FAN1
#define FAN2  11 // PWM pin to control FAN2
//Timer management
CountUpDownTimer T(DOWN);
unsigned int Timer_Duration = 480; // runtime in minutes
boolean TimerPaused = false;
uint8_t check[8] = {0x0, 0x1, 0x3, 0x16, 0x1c, 0x8, 0x0};
uint8_t temperature[8] = //icon for termometer
  B00100,
  B01010,
  B01010,
  B01110,
  B01110,
  B11111,
  B11111,
  B01110
uint8_t humidity[8] = //icon for water droplet
  B00100,
  B00100,
  B01010,
  B01010,
  B10001,
  B10001,
  B10001,
  B01110,
uint8_t play[8] = {  //char for play
  0b11000,
  0b11100,
  0b11110,
  0b11111,
  0b11111,
  0b11110,
  0b11100,
  0b11000
uint8_t pause[8] = { //char for pause
  0b11011,
  0b11011,
  0b11011,
  0b11011,
  0b11011,
  0b11011,
  0b11011,
  0b11011
//byte bell[8] = { B00100, B01010, B01010, B01010, B10001, B11111, B00100, B00000 };
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
int  Humidity;
//Specify the links and initial tuning parameters
const int Kp = 2, Ki = 5, Kd = 3;
//const int Kp = 50, Ki = 100, Kd = 10;
//double Kp=1, Ki=0.05, Kd=0.25;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, AUTOMATIC);
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
  pinMode(RPWM_Output, OUTPUT);
  pinMode(LPWM_Output, OUTPUT);
  pinMode(FAN_RELAY, OUTPUT);
  pinMode(FAN1, OUTPUT);
  pinMode(FAN2, OUTPUT);
  lcd.init();                      // initialize the lcd
  lcd.backlight();
  lcd.createChar(1, temperature);
  lcd.createChar(2, humidity);
  lcd.createChar(3, check);
  lcd.createChar(4, play);
  lcd.createChar(5, pause);
  //set and start timer
  T.SetTimer(Timer_Duration * 60);
  T.StartTimer();
  //irrecv.enableIRIn(); // Start the receiver
  //irrecv.blink13(false);
  My_Receiver.enableIRIn(); // Start the receiver
  My_Decoder.UseExtnBuf(Buffer);
  Setpoint = 28;
  // Set PID Output Range
  myPID.SetOutputLimits(-255, 255);  // 1-255 = reverse,  -255 -1 =forward
  myPID.SetMode(AUTOMATIC);
  // Enable DHT reading
  dht.begin();
  T.Timer(); // run the timer
  Input = dht.readTemperature();
  Humidity = dht.readHumidity();
  // Check if any reads failed and exit early (to try again).
  if (isnan(Input) ) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  digitalClockDisplay();
  lcd.setCursor(12, 0);
  if (TimerPaused == true)
    lcd.printByte(5);
    lcd.printByte(4);
  lcd.setCursor(0, 1);
  lcd.printByte(1);
  lcd.print(int(Input));
  lcd.setCursor(4, 1);
  lcd.printByte(2);
  lcd.print(Humidity);
  lcd.setCursor(8, 1);
  lcd.printByte(3);
  lcd.print(int(Setpoint));
  if (My_Receiver.GetResults(&My_Decoder)) {
    //Restart the receiver so it can be capturing another code
    //while we are working on decoding this one.
    My_Receiver.resume();
    My_Decoder.decode();
    Serial.println(My_Decoder.value, HEX);
    switch (My_Decoder.value)
      case 0xFF906F:
        Setpoint++;
      case 0xFFA857:
        Setpoint--;
      case 0xFFC23D:
        Timer_Duration+=10;
      case  0xFF02FD:
        if (Timer_Duration >10)
          Timer_Duration-=10;
      case 0xFF22DD:
          T.StartTimer();
          TimerPaused = true;
          T.StopTimer();
  myPID.Compute();
  if (Output < -41 )
    digitalWrite(LPWM_Output, 0);
    analogWrite(RPWM_Output, abs(Output));
    analogWrite(FAN1, abs(Output));
    analogWrite(FAN2, abs(Output));
  if (Output > 41 )
    digitalWrite(LPWM_Output, abs(Output));
    analogWrite(RPWM_Output, 0);
  if ((Output > -40 && Output < 40) || (T.ShowMinutes() == 0 && T.ShowHours() == 0)  )
    digitalWrite(FAN_RELAY, LOW);
    digitalWrite(FAN_RELAY, HIGH);
  //analogWrite(FAN1, abs(Output));
  //analogWrite(FAN2, abs(Output));
  Serial.print (Setpoint);
  Serial.print ("\t");
  Serial.print (Input);
  Serial.print("\t");
  Serial.print(Humidity);
  Serial.print("\t");
  Serial.println(Output);
  //Serial.print("\t");
  //Serial.println(Timer_Duration);
  delay(200);
void printDigits(byte digits) {
  // utility function for digital clock display: prints preceding colon and leading 0
  if (digits < 10)
    lcd.print('0');
  lcd.print(digits, DEC);
void digitalClockDisplay() {
  lcd.home();
  // digital clock display of current time
  printDigits(T.ShowHours());
  lcd.print(":");
  printDigits(T.ShowMinutes());
  lcd.print("/");
  printDigits(int(Timer_Duration / 60));
  lcd.print(":");
  printDigits(Timer_Duration % 60 );
It's unlikely to be a problem with the IR receiver.
I see you've commented out the 'IRremote' library and replaced it with this:-
#include <IRLib.h>
Is it your own library, based on IRremote, or another third-party library?
I switched from Irlib to IRremote, as suggested, but weird thing happens... After few loops, in which the decoding works fine, now I obtain errors like these:
20FE4DBB
Unknown encoding: 20FE4DBB (32 bits)
Raw (68): 29718 3600 -1700 250 -200 250 -200 250 -200 250 -200 250 -200 200 -200 250 -200 250 -200 250 -650 250 -650 200 -650 250 -650 250 -650 200 -650 250 -650 250 -650 250 -60
E5CFBD7F
Unknown encoding: E5CFBD7F (32 bits)
Raw (68): -20462 3550 -1750 200 -250 200 -250 200 -200 250 -200 250 -200 250 -200 200 -250 250 -200 200 -650 250 -650 250 -650 200 -650 250 -650 250 -650 200 -650 250 -650 250 -6
Problem solved ! There is a conflict between the pin I used to pilot the fan in pwm and the TIMER2 used by IR library to read data. I simply changed the pin used to control the fan from 11 to 6 and now the remote works. This link was very useful http://blog.oscarliang.net/arduino-timer-and-interrupt-tutorial/
