Is it ok to send 5v to the reset pin?
Hi.
Im making a hexapod project controlled by IR remote, I use the remote to turn it on and off
but i cant turn it off (just stop it in place)
I've been trying everything but with no success.
Yesterday I've got an idea
the idea is to connect pin 2 to the reset pin
and then when the IR sensor get anything it will trigger the interrupt function and will send 5v to the reset pin,
or I need to bring low voltage to the reset pin?
Sorry for my bad English, i hope you get the idea :slight_smile:
/******* Preprocessor Directives *******/
#include <Servo.h>  //Include servo library
#include <IRremote.h>  //Include IR library
#define trigPin 13 //Define pin 13 as trig pin
#define echoPin 12 //Define pin 12 as echo pin
#define led 7  //Define pin 7 as red led+buzzer pin
#define led2 8 // Define pin 8 as green pin
/******* Global Variables Declarations *******/
Servo Middleservo; //Define first servo
Servo Rightservo; //Define second servo
Servo Leftservo; //Define third servo
int IR_Recv = 3; //IR Receiver Pin 3
int shutdown = 0;
IRrecv irrecv(IR_Recv); //Create the receiver object
decode_results results; //Decode the results from the sensor
/******* Initializing the setup of the main function *******/
*	Function name: setup
*	Purpose:
*			- Setup of the serial input.
*			- Trigger the pins to be ready for input / output.
*			- Setup of the 3 main servo engines.
*			- Setup of the IR sensor.
*	Return value: None.
*	Important notes: None.
  Serial.begin (9600); //Start the serial communication at 9600 bits per second
  pinMode(trigPin, OUTPUT); // make the trigger's pin an output:
  pinMode(echoPin, INPUT); // make the echo's pin an input:
  pinMode(led, OUTPUT); // make the red led+buzzer pin an output:
  pinMode(led2, OUTPUT); // make the green led pin an output:
  Middleservo.attach(9); //Attach the Middleservo variable to pin 9
  Rightservo.attach(10); //Attach the Rightservo variable to pin 10
  Leftservo.attach(11); //Attach the Leftservo variable to pin 11
  irrecv.enableIRIn(); // Starts the receiver
  irrecv.blink13(true); //Enable blinking the LED when during reception
*	Function name: loop
*	Purpose:
*			The main function of the project.
*			The whole proccess of operating the robot.
*			The function waits for the signal from the IR remote, when the IR signal is recieved the function calculates the distance between the actual robot to an obstacle,
*			By the distance the function sets the way of the behavior of the robot(Go straight, Turn around and ETC.. ).
  if (irrecv.decode(&results)) //Attempt to receive a IR code
    if(results.value == 16753245)
      //Set the variables as 0
      long duration = 0, distance = 0;
      // Start Ranging
      digitalWrite(trigPin, LOW);
      delayMicroseconds(2);
      digitalWrite(trigPin, HIGH);
      delayMicroseconds(10);
      // Compute distance
      duration = pulseIn(echoPin, HIGH);
      distance = (duration/2) / 29.1;
      if(distance <= 20) //If the distance is lower or equal to 20 CM do below
        digitalWrite(led,HIGH); // sets the red led+buzzer on
        digitalWrite(led2,LOW); // sets the green led off
        Middleservo.write(75); // set Middleservo to 75 degrees
        delay(200); // waits for a 200 milliseconds
        Leftservo.write(110); // set Leftservo to 110 degrees
        delay(50); // waits for a 50 milliseconds
        Rightservo.write(80); // set Rightservo to 80 degrees
        Middleservo.write(95); // set Middleservo to 95 degrees
        Rightservo.write(105); // set Rightservo to 105 degrees
        Leftservo.write(80); // set Leftservo to 80 degrees
      else //If the distance isnt lower or equal to 20 CM do below:
        digitalWrite(led,LOW); // sets the red led+buzzer off
        digitalWrite(led2,HIGH); // sets the green led on
        Middleservo.write(65); // set Middleservo to 65 degrees
        Middleservo.write(105); // set Middleservo to 105 degrees
        Rightservo.write(110);  // set Rightservo to 110 degrees
      if (distance >= 200 || distance <= 0)
      { //If the distance is bigger or equal to 200 and lower and equal to 0
        Serial.println("Out of range"); // print "Out of range"
      {  //If the distance is NOT bigger or equal to 200 and lower and equal to 0
        Serial.print(distance); //print distance
        Serial.println(" cm"); //print cm below the distance
    else //if the result isnt 16753245 do below
      irrecv.resume(); //reset the receiver and prepare it to receive another code
Easy way to find your answer is to look at the datasheet for the uC that you're using. However, reset should be pulled-down to GND for a reset to happen.
First did you know the reset pin should be high in order the micro controller to run.
So to do a reset to him it must be pulled down for some time(consult the data sheet about that minimum time)
About your idea i suggest you don’t do that!!
I don understand why you need to reset the micro controller when you receive something???
Shouldn’t instead you process that data?
Using a pin to trigger a reset on him self won't prevent the minimum time to reset happen in a "save" way
You have not tried everything or you would have succeeded. Presumably you have managed to send other commands and it is just the 'stop moving' command that you are having trouble with. Your question seems to indicate, however, that you want the bot to stop
so maybe not.
Post your code and you will get more helpful answers
Ok so here is my code:
int shutdown = 0;
*	Purpose:
*	Purpose:
      // Start Ranging
      // Compute distance
My problem is when the IR sensor recieves a signal it set's it into the results.value.
Then if i want to use another value I have to reset the previous with this command "irrecv.resume() "
now, I need it to stay in the working loop for unlimited time and scan for new value at the same time.
The second problem I have is when I tried to stop it, it stopped just for few seconds and then keep working again.
Anyone have a good idea for me? :slight_smile:
Something like this
    else if (results.value == the command that you want to stop the bot)
       //commands to stop the bot go here
I added those codes lines to he code but its still doesn't respond the next values.
After i give him the first value its set itself as result.value and going into infinite loop
I need to reset the value but somehow to continue the working loop until its gets another value.
What value are you sending to stop the bot ?
Please post your revised code
int shutdown = 0;
 *	Purpose:
 *	Purpose:
      // Start Ranging
      // Compute distance
    else if (results.value == 16736925)
turning on value = 16753245
turning off value = 16736925
should be
I don't know which command I can use to stop the bot.
i used the resume command to get back to the starting point and wait for turning on value.
that's why I thought to use the reset pin
What sort of servos are you using ?
Are they conventional servos that move to a position and stop or do they rotate continuously ?
OK, they are the correct type
Can you describe exactly what happens when you power up the bot ?
Do the servos move before you use the IR remote ?
What happens when you send the command to start ?
Do the servos move once or continue to move ?
Insert some Serial.prints in your code like this
    Serial.print("results.value : [");
    Serial.print(results.value);
    Serial.println("]");
What do you get printed when you press the 'start' key on the IR remote and when you don't ?
What do you get printed when you press the 'stop' key ?
When i turn on the bot the servos stays on 90 degrees and resist any movement by touching them.
They are stay at 90 degrees before i use the remote.
When i sending the command to start to start the bot they start to work, in the same order as I wrote.
They move until I disconnect the power. because it have the same result.value every time.
I added the code you gave me and here's the results:
after I turn it on (pressed just once at the start) :
results.value : [16753245]
38 cm
140 cm
24 cm
24 cm
59 cm
28 cm
174 cm
105 cm
83 cm
118 cm
93 cm
113 cm
112 cm
96 cm
109 cm
104 cm
84 cm
what i got when i pressed on the stop bottom:
results.value : [16736925]
Then i pressed on the work bottom:
Out of range
28 cm
27 cm
27 cm
27 cm
27 cm
27 cm
27 cm
26 cm
27 cm
I tried to press on the off bottom while it working, but it didn't show it on the serial.
It just keep to use the working value.
Looks like the problem is that once you have started the bot the value of the command is being remembered and acted upon.
Try this
      irrecv.resume(); // <<<<<<<<< new line added
This should reset the receiver.
Here's the problem
with this code line i have to keep pressing on the bottom to keep it work
I need to press once to make it work
and once on the other bottom to stop it
What's happens?
Every loop???? it resets the value and i have to set it again.
I need it to stay in the working loop for infinite time but in the same time to check for new values
Without the reset command it will never read another command.
A suggestion. Read the IR input every time through loop() When you receive a command set a variable to indicate the state of the program then issue the IR reset command. Keep the program doing what you want by checking the variable unless/until another command is read but do not block loop() from executing.
