Is SG90 a Servo Motor or a Stepper Motor?
This is an example of a close loop servo system -- DC Motor equipped with encoder wheel to receive feedback about speed.
I looks pretty good.
I have some minor comments, depending on how exact you want to be, and how much you want to describe this particular servo vs servos in general...
  1. Your picture of the servo signal is "not to scale", which is getting to be a particular annoyance of mine, since it makes it more difficult for people to understand how a microcontroller can operate multiple servos. The maximum length of the signal pulse maxes out at about 1/10th of the total period, whereas your picture shows about 1/5th. See servo-radio | Now that the servos pulses happen one at a tim… | Flickr
  2. It might be useful to separate the "servo contrller/amp" from the "motor driver."
  3. The "Feedback device" need not be a potentiometer; optical encoders and hall effect sensors are pretty common (both of which are contact-free, and thus last better.)
  4. I'm not sure that the control signal is always converted to a voltages, vs converting the feedback signal to a pulse; I'm pretty sure I've seen the latter.
Thank you very much for the good words and the constructive criticisms. In fact, I have been keeping the text description pending in respect of receiving comments on the pictures/images presented in post #40.
I have searched Net and have looked for diagrams which bear (at least at conceptual level) mecanical components (Fig-1(a)) and electronics controller (Fig-1(b) that correspond to actual SG90 Servo System (Fig-(d) to (f)) and Fig-2.
Figure-1:
Figure-2:
I have edited the source diagrams to bring them close to the spirit of SG90 as much as possible. The components/signals of Fig-1(a) and (b) are labelled to allowo readers to make one-to-one correspondance with Fig-1(e).
Fig-1(d) and (e) are due to my efforts of carefully dismantling the SG90 and then putting them back in full working condition.
1. I have worked on single SG90 Servo System. I have now edited the rough scales of the pulse width of PWM signal so that the two signals of Fig-1(b) and Fig-1(c) agree.
2. Motor Driver block is added in Fig-1(b). Now, it agrees with the Q1 and Q2 Motor Driver transistors of Fig-2.
3 As I am referring to SG90 which uses potentiometer as a feedback network, I have chosen a diagram from Net that contains potentionmeter in the feedback path. Of course, other devices like encoder wheel (post #42) etc. are the viable options.
4. This is a very interesting and informative point you have raised. It is much more accurate to process/compare two digital level PWM signals (reference command PWM and KC8801 generated PWM based DC volt of potentionmeter) compare to handling analog signals. Accordingly, I have added a PWM block inside Fig-1(b) which KC8801 must have cotained though I don't have the details of the inside world of KC8801 Controller/Driver.
Moreover, the PWM concept agrees with the L298N Motor Driver that asserts the PWM signal coming from UNO directly on the power driver circuit; the necessary filtering is done by the Motor Coil and other stray capacitances.
I have also added a signal conditioning block inside Fig-1(b) to remove any noise or jitter present on input PWM signal.
I will do some more measurements to record the wiper voltage of potentiometer at diffrent angular positions of the shaft/horn and then see how it goes with input position command PWM.
I have practically observed that the motor terminals are not disconnected (power cut off) from the motor driver. Instead, the terminals remain connected with an almost 0% duty cycle of the resultant PWM when the shaft arrives at the desired position; as a result, the Motor is at completely standstill condition. This is evident from the fact that any external disturbance imposed on the horn (such as a slight touch to change the position manually) causes the motor to jitter, turning back and forth to retrieve the original set point.
