Hi guys .
I have to read a rotary encoder , not so fast.
Using only digitalread comparation to read and compare the pins , I miss some "ticks" when arduino is updating a display.
My question is , is it possible read the rotary encoder via interruption or any other way , while the arduino updates an I2C display ?
Does the interruptions pins works while arduino updates the display?
Thank you
The Encoder library may be of use to you.
Interrupts will be serviced when they occur, even during a display update. That is why they are called interrupts.
Thank you ground fungus !!
You can also use the I2C Encoder !
Thanks fatoresaimon.
Good choice too!
Found this , GitHub - brianlow/Rotary: Rotary encoder library for Arduino
Working like a breeze!
