IR remote erratic in operation?
The attached sketch is to control a neopixel strip using an IR remote control but does not work reliably. the remote keypad should decrease/inrease red using buttons 1 and 3, the same with Green and Blue using 4/6 and 7/8, and turn on full brightness using 2,5 and 7. However sometimes nothing happens at all when pressing the remote, other times it seems to be ok. I just can't fathom what's wrong, any ideas? I've tried using an older IRremote library but no success, if I have to use the latest IRremote library what do I need to change in my code. Thanks for any guidance, Bob.
// Neopixel individual colour adjustment by IR remote control Dec 25th 2022
#include <IRremote.h>
#define RECEIVER_PIN 8          // define the connections
IRrecv receiver(RECEIVER_PIN);  // create a receiver object of the IRrecv class
decode_results results;         // create a results object of the decode_results class
unsigned long key_value = 0;
#define PIN 6  // pin connected to the NeoPixels?
// Set the light output to a low level white
int redValue = 10;
int greenValue = 10;
int blueValue = 10;
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 26
/*  When setting up the NeoPixel library, we tell it how many pixels,
    and which pin to use to send signals. Note that for older NeoPixel
    strips you might need to change the third parameter -- see the
    Strandtest example for more information on possible values.
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 5  // Time (in milliseconds) to pause between pixels
  receiver.enableIRIn();   // enable the receiver
  receiver.blink13(true);  // enable blinking of the built-in LED when an IR signal is received
  pixels.begin();  // INITIALIZE NeoPixel strip object (REQUIRED)
  if (receiver.decode(&results)) {
    if (results.value == 0xFFFFFFFF) {
      results.value = key_value;
    switch (results.value) {
      case 0xFF6897:  //1
        redValue = redValue - 10;
        if (redValue < 0) { redValue = 0; };
      case 0xFF9867:  //
          redValue = 250;
      case 0xFFB04F:  //3
        redValue = redValue + 10;
        if (redValue > 250) { redValue = 250; };
      case 0xFF30CF:  //4
        greenValue = greenValue - 10;
        if (greenValue < 0) { greenValue = 0; };
      case 0xFF18E7:  //5
          greenValue = 250;
      case 0xFF7A85:  //6
        greenValue = greenValue + 10;
        if (greenValue > 250) { greenValue = 250; };
      case 0xFF10EF:  //7
        blueValue = blueValue - 10;
        if (blueValue < 0) { blueValue = 0; };
      case 0xFF38C7:  //
          blueValue = 250;
      case 0xFF5AA5:  //9
        blueValue = blueValue + 10;
        if (blueValue > 250) { blueValue = 250; };
    //delay(250);
    key_value = results.value;
    receiver.resume();
  delay(200);
  // serial print to aid debugging
  Serial.print("Red ");
  Serial.print(redValue);
  Serial.print("   Green ");
  Serial.print(greenValue);
  Serial.print("   Blue ");
  Serial.println(blueValue);
  delay(10);
  // pixels.clear(); // Set all pixel colors to 'off'
  // The first NeoPixel in a strand is #0, second is 1, all the way up
  // to the count of pixels minus one.
  for (int i = 0; i < NUMPIXELS; i++) {  // For each pixel...
    // pixels.Color{RGB values, from 0,0,0 up to 255,255,255}
    pixels.setPixelColor(i, pixels.Color(redValue, greenValue, blueValue));
    pixels.show();  // Send the updated pixel colors to the hardware.
    delay(DELAYVAL);  // Pause before next pass through loop
The pixel library turns off interrupts.
When off, your IR section will not operate properly each and every time.
You can modify the pixel code to check for IR codes.
There are several posts on in the forum showing how.
Also, Adafruit has a 3 part example how to do pseudo multil tasting.
Thanks Larry, I guessed something like this might be going on but after doing a bit of searching around on here I'm still none the wiser as to how to solve the problem, can anyone point me in the right direction?
This was covered a while back.
Assumption: there is a pixel animation running; the user sends a new command to change to a different pixel animation.
There are two basic parts,
  • If a interrupt is received (from an IR code), all the pixels are made yellow.
  • When you see the pixels turn yellow, you send the same IR command, a 2nd time, which then starts the new animation.
//IR_remote_and_Neo_Pixels.ino
//A program that integrates an IR remote with a WS2812 LED strip.
//The 1st button press on the remote stops the current animation running on the LED strip.
//All LEDs on the strip turn Yellow for 2 seconds while waiting for a 2nd remote button to be pressed.
//A 2nd button press is evaluated and the new animation associated to the button starts running.
//No 2nd button press results in the current animation starting again, this happens after a 2
//second time-out.
// By:                  LarryD
// Version   YY/MM/DD   Description
// 1.00      19 10 01   working sketch; you have 2 seconds after the 1st button push for the 2nd push
#define DECODE_NEC
#include <Arduino.h>
#include <IRremote.h>                  //version 3.3.0  (using a TSOP4838 receiver in this project)
//adjust to give the most pleasing results
#define NUM_PIXELS                 15  //Rainbow gives ~520ma (i.e. one string of 31 LEDs)
#define KnightRiderSpeed           28  //
#define inOutOutInDelay            48  //
#define Cycles                     1   //
#define Width                      2   //
#define rainbowSpeed               6   //
#define zylonSpeed                 28  //used in Zylon
#define theaterChaseDelay          100 //used with theaterChase
#define rainbowDelay               20  //used with rainbow
#define colorWipeDelay             50  //used with colorWipe
//increase to get narrow spots, decrease to get wider spots
#define FOCUS                      65
//max LED brightness (1 to 255) – start with low values!
//high brightness requires a more power
#define BRIGHTNESS                 255
//decrease to speed up, increase to slow down (it's not a delay actually)
#define DELAY                      1500
//we have 3 colour spots (reg, green, blue) oscillating along the strip with different speeds
float spdr, spdg, spdb;
float offset;
int pos                          = 0;   //used in Zylon
int dir                          = 1;   //used in Zylon
const byte IR_RECEIVE_PIN        = 2;   //must use pin 2
const byte interruptPin          = 2;   //must use pin 2
const byte feedBackLED           = 8;
const byte PixelPin              = 12;
const byte buzzerPin             = 13;
byte mode                        = 12;  //the current display mode
volatile byte IRflag             = 0;
volatile unsigned long lastMillis;
//17 button IR remote
//https://store.qkits.com/media/catalog/product/cache/de6f4998e28d20e4664ef81588e1bf0a/i/r/ir-transmitter-17-button_1.jpg
const byte buttonCode[18] =
  0x46, 0x44, 0x40,
  0x43, 0x15, 0x00,                     //0x00 is not defined (used as a place holder only)
  0x16, 0x19, 0x0D,
  0x0C, 0x18, 0x5E,
  0x08, 0x1C, 0x5A,
  0x42, 0x52, 0x4A
}; //END of buttonCode Array
const byte ASCIIcode[18] =
  // ^   <     OK (LEDs OFF)
  0x5E, 0x3F, 0x3C,
  // >    v    nul
  0x3E, 0x76, 0x00,                     //0x00 is not defined (used as a place holder only)
  // 1    2    3
  0x31, 0x32, 0x33,
  // 4    5    6
  0x34, 0x35, 0x36,
  // 7    8    9
  0x37, 0x38, 0x39,
  // *    0    #
  0x3A, 0x30, 0x3B
}; //END of ASCIIcode Array
//define the Neo-Pixel strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_PIXELS, PixelPin, NEO_GRB + NEO_KHZ800);
//                                       s e t u p ( )
  //Serial.begin(115200);
  pinMode(buzzerPin, OUTPUT);
  pinMode(feedBackLED, OUTPUT);
  pinMode(interruptPin, INPUT);
  IrReceiver.begin(IR_RECEIVE_PIN);
  IrReceiver.stop();
  //ignore a queued interrupt (UNO pin D02)
  EIFR = 1;
  //or
  //EIFR = bit (INTF0);  //clear flag for interrupt 0
  attachInterrupt(digitalPinToInterrupt(interruptPin), firstIRcode, HIGH);
  strip.begin();
  //Initialize all pixels to 'OFF'
  clearStrip();
  strip.show();
  //initialize pseudo-random number generator with some random value
  randomSeed(analogRead(A0));
  // assign random speed to each spot
  spdr = 1.0 + random(200) / 100.0;
  spdg = 1.0 + random(200) / 100.0;
  spdb = 1.0 + random(200) / 100.0;
  // set random offset so spots start in random locations
  offset = random(10000) / 100.0;
} //END of setup()
//                                        l o o p ( )
  //if we are not waiting for IR remote action, run animations
  if (IRflag == 0)
    checkStateMachine();
  //check for IR remote action
  checkIRinterrupt();
} //END of loop()
//                                  f i r s t I R c o d e ( )         (ISR, TSOP4838 1st press)
void firstIRcode()
  //set 1st code detected
  IRflag = 1;
  //restart the time-out TIMER
  lastMillis = millis();
} //END of  firstIRcode()
//                            c h e c k I R i n t e r r u p t ( )
void checkIRinterrupt()
  //is there an IR remote request for attention ?
  if(IRflag == 0)
    //no
    return;
  //when the 1st IR code is detected, has the time-out TIMER expired ?
  if (IRflag == 1 && millis() - lastMillis >= 200)
    //disable the ISR
    detachInterrupt(digitalPinToInterrupt(interruptPin));
    digitalWrite(feedBackLED, HIGH);
    //setup 2nd IR coding
    IRflag = 2;
    //enable IR decoding
    IrReceiver.start();
    IrReceiver.resume();
    //after the 1st IR remote button press, all the pixels are turn to YELLOW
    //this will let the user know they can now select the 'new' desired animation with a 2nd button press
    for (int count = 0; count < NUM_PIXELS; count++)
      strip.setPixelColor(count, 0x7F3F00);  //yellow
    strip.show();
  } //END of if (IRflag == 1 && millis() - lastMillis >= 200)
  //if we are waiting for the 2nd IR code, has this time-out TIMER expired ?
  if (IRflag == 2 && millis() - lastMillis >= 2000)
    IrReceiver.decode();
    byte byteRX = IrReceiver.decodedIRData.command;
    clearStrip();
    EIFR = 1;
    //or
    //finished with the 2nd IR code, enable the ISR
    IRflag = 0;
    IrReceiver.stop();
    digitalWrite(feedBackLED, LOW);
  //if we are waiting for the 2nd IR code, have we received it ?
  if (IRflag == 2 && IrReceiver.decode())
    //Make a buzzer sound
    IrReceiver.stop();
    tone(buzzerPin, 4000, 10);
    delay(50);
    IrReceiver.start();
    //print a short summary of received data
    //IrReceiver.printIRResultShort(&Serial);
    //convert the button code to it's ASCII code.
    if (byteRX)
      //Scan through the buttonCode Array.
      for (int i = 0; i < 18; i++)
        if (buttonCode[i] == byteRX)
          //Serial.println(char(ASCIIcode[i])); //get the ASCII code
          mode = ASCIIcode[i] - '0';
          //keypad arrow buttons default to button 1 press
          if (mode > 12)
            //default
            mode = 1;
          //We found it, no need to continue looking.
    } //END of if(byteRX)
    clearStrip();
    EIFR = 1;
    //or
    //we are finished with decoding the 2nd IR receive code, enable the ISR
    IRflag = 0;
    IrReceiver.stop();
  } //END of if (IRflag == 2 && IrReceiver.decode())
} //END of  checkIR()
//                            c h e c k S t a t e M a c h i n e ( )
void checkStateMachine()
  //check machine state and run animations accordingly
  switch (mode)
    case 0:
        //All LEDs white (0x7F7F7F draws ~700mA for 31 LEDs ~22mA per pixel X 5 = 3.5A)
        //All LEDs white (0x5F5F5F draws ~520mA for 31 LEDs ~16mA per pixel X 5 = 2.6A)
        strip.setPixelColor(count, 0x5F5F5F);
      strip.show();
      checkIRinterrupt();
    //END case stateStart:
    case 1:
      //All LEDs frozen draws ~520mA for 31 LEDs ~16mA per pixel X 5 = 2.6A)
      rainbowCycle(rainbowSpeed, 1);
      checkIRinterrupt();
    //END case stateRainbow:
    case 2:
      rainbow(rainbowDelay);
      if (IRflag)
    //END case stateZylonRed:
    case 3:
      //All LEDs frozen draws ~350mA for 31 LEDs ~11mA per pixel X 5 = 1.75A)
      XMAS(300);
      checkIRinterrupt();
    case 4:
      twoSides(0x0000FF); //Blue
      checkIRinterrupt();
      if (IRflag)
      twoSides(0x7F7F00); //Yellow
      checkIRinterrupt();
      if (IRflag)
      twoSides(0x7F0010); //Pink
      checkIRinterrupt();
      if (IRflag)
      twoSides(0x00FF00); //Green
      checkIRinterrupt();
      if (IRflag)
      twoSides(0x5F5F5F); //White
      checkIRinterrupt();
      if (IRflag)
      twoSides(0xFF0000); //Red
      checkIRinterrupt();
      if (IRflag)
      twoSides(0x7F007F); //Purple
      checkIRinterrupt();
    //END case color twoSides:
    case 5:
      middleOut(0x0000FF); //Blue
      checkIRinterrupt();
      if (IRflag)
      middleOut(0x5F5F5F); //White
      checkIRinterrupt();
      if (IRflag)
      middleOut(0x7F0010); //Pink
      checkIRinterrupt();
      if (IRflag)
      middleOut(0x00FF00); //Green
      checkIRinterrupt();
      if (IRflag)
      middleOut(0xFF0000); //Red
      checkIRinterrupt();
      if (IRflag)
      middleOut(0x7F7F00); //Yellow
      checkIRinterrupt();
      if (IRflag)
      middleOut(0x7F007F); //Purple
      checkIRinterrupt();
    //END case color middleOut
    case 6:
      knightRider(Cycles, KnightRiderSpeed, Width, 0x0000FF); // Cycles, Speed, Width, RGB Colour (blue)
      checkIRinterrupt();
      if (IRflag)
      knightRider(Cycles, KnightRiderSpeed, Width, 0x5F5F5F); // Cycles, Speed, Width, RGB Colour (white)
      checkIRinterrupt();
      if (IRflag)
      knightRider(Cycles, KnightRiderSpeed, Width, 0x00FF00); // Cycles, Speed, Width, RGB Colour (green)
      checkIRinterrupt();
      if (IRflag)
      knightRider(Cycles, KnightRiderSpeed, Width, 0x7F0010); // Cycles, Speed, Width, RGB Colour (Pink)
      checkIRinterrupt();
      if (IRflag)
      knightRider(Cycles, KnightRiderSpeed, Width, 0xFFFF00); // Cycles, Speed, Width, RGB Colour (yellow)
      checkIRinterrupt();
      if (IRflag)
      knightRider(Cycles, KnightRiderSpeed, Width, 0xFF0000); // Cycles, Speed, Width, RGB Colour (red)
      checkIRinterrupt();
      if (IRflag)
      knightRider(Cycles, KnightRiderSpeed, Width, 0xFF00FF); // Cycles, Speed, Width, RGB Colour (purple)
      checkIRinterrupt();
    //END case Blue twoSides:
    case 7:
      theaterChase(strip.Color(0x5F, 0x5F, 0x5F), theaterChaseDelay); // White
      checkIRinterrupt();
      if (IRflag)
      theaterChase(strip.Color(0x7F, 0, 0), theaterChaseDelay); // Red
      checkIRinterrupt();
      if (IRflag)
      theaterChase(strip.Color( 0, 0, 0x7F), theaterChaseDelay); // Blue
      checkIRinterrupt();
      if (IRflag)
      theaterChase(strip.Color( 0xFF, 0xFF, 0), theaterChaseDelay); // Yellow
      checkIRinterrupt();
      if (IRflag)
      theaterChase(strip.Color( 0x7F, 0, 0x10), theaterChaseDelay); // Pink
      checkIRinterrupt();
      if (IRflag)
      theaterChase(strip.Color( 0, 0x7F, 0), theaterChaseDelay); // Green
      checkIRinterrupt();
    //END case theaterChase:
    case 8:
      theaterChaseRainbow(theaterChaseDelay);
      checkIRinterrupt();
    //END case theaterChaseRainbow:
    case 9:
      colorWipe(strip.Color(0xFF, 0, 0), colorWipeDelay);       //Red
      colorWipe(strip.Color(0x5F, 0x5F, 0x5F), colorWipeDelay); //White
      colorWipe(strip.Color(0x7F, 0, 0x10), colorWipeDelay);    //Pink
      colorWipe(strip.Color(0, 0xFF, 0), colorWipeDelay);       //Green
      colorWipe(strip.Color(0, 0, 0xFF), colorWipeDelay);       //Blue
      colorWipe(strip.Color(0x7F, 0x7F, 0), colorWipeDelay);    //Yellow
      colorWipe(strip.Color(0x7F, 0, 0x7F), colorWipeDelay);    //Magenta
      checkIRinterrupt();
    //END case stateKnightRiderBlue:
    case 10:
      knightRider(Cycles, KnightRiderSpeed, Width, 0x0000FF); //Cycles, Speed, Width, RGB Color (Blue)
      checkIRinterrupt();
    //END case case knightRider Blue:
    case 11:
      ZylonRed();
      if (pos - 1 < 0)
        checkIRinterrupt();
        if (IRflag)
    //END case state ZylonRed:
    case 12:
      clearStrip();
      checkIRinterrupt();
      //END case LEDs OFF:
  } //END of switch(mode)
} //END of checkStateMachine()
//                                  k n i g h t R i d e r ( )
// Cycles - one cycle is scanning through all pixels left then right (or right then left)
// Speed - how fast one cycle is (32 with 16 pixels is default KnightRider speed)
// Width - how wide the trail effect is on the fading out LEDs.  The original display used
//         light bulbs, so they have a persistence when turning off.  This creates a trail.
//         Effective range is 2 - 8, 4 is default for 16 pixels.  Play with this.
// Colour - 32-bit packed RGB colour value.  All pixels will be this colour.
// knightRider(cycles, speed, width, colour);
void knightRider(uint16_t cycles, uint16_t speed, uint8_t width, uint32_t color)
  uint32_t old_val[NUM_PIXELS]; // up to 256 lights!
  for (unsigned int i = 0; i < cycles; i++)
    for (int count = 1; count < NUM_PIXELS; count++)
      checkIRinterrupt();
      if (IRflag)
        return;
      strip.setPixelColor(count, color);
      old_val[count] = color;
      for (int x = count; x > 0; x--)
        old_val[x - 1] = dimColor(old_val[x - 1], width);
        strip.setPixelColor(x - 1, old_val[x - 1]);
      strip.show();
      delay(speed);
    for (int count = NUM_PIXELS - 1; count >= 0; count--)
      checkIRinterrupt();
      if (IRflag)
        return;
      for (int x = count; x <= NUM_PIXELS ; x++)
        strip.setPixelColor(x + 1, old_val[x + 1]);
      strip.show();
      delay(speed);
} //END of  knightRider()
//                                  c l e a r S t r i p ( )
void clearStrip()
  for ( int i = 0; i < NUM_PIXELS; i++)
    strip.setPixelColor(i, 0x000000);
    strip.show();
}  //END of  clearStrip()
//                                    d i m C o l o r ( )
uint32_t dimColor(uint32_t color, uint8_t width)
  return (((color & 0xFF0000) / width) & 0xFF0000) + (((color & 0x00FF00) / width) & 0x00FF00) + (((color & 0x0000FF) / width) & 0x0000FF);
} //END of  dimColor()
//                                r a i n b o w C y c l e ( )
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait, unsigned int repeatNumber)
  unsigned int i, j;
  for (j = 0; j <= 255 * repeatNumber; j++)
    checkIRinterrupt();
    if (IRflag)
      return;
    // repeatNumber of cycles of all colours on wheel
    for (i = 0; i < strip.numPixels(); i++)
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
} //END of  rainbowCycle()
//                                       W h e e l ( )
// Input a value 0 to 255 to get a colour value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos)
  WheelPos = 255 - WheelPos;
  if (WheelPos < 85)
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  else if (WheelPos < 170)
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
    WheelPos -= 170;
    return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} //END of  Wheel()
//                                t h e a t e r C h a s e ( )
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait)
  for (int j = 0; j < 10; j++) //do 10 cycles of chasing
    checkIRinterrupt();
    if (IRflag)
      return;
    for (int q = 0; q < 3; q++)
      for (int i = 0; i < strip.numPixels(); i = i + 3)
        strip.setPixelColor(i + q, c);  //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i + q, 0);      //turn every third pixel off
} //END of  theaterChase()
//                        t h e a t e r C h a s e R a i n b o w ( )
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait)
  for (int j = 0; j < 256; j = j + 10)   // cycle all 256 colours in the wheel
    checkIRinterrupt();
    if (IRflag)
      return;
        strip.setPixelColor(i + q, Wheel( (i + j) % 255)); //turn every third pixel on
      strip.show();
      delay(wait);
} //END of  theaterChaseRainbow()
//                                     r a i n b o w ( )
void rainbow(uint8_t wait)
  uint16_t i, j;
  for (j = 0; j < 256; j++)
    checkIRinterrupt();
    if (IRflag)
      return;
      strip.setPixelColor(i, Wheel((i + j) & 255));
    strip.show();
    delay(wait);
} //END of  rainbow()
//                                    Z y l o n R e d ( )
void ZylonRed()
  int j;
  checkIRinterrupt();
  if (IRflag)
    return;
  // Draw 5 pixels centered on pos.  setPixelColor() will clip any
  // pixels off the ends of the strip, we don't need to watch for that.
  strip.setPixelColor(pos - 2, 0x100000); // Dark red
  strip.setPixelColor(pos - 1, 0x400000); // Medium red
  strip.setPixelColor(pos    , 0xFF0000); // Center pixel is brightest was 0xFF0000
  strip.setPixelColor(pos + 1, 0x400000); // Medium red
  strip.setPixelColor(pos + 2, 0x100000); // Dark red
  strip.show();
  delay(zylonSpeed);
  // Rather than being sneaky and erasing just the tail pixel,
  // it's easier to erase it all and draw a new one next time.
  for (j = -2; j <= 2; j++) strip.setPixelColor(pos + j, 0);
  // Bounce off ends of strip
  pos += dir;
  if (pos < 0)
    pos = 1;
    dir = -dir;
  else if (pos >= strip.numPixels())
    pos = strip.numPixels() - 2;
    dir = -dir;
} //END of  ZylonRed()
//                                   Z y l o n B l u e ( )
void ZylonBlue()
  int j;
  strip.setPixelColor(pos - 2, 0x000010); // Dark blue
  strip.setPixelColor(pos - 1, 0x000040); // Medium blue
  strip.setPixelColor(pos    , 0x0000FF); // Center pixel is brightest was 0xFF0000
  strip.setPixelColor(pos + 1, 0x000040); // Medium blue
  strip.setPixelColor(pos + 2, 0x000010); // Dark blue
  strip.show();
  delay(zylonSpeed);
  //Bounce off ends of strip
  pos += dir;
  if (pos < 0)
    pos = 1;
    dir = -dir;
    dir = -dir;
} //END of  ZylonBlue()
//                                    t w o S i d e s  ( )
void twoSides(uint32_t color)
  for (uint16_t i = 0; i <= (strip.numPixels() / 2); i++) // fill strip from sides to middle
    checkIRinterrupt();
    if (IRflag)
      return;
    strip.setPixelColor(i, color);
    strip.setPixelColor(strip.numPixels() - i, color);
    strip.show();
    delay(inOutOutInDelay);
  for (uint16_t i = 0; i <= (strip.numPixels() / 2); i++) // reverse
    checkIRinterrupt();
    if (IRflag)
      return;
    strip.setPixelColor(strip.numPixels() / 2 + i, strip.Color(0, 0, 0));
    strip.setPixelColor(strip.numPixels() / 2 - i, strip.Color(0, 0, 0));
    strip.show();
} //END of  twoSides()
//                                    m i d d l e O u t  ( )
void middleOut(uint32_t color)
  for (uint16_t i = 0; i <= (strip.numPixels() / 2); i++) // start from the middle, lighting an LED on each side
    checkIRinterrupt();
    if (IRflag)
      return;
    strip.setPixelColor(strip.numPixels() / 2 + i, color);
    strip.setPixelColor(strip.numPixels() / 2 - i, color);
    strip.show();
  for (uint16_t i = 0; i < (strip.numPixels() / 2); i++) // reverse
    checkIRinterrupt();
    if (IRflag)
      return;
    strip.setPixelColor(i, strip.Color(0, 0, 0));
    strip.setPixelColor(strip.numPixels() - i, strip.Color(0, 0, 0));
    strip.show();
} //END of   middleOut()
//                                   c o l o r W i p e ( )
//Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait)
  for (uint16_t i = 0; i < strip.numPixels(); i++)
    checkIRinterrupt();
    if (IRflag)
      return;
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
} //END of  colorWipe()
//                                        X M A S ( )
//https://github.com/smartynov/iotfun/blob/instructables/arduino/deco_lights/deco_lights.ino
//http://www.instructables.com/id/USB-NeoPixel-Deco-Lights-via-Digispark-ATtiny85/
void XMAS(int num)
  for (int x = 0; x < num; x++)
    checkIRinterrupt();
    if (IRflag)
      return;
    // use real time to recalculate position of each colour spot
    long ms = millis();
    // scale time to float value
    float m = offset + (float)ms / DELAY;
    // add some non-linearity
    m = m - 42.5 * cos(m / 552.0) - 6.5 * cos(m / 142.0);
    // recalculate position of each spot (measured on a scale of 0 to 1)
    float posr = 0.5 + 0.55 * sin(m * spdr);
    float posg = 0.5 + 0.55 * sin(m * spdg);
    float posb = 0.5 + 0.55 * sin(m * spdb);
    // now iterate over each pixel and calculate it's colour
    for (int i = 0; i < NUM_PIXELS; i++)
      // pixel position on a scale from 0.0 to 1.0
      float ppos = (float)i / NUM_PIXELS;
      // distance from this pixel to the center of each color spot
      float dr = ppos - posr;
      float dg = ppos - posg;
      float db = ppos - posb;
      // set each colour component from 0 to max BRIGHTNESS, according to Gaussian distribution
        i, constrain(BRIGHTNESS * myexp(-FOCUS * dr * dr), 0, BRIGHTNESS),
        constrain(BRIGHTNESS * myexp(-FOCUS * dg * dg), 0, BRIGHTNESS),
        constrain(BRIGHTNESS * myexp(-FOCUS * db * db), 0, BRIGHTNESS)
    //send data to LED strip
    strip.show();
} //END of  XMAS()
//                                       m y e x p ( )
// the real exponent function is too slow, so I created an approximation (only for x < 0)
float myexp(float x) // 1.12
  return (1.0 / (1.0 - (0.634 - 1.344 * x) * x));
} //END of myexp()
//                                E N D   O F   P R O G R A M
I'm def gonna look into that!
a7
It is Christmas after all, short bread cookies, turkey, glühwein, . . . .
Mmmm delicious kernel.
My hint is: RTFM, especially GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols
