Is Nicla Sense ME capable of running ML models? If yes, which library to be used?
I have a Nicla Sense ME and I would like to run ML model on it.
When I try to run Arduino_TensorFlowLite library example, which requires manual installing, I get "Your board not supported" warning. So, I assume my only option is to use official TensorFlow Lite Micro repo.
Even though Nicla Sense ME is not listed on supported microcontrollers list, It should be fine as it has ARM CPU?
I appreciate any feedback/guidance.
I don't know anything about your board. Seeing that it hasn't had any replies for a week, I've moved it to the dedicated Nicla Sense ME section of the forum in the hope that it gets the attention of the more experienced Nicla users.
Thanks @sterretje,
I have made a bit progress. I can import the libs without errors now.
Here is the full code on Nicla:
#include <Arduino.h>
#include <Nicla_System.h>
#include "tensorflow/lite/core/c/common.h"
#include "tensorflow/lite/micro/examples/hello_world/models/model.h"
#include "tensorflow/lite/micro/micro_interpreter.h"
#include "tensorflow/lite/micro/micro_log.h"
#include "tensorflow/lite/micro/micro_mutable_op_resolver.h"
#include "tensorflow/lite/micro/micro_profiler.h"
#include "tensorflow/lite/micro/recording_micro_interpreter.h"
#include "tensorflow/lite/micro/system_setup.h"
#include "tensorflow/lite/schema/schema_generated.h"
namespace {
// new alias.
using HelloWorldOpResolver = tflite::MicroMutableOpResolver<1>;
TfLiteStatus RegisterOps(HelloWorldOpResolver& op_resolver) {
  TF_LITE_ENSURE_STATUS(op_resolver.AddFullyConnected());
  return kTfLiteOk;
}  // namespace
TfLiteStatus ProfileMemoryAndLatency() {
  tflite::MicroProfiler profiler;
  HelloWorldOpResolver op_resolver;
  TF_LITE_ENSURE_STATUS(RegisterOps(op_resolver));
  // Arena size just a round number. The exact arena usage can be determined
  // using the RecordingMicroInterpreter.
  constexpr int kTensorArenaSize = 3000;
  uint8_t tensor_arena[kTensorArenaSize];
  constexpr int kNumResourceVariables = 24;
  tflite::RecordingMicroAllocator* allocator(
      tflite::RecordingMicroAllocator::Create(tensor_arena, kTensorArenaSize));
  tflite::RecordingMicroInterpreter interpreter(
      tflite::GetModel(g_model), op_resolver, allocator,
      tflite::MicroResourceVariables::Create(allocator, kNumResourceVariables),
      &profiler);
  TF_LITE_ENSURE_STATUS(interpreter.AllocateTensors());
  TFLITE_CHECK_EQ(interpreter.inputs_size(), 1);
  interpreter.input(0)->data.f[0] = 1.f;
  TF_LITE_ENSURE_STATUS(interpreter.Invoke());
  //MicroPrintf("");  // Print an empty new line
  profiler.LogTicksPerTagCsv();
  interpreter.GetMicroAllocator().PrintAllocations();
  return kTfLiteOk;
TfLiteStatus LoadFloatModelAndPerformInference() {
  const tflite::Model* model =
      ::tflite::GetModel(g_model);
  TFLITE_CHECK_EQ(model->version(), TFLITE_SCHEMA_VERSION);
  tflite::MicroInterpreter interpreter(model, op_resolver, tensor_arena,
                                       kTensorArenaSize);
  // Check if the predicted output is within a small range of the
  // expected output
  float epsilon = 0.05f;
  constexpr int kNumTestValues = 4;
  float golden_inputs[kNumTestValues] = {0.f, 1.f, 3.f, 5.f};
  for (int i = 0; i < kNumTestValues; ++i) {
    interpreter.input(0)->data.f[0] = golden_inputs[i];
    float y_pred = interpreter.output(0)->data.f[0];
    TFLITE_CHECK_LE(abs(sin(golden_inputs[i]) - y_pred), epsilon);
  return kTfLiteOk;
TfLiteStatus initializeModelAndPerformInference() {
  tflite::InitializeTarget();
  TF_LITE_ENSURE_STATUS(ProfileMemoryAndLatency());
  TF_LITE_ENSURE_STATUS(LoadFloatModelAndPerformInference());
  //MicroPrintf("~~~ALL TESTS PASSED~~~\n");
  return kTfLiteOk;
  nicla::begin();
  nicla::leds.begin();
  initializeModelAndPerformInference();
  nicla::leds.setColor(blue);
  nicla::leds.setColor(red);
Now, I am getting following errors:
main.cpp:(.text._Z23ProfileMemoryAndLatencyv+0x6e): undefined reference to `tflite::MicroInterpreter::AllocateTensors()'
main.cpp:(.text._Z23ProfileMemoryAndLatencyv+0xbe): undefined reference to `tflite::MicroInterpreter::input(unsigned int)'
main.cpp:(.text._Z23ProfileMemoryAndLatencyv+0xcc): undefined reference to `tflite::MicroInterpreter::Invoke()'
main.cpp:(.text._Z23ProfileMemoryAndLatencyv+0xd8): undefined reference to `tflite::MicroProfiler::LogTicksPerTagCsv()'
main.cpp:(.text._Z23ProfileMemoryAndLatencyv+0xde): undefined reference to `tflite::RecordingMicroAllocator::PrintAllocations() const'
main.cpp:(.text._Z23ProfileMemoryAndLatencyv+0xe4): undefined reference to `tflite::MicroInterpreter::~MicroInterpreter()'
So I believe the linker is unable to find the definitions for various symbols related to the TensorFlow Lite library. I have found the linker script:
MEMORY
  FLASH (rx) : ORIGIN = 0x10000, LENGTH = 0x70000
  RAM_NVIC (rwx) : ORIGIN = 0x20000000, LENGTH = 0xE0
  RAM (rwx) : ORIGIN = (0x20000000 + 0xE0), LENGTH = (0x10000 - 0xE0)
OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
ENTRY(Reset_Handler)
SECTIONS
    .text :
        KEEP(*(.Vectors))
        *(.text*)
        KEEP(*(.init))
        KEEP(*(.fini))
        *crtbegin.o(.ctors)
        *crtbegin?.o(.ctors)
        *(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
        *(SORT(.ctors.*))
        *(.ctors)
        *crtbegin.o(.dtors)
        *crtbegin?.o(.dtors)
        *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
        *(SORT(.dtors.*))
        *(.dtors)
        *(.rodata*)
        KEEP(*(.eh_frame*))
    } > FLASH
    .sdh_soc_observers :
        PROVIDE(__start_sdh_soc_observers = .);
        KEEP(*(SORT(.sdh_soc_observers*)))
        PROVIDE(__stop_sdh_soc_observers = .);
    } > FLASH
    .sdh_stack_observers :
        PROVIDE(__start_sdh_stack_observers = .);
        KEEP(*(SORT(.sdh_stack_observers*)))
        PROVIDE(__stop_sdh_stack_observers = .);
    } > FLASH
    .sdh_req_observers :
        PROVIDE(__start_sdh_req_observers = .);
        KEEP(*(SORT(.sdh_req_observers*)))
        PROVIDE(__stop_sdh_req_observers = .);
    } > FLASH
    .sdh_state_observers :
        PROVIDE(__start_sdh_state_observers = .);
        KEEP(*(SORT(.sdh_state_observers*)))
        PROVIDE(__stop_sdh_state_observers = .);
    } > FLASH
    .sdh_ble_observers :
        PROVIDE(__start_sdh_ble_observers = .);
        KEEP(*(SORT(.sdh_ble_observers*)))
        PROVIDE(__stop_sdh_ble_observers = .);
    } > FLASH
    .ARM.extab :
        *(.ARM.extab* .gnu.linkonce.armextab.*)
        . = ALIGN(8);
    } > FLASH
    __exidx_start = .;
    .ARM.exidx :
        *(.ARM.exidx* .gnu.linkonce.armexidx.*)
        . = ALIGN(8);
    } > FLASH
    __exidx_end = .;
    __etext = .;
    .data : AT (__etext)
        __data_start__ = .;
        *(vtable)
        *(.data*)
        . = ALIGN(8);
        PROVIDE_HIDDEN (__preinit_array_start = .);
        KEEP(*(.preinit_array))
        PROVIDE_HIDDEN (__preinit_array_end = .);
        . = ALIGN(8);
        PROVIDE_HIDDEN (__init_array_start = .);
        KEEP(*(SORT(.init_array.*)))
        KEEP(*(.init_array))
        PROVIDE_HIDDEN (__init_array_end = .);
        . = ALIGN(8);
        PROVIDE_HIDDEN (__fini_array_start = .);
        KEEP(*(SORT(.fini_array.*)))
        KEEP(*(.fini_array))
        PROVIDE_HIDDEN (__fini_array_end = .);
        . = ALIGN(8);
        PROVIDE(__start_fs_data = .);
        KEEP(*(.fs_data))
        PROVIDE(__stop_fs_data = .);
        *(.jcr)
        . = ALIGN(8);
        __data_end__ = .;
    } > RAM
    __edata = .;
    .nvictable (NOLOAD) :
      PROVIDE(__start_nvictable = .);
      KEEP(*(.nvictable))
      PROVIDE(__stop_nvictable = .);
    } > RAM_NVIC
    .noinit (NOLOAD) :
      PROVIDE(__start_noinit = .);
      KEEP(*(.noinit))
      PROVIDE(__stop_noinit = .);
    } > RAM
    .bss :
        . = ALIGN(8);
        __bss_start__ = .;
        *(.bss*)
        *(COMMON)
        . = ALIGN(8);
        __bss_end__ = .;
    } > RAM
    .heap (NOLOAD):
        __end__ = .;
        end = __end__;
        *(.heap*);
        ASSERT(. <= (ORIGIN(RAM) + LENGTH(RAM) - 0x400), "heap region overflowed into stack");
        . = ORIGIN(RAM) + LENGTH(RAM) - 0x400;
        __HeapLimit = .;
    } > RAM
    PROVIDE(__heap_start = ADDR(.heap));
    PROVIDE(__heap_size = SIZEOF(.heap));
    PROVIDE(__mbed_sbrk_start = ADDR(.heap));
    PROVIDE(__mbed_krbs_start = ADDR(.heap) + SIZEOF(.heap));
    .stack (NOLOAD):
        __StackLimit = .;
        *(.stack*)
        . = ORIGIN(RAM) + LENGTH(RAM);
    } > RAM
    __StackTop = ORIGIN(RAM) + LENGTH(RAM);
    __StackLimit = __StackTop - 0x400;
    PROVIDE(__stack = __StackTop);
Now trying to figure out what is going on there. I think it makes sense to change the title to for example "undefined reference to tflite::MicroInterpreter::AllocateTensors()", since I believe, we can def. run ML on Nicla.
This is very interesting. I have an issue on the Tensorflow github that this could relate to
