IR sensor detecting black
Hello I have an 4 IR avoidance module and it is detecting black. Can you tell me why is that. I want to make a line follower car whit these if I can. Please help
Thank you
Tell us more.
(Hint: we're not all interested in your timescales, your desires or your emotions.)
ok so I have an 4 IR avoidance module like this one: https://www.amazon.com/4-Channel-Infrared-Follower-Obstacle-Avoidance/dp/B07662JJF7
and even its detecting every object i put in front of it even if the object is black or white. Shouldn't it detect only the white object ?
Tell us more.
I just want to know why do the sensors detect black when they are IR and black should absorb the light
How do you know this?
(Also: IR is not always like visible. Instinct doesn't always work for you.)
If no light is reflected, "black" is detected by the fact that no light is reflected.
Because i have tested it whit a program that detects if an object is placed in front of the sensor. Whit every black object it detects it and i do not know why
Can't see it.
Sorry.
An object that appears black in visible light may reflect IR very well.
Or, you have a program error or wiring error.
  pinMode(SENSOR_PIN, INPUT);
  int state = digitalRead(SENSOR_PIN);
  if (state == LOW){
    Serial.println("The obstacle is present");
  }else{
    Serial.println("The obstacle is NOT present");
  delay(100);
Even is a dark room it sill detects it
Please post a complete, compilable program.
const int SENSOR_PIN = 2;
  if (state == LOW){
  }else{
  delay(100);
Now, a wiring diagram and specifications or links to specifications of all your hardware.
I made it easier to read:
  if (state == LOW) {
  else {
  delay(100);
Which message does it print?
the IR sensor module: https://www.amazon.com/4-Channel-Infrared-Follower-Obstacle-Avoidance/dp/B07662JJF7
the arduino : Arduino Uno Rev3 — Arduino Official Store
Then the sensor appears to be working correctly!
It prints The obstacle is present even if i put a black object in front of it
Are those objects reflective? Have you tried adjusting the sensitivity potentiometers on the board?
"black" does not mean "invisible".
