Hi, I am working on a project to where I want to turn on an LED by a IR wand (similar to the ones found at Disney) with the IR receiver. Later on, I want to control the robot that I have with my wand by moving the robot forward, left, right, and backward. I have an Arduino Uno with the IR Receiver . I have tested to get the IR "code" from the receiver, but when I want to get an if-statement, it gives me this error:
C:\Users\uptow\OneDrive\Desktop\IRReceiverLED\IRReceiverLED.ino: In function 'void loop()':
IRReceiverLED:35:29: error: unable to find numeric literal operator 'operator""CF4AC3'
if(results.value == 41CF4AC3){
Multiple libraries were found for "IRremote.h"
Used: C:\Users\uptow\OneDrive\Documents\Arduino\libraries\IRremote-2.2.3
Not used: C:\Users\uptow\OneDrive\Documents\Arduino\libraries\Arduino-IRremote-master
exit status 1
It's as if the code doesn't like that hex code, for some reason. Anyways, here is the code:
IR Receiver Demonstration 3
IR-Rcv-Demo3.ino
Control LED's using Unused IR Remote keys
DroneBot Workshop 2017
http://dronebotworkshop.com
// Include IR Remote Library by Ken Shirriff
#include <IRremote.h>
// Define sensor pin
const int RECV_PIN = 12;
// Define LED pin constants
const int redPin = 2;
// Define IR Receiver and Results Objects
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
// Enable the IR Receiver
irrecv.enableIRIn();
// Set LED pins as Outputs
pinMode(redPin, OUTPUT);
void loop(){
if (irrecv.decode(&results)){
// Turn on LED for 2 Seconds
digitalWrite(redPin, HIGH);
delay(2000);
digitalWrite(redPin, LOW);
irrecv.resume();
