i am using arduino uno r3 , l293d ic nd ir remote nd sensor(vs1838b) i am new to electronics i have created a circuit in which when i press [2 ->frwd ,8->bckwrd ,4->left ,6->right ,5->stop]. my circuit is working absoultely fine but when i press any button out of [2,4,6,8] nd motor starts running my ir reciever starts showing random number in serial monitor and does not take any input from remote i have to disconnect the power supply to reset it i am using 2 motors
my code-:
#include <IRremote.h>
int ir=11;
int enA=3;
int enB=10;
int i1=4;
int i2=5;
int i3=9;
int i4=8;
String z;
IrReceiver.begin(ir,ENABLE_LED_FEEDBACK);
pinMode(enA,OUTPUT);
pinMode(enB,OUTPUT);
pinMode(i1,OUTPUT);
pinMode(i2,OUTPUT);
pinMode(i3,OUTPUT);
pinMode(i4,OUTPUT);
if(IrReceiver.decode())
Serial.println(IrReceiver.decodedIRData.decodedRawData,HEX);
switch(IrReceiver.decodedIRData.decodedRawData){
case 0xE41B7F80:
digitalWrite(enA,HIGH);
digitalWrite(enB,HIGH);
digitalWrite(i1,HIGH);
digitalWrite(i2,LOW);
digitalWrite(i3,HIGH);
digitalWrite(i4,LOW);
case 0x1FEF00F:
analogWrite(enA,255);
analogWrite(enB,255);
digitalWrite(i1,LOW);
digitalWrite(i2,HIGH);
digitalWrite(i3,LOW);
digitalWrite(i4,HIGH);
case 0x1FE30CF:
case 0x1FE708F:
case 0xF20D7F80:
IrReceiver.resume();
here is the picture of circuit its working on simulator but not working in real life model and everything is exact same i have not used any resistors or capacitors.
