IR-receiver receives "garbage"
I’ve got a problem here. I have tried to get my IR-receiver working. i have the sensor and remote control. I used the code
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  pinMode(3, OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results))
    Serial.println(results.value, HEX);
    delay(100);
    irrecv.resume(); // Receive the next value
  if(results.value == 0xFF30CF)
    digitalWrite(3, HIGH);
  else if (results.value == 0xFFA25D)
    digitalWrite(3, LOW);
Code works great except the thing that after every few second there is three garbage-values that my IR-sensor reads. And when they are displayed none of my inputs are received. When i press button after the three values have shown it works great! I don’t understand what are those three codes
3C573D9C
43B23900
6860065
it gives something like these in every few seconds. And they are diffrent every time!
Okay! I managed to pinpoint my problem, but i dont get it :D. Whenever i turn on my TV the garbage stops and program works perfectly. After i shut it down it starts again! How this is possible? I went to my bedroom with arduino and the garbage was still there but after i turn on TV it stops again. :open_mouth:
Wow, that sounds pretty ‘X-files’! :wink:
Is it an old fashion tv or a flatscreen?
Remote controls make use of IR leds (usually around 950nm, don’t know what you’re detector is like) so it can’t really be from the tv since it only uses a reciever (detector)… Do you have any consoles conected to you tv? (Wii, other stuff that might use IR radiation as remote control?)
Although it sounds pretty darn weird that you encounter the same phenomenon in a room without tv (doors closed?)
How many times have you tried this? (all experimentation should be statistically evaluated :wink: )
