I'm trying to write an application for ESP32 (16 MB flash, no PSRAM) that needs basically three things:
- read/write from/to an SD card
- decode MP3
- send audio samples over BT A2DP
The minimal code is very simple:
#include <Arduino.h>
#include <FS.h>
#include <SD.h>
#include <SPI.h>
#include <freertos/ringbuf.h>
#include "AudioTools.h"
#include "BluetoothA2DPSource.h"
#include "Audio.h"
#define PIN_SPI_SCK 27
#define PIN_SPI_MISO 26
#define PIN_SPI_MOSI 2
#define PIN_SD_CS 22
#define PIN_I2S_BCLK 17
#define PIN_I2S_LRC 18
#define PIN_I2S_DOUT 19
SET_LOOP_TASK_STACK_SIZE(4096);
Audio audio;
BluetoothA2DPSource a2dp_source;
RingbufHandle_t audioRingBuffer = xRingbufferCreate(2048, RINGBUF_TYPE_BYTEBUF);
void audio_process_i2s(int16_t* outBuff, uint16_t validSamples, uint8_t bitsPerSample, uint8_t channels, bool *continueI2S)
// process samples
*continueI2S = false;
int32_t get_data_channels(Frame *frame, int32_t channel_len)
// process samples
return channel_len;
SPI.setFrequency(1000000);
SPI.begin(PIN_SPI_SCK, PIN_SPI_MISO, PIN_SPI_MOSI, PIN_SD_CS);
if (SD.begin(PIN_SD_CS)) Serial.println("SD card mounted!");
else Serial.println("Failed to mount SD card");
a2dp_source.start("BT speaker", get_data_channels);
File root = SD.open("/");
audio.setPinout(PIN_I2S_BCLK, PIN_I2S_LRC, PIN_I2S_DOUT);
audio.setVolume(2);
audio.connecttoFS(SD, "sample.mp3");
static unsigned long refTime = 0;
if (millis() > refTime + 1000)
Serial.printf("%lu\t%lu\t%lu\t%lu\n", ESP.getHeapSize(), ESP.getFreeHeap(), ESP.getMinFreeHeap(), ESP.getMaxAllocHeap());
refTime = millis();
audio.loop();
at compile time I get:
RAM: [= ] 11.5% (used 59880 bytes from 521984 bytes)
Flash: [====== ] 63.9% (used 2009777 bytes from 3145728 bytes)
and at run-time:
234336 17620 12844 11252
where:
- ESP.getHeapSize(): 234336
- ESP.getFreeHeap(): 17620
- ESP.getMinFreeHeap(): 12844
- ESP.getMaxAllocHeap(): 11252
still the mp3 decoder cannot be created:
info PSRAM not found, inputBufferSize: 13951 bytes
[ 789][V][ssl_client.cpp:321] stop_ssl_socket(): Cleaning SSL connection.
info buffers freed, free Heap: 20300 bytes
info Reading file: "/sample.mp3"
[ 826][E][mp3_decoder.cpp:1602] MP3Decoder_AllocateBuffers(): not enough memory to allocate mp3decoder buffers
info Closing audio file "sample.mp3"
Since I don't need to use WiFi, BLE, SSL, etc... is there a way to disable them in order to free more memory?
I'm aware the PSRAM would probably fix the issue, but we have a lot of these ESP32-WROOMs (w/o PSRAM) and I'm trying to use them is possibile.
