I am Farhan.I am new in arduino .Recently I have planned to make a line following robot car.But I faced various problems.Most of the problems I already solved.But when I came to to the part of IR led and photodiode .I tried to find a code and a sketch .I got one,but it wasn't working.Here is that code:
int pd=2; //Photodiode to digital pin 2
int buzz=13; //piezo buzzer to digital pin 13
int senRead=0; //Readings from sensor to analog pin 0
int limit=850; //Threshold range of an obstacle
pinMode(pd,OUTPUT);
pinMode(buzz,OUTPUT);
digitalWrite(pd,HIGH); //supply 5 volts to photodiode
digitalWrite(buzz,LOW); //set the buzzer in off mode (initial condition)
Serial.begin(9600); //setting serial monitor at a default baund rate of 9600
int val=analogRead(senRead); //variable to store values from the photodiode
Serial.println(val); // prints the values from the sensor in serial monitor
if(val <= limit) //If obstacle is nearer than the Threshold range
digitalWrite(buzz,HIGH); // Buzzer will be in ON state
delay(20);
else if(val > limit) //If obstacle is not in Threshold range
digitalWrite(buzz,LOW); //Buzzer will be in OFF state
delay(20);
And my sketch is below:
I wish someone will help me....Thanks
