Is there a way to convert a string or char to int
I have tried everything I can think of but cannot get the compiler to accept converting char to int. I tried first reading byte buffer but couldn't find a way to convert that. So, I tried read a single character in at a time and adding it to a string because then I thought I could iterate the string and pull the data that I need. The clock that I am using accepts int for each position of hour and minute (num1,num2,num3,num4). So I am sending a request to a server which replys with "04,51,40" + crlf. I need to take the 0 and put in num1, 4 in num2, 5 in num3, 1 in num4. Any help would be appreciated.
void GetTimeReply ()
  delay(2000);
  String sTemp;
  byte buffer[80];
  int len = client.available();
  if (len > 0)
    char c = client.read();
    sTemp += c;
    while (client.available() > 0)
      sTemp += c;
    Serial.print("(");
    Serial.print(sTemp);
    Serial.print(")");
    Serial.println(sTemp.length());
  char c1 = sTemp.substring(1);
  num1 = int(c1);
//  num1 = int(sTemp.substring(1));
//  Serial.print(num1);
//  num2 = int(sTemp.substring(2));
//  Serial.print(num2);
//  num3 = int(sTemp.substring(4));
//  Serial.print(num3);
//  num4 = int(sTemp.substring(5));
//  Serial.print(num4);
  // Set Clock time
  // SetClockDisplayFromServer(num1,num2,num3,num4)
  Serial.println("  GetTimeReply - Exit");
  bGetTimeReplyDone = true;
Not that you should be using "S"trings on an Arduino anyway, but I think you're looking for stoi().
Thanks, I was to optimistic!
I think you're looking for toInt
(Never heard of stoi)
If you are using Strings, then the below type operation should work.
  if (readString.length() >0) {
    Serial.println(readString);
    int n = readString.toInt();
    Serial.println(n);
    myservo.writeMicroseconds(n);
    //myservo.write(n);
    readString="";
So, I guess the first comment about not using string functions must be true.
I have
    //0123456789012345678 <---Chars in string position
    //2020,02,01,09,28,58     <---Return string from server
    // This code below
    String sYear;
    sYear = sTemp.substring(0, 4);
    String sMonth;
    sMonth = sTemp.substring(5, 2);
    String sDay;
    sDay = sTemp.substring(8, 2);
    String sHour;
    sHour = sTemp.substring(11, 2);
    String sMinute;
    sMinute = sTemp.substring(14, 2);
    String sSeconds;
    sSeconds = sTemp.substring(17, 2);
Returns
09:35:44.674 -> -->
09:35:44.674 -> 2020,02,01,09,35,44
09:35:44.674 -> <--Length=21
09:35:44.709 -> Year=2020
09:35:44.709 -> Month=20,
09:35:44.709 -> Day=20,02,
09:35:44.709 -> Hour=20,02,01,
09:35:44.709 -> Minute=20,02,01,09,
09:35:44.709 -> Seconds=20,02,01,09,35,
09:35:45.685 -> GetTimeReply - Exit
Has anyone been able to get the string functions to work? Is there a different library?
XY Problem.
it looks like you have something like a webclient.
What hardware are you using?
What do you want to achieve?
in the end I guess you want something like
strtok and atoi
if you really always get
"04,51,40" + crlf.
and really want to have it in single digits
than even a simple char array buffer will work
num1=buffer[0]-32;
num2=buffer[1]-32;
num3=buffer[3]-32;
etc
could work.
I have an Arduino Mega with ethernet shield connected to 4 digit 7 segment display with rtc module.
I press button on Arduino and it makes a websocket to server sending "Time" request.
Server responds with datetime string in the following format "2020,02,01,09,28,58"+crlf.
I then was trying to parse through the string but was not realizing that the substring function on Arduino does (from, to) as opposed to (from, length).
So, I got everything functioning except simple things I am stumbling over.
Current road block is I want to "Serial.println(rtc.now()" before and after setting time...BUT
Compiler gives me error "no matching function for call to 'DateTime::toString()".
I also tried making DateTime dtNow variable, assigning rtc.now() to it and then trying "Serial.println(dtNow.toString())" but I think the compiler doesn't accept the toString method.
"Has anyone been able to get the string functions to work?"
The String functions usually work for me.
