Hi everyone! I have been relentlessly trying to get this code to work. I probably have 35 hours invested and still have not been able to produce the desired results. If anybody can offer advice, or even criticisms I would greatly appreciate it!
I am wanting to control a stepper motor using an IR remote. I have figured out how to rotate the motor CW and CCW, but have not been able to figure out how to control the speed or rotation while it's in a loop. The way it is now, it will change speed and rotation only after the loop is complete. I want to be able to have control over those adjustments while it's in the loop.
Ultimately I'd like to have it in a "while" loop so that it continues to run until I press the "Mode" button or "Power" button. The names of the functions are named after the icons on the remote I'm using (just a random remote I had laying around).
Also, I'm new to C++ language so any criticisms are greatly appreciated. Thanks in advance!
#include <IRremote.hpp>
#include "BasicStepperDriver.h"
// STEPPER MOTOR
const int STEP_PIN = 3; // How many steps to make
const int DIR_PIN = 4; // CW or CCW
const int SLEEP = 5; // Enable & Disable
const int TONE_PIN = 6; // Buzzer
const int MOTOR_STEPS = 200;
const int RPM = 100;
const int LIM_SWITCH = 9;
int SPEED_ADJUST = 0;
float STROKE_ADJUST = 1.0;
int MODE = 1;
const int MICROSTEPS = 1;
bool POWER_STATE = false; // Has power button been pressed?
const int NOTE_1 = 262; // Buzzer note
const int IR_RECEIVE_PIN = 2; // Receive IR signals
// Delay
const int POWER_DELAY = 1000; // Has the power button been pressed already
unsigned long PREV_MILLIS = 0; // Hold previous millis value
unsigned long PREV_MILLIS_2 = 0; // Hold previous millis value
const unsigned long DELAY_1 = 1000; // Delay for 1 second
const unsigned long DELAY_2 = 2000; // Delay for 2 seconds
const unsigned long DELAY_3 = 3000; // Delay for 3 seconds
const unsigned long LED_DELAY = 6000; // Turn on LED for 6 seconds
BasicStepperDriver stepper(MOTOR_STEPS, DIR_PIN, STEP_PIN, SLEEP);
stepper.begin(RPM, MICROSTEPS);
stepper.setEnableActiveState(LOW);
pinMode(STEP_PIN, OUTPUT);
pinMode(DIR_PIN, OUTPUT);
pinMode(SLEEP, OUTPUT);
pinMode(TONE_PIN, OUTPUT);
pinMode(LIM_SWITCH, INPUT_PULLUP);
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
if (IrReceiver.decode()) {
SwitchCase();
LimitSwitch();
void SwitchCase() {
switch (IrReceiver.decodedIRData.command) {
case 0xC:
Power();
case 0x8:
HL();
case 0x7:
TwoArrows();
case 0x6:
Clock();
case 0x1C:
VolumeUp();
case 0x15:
VolumeDown();
IrReceiver.resume(); // Enable receiving of the next value
void Power() {
if (millis() - PREV_MILLIS >= POWER_DELAY) {
if (POWER_STATE == 1) {
POWER_STATE = 0;
Serial.println("Off");
else {
POWER_STATE = 1;
Serial.println("On");
PREV_MILLIS = millis();
void HL() {
ChangeMode();
void TwoArrows() {
SPEED_ADJUST += 5;
if ( SPEED_ADJUST >= 200 ) {
SPEED_ADJUST = 200;
IrReceiver.stop();
tone(TONE_PIN, NOTE_1, 100);
delay(100);
IrReceiver.start(100000);
Serial.print("SPEED_ADJUST = ");
Serial.println(SPEED_ADJUST);
void Clock() {
SPEED_ADJUST -= 5;
if ( SPEED_ADJUST <= 0 ) {
SPEED_ADJUST = 0;
IrReceiver.stop();
delay(100);
void VolumeUp() {
STROKE_ADJUST += 0.05;
if ( STROKE_ADJUST >= 2.0 ) {
STROKE_ADJUST = 2.0;
IrReceiver.stop();
delay(100);
Serial.print("STROKE_ADJUST = ");
Serial.println(STROKE_ADJUST);
void VolumeDown() {
STROKE_ADJUST -= .05;
if ( STROKE_ADJUST <= 0.05 ) {
STROKE_ADJUST = .05;
IrReceiver.stop();
delay(100);
void ChangeMode() {
if (MODE == 1) {
for (int i = 0; i < 5; i ++) {
PREV_MILLIS_2 = millis() + DELAY_1;
while (millis() < PREV_MILLIS_2) {
stepper.disable();
if (IrReceiver.decodedIRData.command == 0x8) {
Serial.print("Change Mode ");
if (IrReceiver.decodedIRData.command == 0x7) {
Serial.println("Speed Adjust UP");
SPEED_ADJUST += 5;
SPEED_ADJUST = 200;
if (IrReceiver.decodedIRData.command == 0x6) {
Serial.println("Speed Adjust DOWN");
SPEED_ADJUST -= 5;
SPEED_ADJUST = 0;
// CW Rotation //
stepper.enable();
stepper.setRPM(SPEED_ADJUST);
Serial.print("SPEED ADJUST = ");
stepper.rotate(150 + STROKE_ADJUST);
// CCW Rotation //
stepper.disable();
stepper.enable();
stepper.rotate(140 + STROKE_ADJUST);
stepper.disable();
if (MODE == 2) {
Serial.println("");
Serial.print("MODE = ");
Serial.println(MODE);
stepper.disable();
// CCW Rotation
stepper.enable();
stepper.rotate(-125 * STROKE_ADJUST);
// CW Rotation
stepper.disable();
stepper.enable();
stepper.rotate(100 * STROKE_ADJUST);
// CW Rotation
stepper.disable();
stepper.enable();
stepper.rotate(140 * STROKE_ADJUST);
stepper.disable();
if (MODE == 2) {
MODE = 0;
MODE ++;
void LimitSwitch() {
if (digitalRead(LIM_SWITCH) == LOW) {
digitalWrite(SLEEP, HIGH);
Serial.println("*** LIMIT SWITCH ACTIVATED ***");
for (int i = 0; i < 10; i ++) {
IrReceiver.stop();
tone(TONE_PIN, NOTE_1, 1000);
delay(30000);
