Is their an app or an api i can send it too?
Grumpy_Mike:
http://makezine.com/2015/07/06/control-arduino-your-smartphone-via-blynk/
orhttps://diyhacking.com/diy-android-home-automation/
or
https://www.youtube.com/watch?v=lPai9qMoauM
It must be a bugger when Google is broken for you.
I cant see any of them working for me. I already have a base shield installed to connect grove connectors. And it must be compatible with apple devices.
What should I do? an api server for cpu and iphone would be best
Send the data via bluetooth, no change of code required, use a bluetooth terminal on iphone.
how would i do that?
cowloversecret:
Nice of you to tell us the full information before you waste our time.
cowloversecret:
Ring your ISP and get them to fix access to google.
Grumpy_Mike:
google is working i just couldnt find one that could work for me
cowloversecret:
Now you have Google working you will surely find plenty of information on that.
Essentially it is just a case of connect and go. But note that, since you are stuck with Apple compatibility, you will need to use a Bluetooth 4 (BLE) module, and ignore all reference to HC-05 and HC-06.
cowloversecret:
Try a Google on;
'bluetooth terminal on iphone'
The first search result will likely point to Blueterm.
Why is Blueterm not suitable, it would appear to do exactly what you require ?
