Is there a timer interrupt library that can be used as a nano 33 board?
I'd like to blink one LED using a timer interrupt. I tried using several timer interrupt libraries, such as mstimer2, but I get compilation errors.
Maybe this is because the nano33ble board uses nrf52840 unlike the usual Arduino.
Then, is there a timer library for the nano33ble board?
I'd appreciate it if you could let me know.
Thank you in advance. :slight_smile:
I cannot help with your query, but are you sure that you need to use a timer interrupt ? What sort of blinking period and accuracy do you need and what else is the sketch doing ?
Not maybe, it is the reason.
Hello. Thank you for your answer.
There are two main functions that I want to use. (Use an IMU sensor and three LED)
  1. LED1 or LED2 operates the Blink according to IMU sensor values.
    (The left and right LED operate like a direction light depending on the slope value of the IMU.)
  2. LED3 continues to Blink regardless of previous function This function can be turned on/off through the app.
    (App control via BLE communication)
I was thinking of using timer interrupt in function number 2, but can it be simply implemented as a millis() function?
Yes
See Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
Thank you for your help!
