Is this documented...anywhere?
An observation...
This works....
if (x+y == z) { stuff.....
BUT THIS DOES NOT... though one might think so.
if ( x & y == z) { stuff...
AND THIS DOES.... when I finally worked out why things didn't work!
if (( x & y) == z) { stuff...
I couldn't find any reference to this trap anywhere. Or have I missed it?
Is this just a newby trap, or should it be blindingly obvious?
regards in advance ... leolfs
A C++, or even C book, might be handy.
rFree,
I guess this is what you mean.
]"The precedence of the bitwise logical operators has been criticized.[1] Conceptually, & and | are arithmetic operators like + and *.
The expression a & b == 7 is syntactically parsed as a & (b == 7) whereas the expression a + b == 7 is parsed as (a + b) == 7. This requires parentheses to be used more often than they otherwise would."
Thanks for putting me in the picture. I wouldn't have known where to look. I was kind of hoping the Arduino environment didn't allow pitfalls like this.
Still that's what such a good forum is for. Info gained, problem solved.
PS A compendium of odd things for beginners to watch out for would be a good idea.Like "when masking for a bit, don't do it like this because..."
In general: It is hard to have too many brackets!
You can use them to eliminate the possiblity of "order of operations" bugs.
P.S.... but easy to have too few ohs! Apologies for the earlier typo. The post used to say "...hard to have to many brackets"
(a + b) == 7
no problem
