Hi!
C++17 rocks! However, the different Arduino IDE's are still using C++11. I tweaked the compilation instruction so it was able to compile using C++17, and gracefully it compiled, so good for being true
For testing purposes I've compiled this C++17 code:
// (1) Structured binding
// (2) If initializer
struct Res{int x; int y;};
auto foo( int a ) -> Res
return{ a+1, a*2 }; // (1)
Serial.begin( 9600 );
auto [a,b] = foo( 5 ); // (1)
Serial.println( a );
Serial.println( b );
if( auto [x,y] = foo( 3 ); x < 10 ) // (2)
Serial.println( y );
An excerpt from the compilation output (just to show it's actually using C++17 and that it compiled):
home/fjrg76/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++17 ...
Generating function prototypes...
Compiling sketch...
/home/fjrg76/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++17 ...
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/arduino_cache_911616/core/core_arduino_avr_uno_6da0409820faaaedb6b0232ec4092644.a
Linking everything together...
Sketch uses 1736 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
C++ compiler version:
$ ./avr-g++ --version
avr-g++ (GCC) 7.3.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Is there any issue with this compiler for the ATMEGA328 processor (and alike) that has compelled the Arduino's mainteiners not to use it?
Same thing for Cortex ARM cores: even the Due board is still using C++11. Any reason?
Compiler version for ARM Cortex cores:
$ ./arm-none-eabi-g++ --version
arm-none-eabi-g++ (GNU Arm Embedded Toolchain 10.3-2021.10) 10.3.1 20210824 (release)
Copyright (C) 2020 Free Software Foundation, Inc.
It's been 6 years from C++17 and right now people is working in the C++23 release, so I think that C++17 is safe enough to be used in embedded systems.
Greetings!
