IR remote problem
hi, i want to control a servo motor by using a IR remote.
here is my code:
#include <IRremote.h>
#include <Servo.h>
const int irReceiverPin = 30;
IRrecv irrecv(irReceiverPin);
decode_results result;
const int ledPin =  13;
Servo myservo;
  irrecv.enableIRIn();
  pinMode(ledPin, OUTPUT);
    myservo.attach(10);
void showIRProtocol(decode_results *result)
  Serial.print("Protocol: ");
  switch(result->decode_type) {
   case NEC:
     Serial.print("NEC");
   case SONY:
     Serial.print("SONY");
   case RC5:
     Serial.print("RC5");
   case RC6:
     Serial.print("RC6");
   default:
     Serial.print("Unknown encoding");
  Serial.print(", irCode: ");
  Serial.print(result->value, HEX);
  Serial.print(",  bits: ");
  Serial.println(result->bits);
  myservo.write(value);
  if (irrecv.decode(&result)) {
    showIRProtocol(&result);
    irrecv.resume();
  if(result.value == 0x490){
    digitalWrite(ledPin, HIGH);
    if(result.value == 0xC90){
    myservo.write(130);
from the serial monitor, i can get the same IR code and protocol name every time pressing the same button.
for example : Protocol : $ony, IR code : AAAA
however, once i add this myservo.attach(10); , the protocol become unknown and i cannot get the same IR code.
It becomes: Protocol: Unknown, IR code: FDSAS65
Protocol: Unknown, IR code: QWEW1451
and i delete the above code, the IRcode and protocol will back to normal.
pls help!!
The IR process requires a timer. So does the Servo library. Guess which timer they both use.
SoftwareServo uses a different timer.
