Moin Moin
Habe mal wieder ein Problem.
Ich möchte durch einen IR Sensor TCRT 5000 einen LED Stripe ( 60 LED´s) WS 2812 ansteuern.
Ich möchte wie beim letzten Post ( nochmals Danke an alle ), das wenn ein RC->Car den IR-Sensor auslöst, das die LED Stripe´s für 10 Sekunden ausgelöst werden.
Ich habe den Standard Sketch genommen und würde den wenn möglich erweiter.
Weiß aber wieder nicht wie ![]()
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// Released under the GPLv3 license to match the rest of the
// Adafruit NeoPixel library
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN 6 // On Trinket or Gemma, suggest changing this to 1
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 60 // Popular NeoPixel ring size
// When setting up the NeoPixel library, we tell it how many pixels,
// and which pin to use to send signals. Note that for older NeoPixel
// strips you might need to change the third parameter -- see the
// strandtest example for more information on possible values.
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 10 // Time (in milliseconds) to pause between pixels
// These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
// Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
#endif
// END of Trinket-specific code.
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
pixels.clear(); // Set all pixel colors to 'off'
// The first NeoPixel in a strand is #0, second is 1, all the way up
// to the count of pixels minus one.
for(int i=0; i<NUMPIXELS; i++) { // For each pixel...
// pixels.Color() takes RGB values, from 0,0,0 up to 255,255,255
// Here we're using a moderately bright green color:
pixels.setPixelColor(i, pixels.Color(255, 0, 0));
pixels.show(); // Send the updated pixel colors to the hardware.
delay(DELAYVAL); // Pause before next pass through loop
Den IR Sensor habe ich wie folgt angeschlossen.
VCC und GRN ist ja klar.
DO habe ich auf dem Arduino R3 Board an Digital PWM 2 angeschlossen.
Ich hatte folgendes ausprobiert was aber nicht funktioniert hat.
#ifdef __AVR__
#endif
#include <IRremote.h> // Habe ich eingefügt
int IR_PIN = 2; // Pin, an dem der IR-Sensor angeschlossen ist
int LED_PIN = 6; // Pin, an dem der LED-Streifen angeschlossen ist. Das ist wahrscheinlich doppelt ??
IRrecv irrecv(IR_PIN);
decode_results results;
#endif
pinMode(LED_PIN, OUTPUT); // Habe ich eingefügt
irrecv.enableIRIn(); // Starten des IR-Empfangs
if (irrecv.decode(&results)) {
if (results.value == 0xFFA25D) { // Hier den Wert für die erkannte Infrarotstrahlung eintragen
digitalWrite(LED_PIN, !digitalRead(LED_PIN)); // LED-Streifen umschalten
irrecv.resume(); // Weiterempfang von IR-Signalen
Bekomme folgende Fehlermeldungen :-(
C:\Users\Frei\Documents\Arduino\IR_Steuerung_LED_Streifen\IR_Steuerung_LED_Streifen.ino:43:1: error: expected unqualified-id before '{' token
C:\Users\Frei\Documents\Arduino\IR_Steuerung_LED_Streifen\IR_Steuerung_LED_Streifen.ino: In function 'void loop()':
C:\Users\Frei\Documents\Arduino\IR_Steuerung_LED_Streifen\IR_Steuerung_LED_Streifen.ino:73:1: error: expected '}' at end of input
exit status 1
Compilation error: expected unqualified-id before '{' token
Wer könnte mir hierbei behilflich sein ??
Danke
