To manage a set of array of buttons/LEDs states in a for loop, I need to read multiple button states to toggle multiple corresponding LEDs inside the ISR.
The ISR works pefectly on a single button/LED set, but the code below is an array of buttons/LEDs set and it behaves unexpectedly mixing up the **i**ndex vaulues.
const int MAX = 2;
const int buttonPins[MAX] = {2, 3}; // the number of the pushbutton pin
const int ledPins[MAX] = {13, 12}; // the number of the LED pin
// variables will change:
volatile int buttonStates[MAX] = {0, 0}, ledStates[MAX] = {0, 0}; // variable for reading the pushbutton status
// initialize the LEDs pins as outputs:
for (int i = 0; i < MAX; i++)
pinMode(ledPins[i], OUTPUT);
digitalWrite(ledPins[i], ledStates[i]);
// initialize the pushbuttons pins as inputs:
pinMode(buttonPins[i], INPUT);
// Attach an interrupt to the ISR vector
attachInterrupt(0, pins_ISR, CHANGE);
// Nothing here!
void pins_ISR() {
buttonStates[i] = digitalRead(buttonPins[i]);
ledStates[i] = digitalRead(ledPins[i]);
if (buttonStates[i] == LOW && ledStates[i] == 1) {
digitalWrite(ledPins[i], LOW);
if (buttonStates[i] == LOW && ledStates[i] == 0) {
digitalWrite(ledPins[i], HIGH);
No, you don't. Use of interrupts very often causes more problems than it solves, and yours is a good example.
None of what you are doing in the ISR should be there. Just set a flag indicating that the button was pushed, and do all that work outside of the interrupt. Then you can forget the "volatile" declarations, etc. and your life will become simpler.
And best of all, you don't need to worry about multibyte variables being corrupted by an interrupt, which, courtesy of switch bounce, could cause of the erratic behavior you observe.
I didn't unravel what it is you're trying to do, but I'll wager it doesn't need an interrupt in the first place and that polling the inputs will do the trick.
This says xy-problem to me, where you might be asking for help on an inappropriate solution rather than stating the underlying need.
How have you wired the buttons? This is for pin 2 only:
attachInterrupt(0, pins_ISR, CHANGE) ;
For pin 3, it is:
attachInterrupt(1, pins_ISR, CHANGE) ;
Or look at digitalPinToInterrupt(). For multiple buttons, pin change interrupts can be use instead of external interrupts, then you are not restricted to pins 2 and 3. However, as has been said, polling buttons is usually a better solution than using interrupts.
blomcrestlight:
:o To manage a set of array of buttons/LEDs states in a for loop, I need to read multiple button states to toggle multiple corresponding LEDs
This thing has already been done by using the button polling & state change method. I Just thought if the ISR was possible, and now know that it is not!
6v6gt:
For pin 3, it is:
Good catch & points.
Done this already and all good. Just thought to try and prove of the concept so I put an example to have the experts feedback.
Trying it again to feedback later. Hope it solves and proves possible!
Hope this makes sense to anyone, as with above added, it maps each single button to toggle both LEDs at the same time, but after pressing the buttons a second time, it reads the proper button/LED mapping and toggles the correct LED per the button pressed!
So, I'm somewhat positive that the concept could work, otherwise it still should'nt work after both buttons were pressed and LEDs toggles once either! Right?
What bit of hardware do you have sitting on that ISR? If its something that just5 sends a periodic signal to "wake up" the button reader, the loop() function does exactly that job.
PaulMurrayCbr:
This is basically an example to test the if possible of using ISR for many buttons controlling many corresponding LEDs, instead of the usual polling/debouncing approach.
Just so anyone could spare few seconds to test and feedback with code fixes/examples. Simple as that.
To do it successfully, you will need to learn more about how to program with interrupts. Fortunately, there is much in the way of tutorials and reference material on line, as well as examples in this forum, so do your reading.
There are circumstances where it is correct, even necessary to trigger an interrupt on a key press, for example if the Arduino is sleeping and the key press also has to force it to wake.
Here is an example based on bits from a working sketch I've put together to read a keyboard matrix. It uses pin change interrupts so you are not restricted to pins 2 and 3. The difference with external interrupts is that, having triggered the interrupt, you must then discover which pin triggered it. You may find something useful in it:
const uint8_t keypadRowPins[ 3 ] = { A2, A1, A0 } ;
bool keyPressIsrTrigger = false ;
void pciSetup(byte pin)
// https://playground.arduino.cc/Main/PinChangeInterrupt/
*digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin)); // enable pin
PCIFR |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
PCICR |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
ISR( PCINT1_vect ) {
// pin change interrupts Port C ( A0 .. A3 )
keyPressIsrTrigger = true ;
for ( uint8_t i = 0; i < ROWS ; i++ ) {
pciSetup( keypadRowPins[ i ] ) ;
if ( keyPressIsrTrigger ) {
// scan all rows
for ( uint8_t i = 0 ; i < ROWS; i++ ) {
pinMode( keypadRowPins[ i ] , INPUT_PULLUP ) ;
if ( digitalRead( keypadRowPins[ i ] ) == LOW ) {
rowFound = i ;
break ;
6v6gt:
Yes. One such scenario would be a washing machine with multiple programs (Half Wash/Full Wash/Tumble Dry/Quick Rinse/...) that the program could be changed using interrupts while another program is running or need a pause/emergency stop or a timer increase/decrease.
6v6gt:
I coded a simple test using your example with debug outputs but it does not fire the interrups on key presses.
Is it the code missing something, or maybe the buttons wiring?
Each buttons' one end separately to the pins A0,A1,A3 and all ends to ground.
const byte ROWS = 3; //Three rows
const uint8_t keypadRowPins[ ROWS ] = { A2, A1, A0 } ;
uint8_t rowFound;
Serial.println("started");
Serial.print("keyPressIsrTrigger: ");Serial.println(keyPressIsrTrigger);
// scan all rows
rowFound = i ;
Serial.print("keypadRowPins[");Serial.println(keypadRowPins[ rowFound ]);Serial.print("]");
break ;
Quote from: 6v6gt on Today at 11:15 am
I don't see why that would be a correct or even necessary circumstance. That could all be done without interrupts with non-blocking code.
evanmars:
By non-blocking your hinting at the use of millis?
Any possibility for a simple code example running a 15 seconds countdown interruptible with multiple buttons to convey your method please?
