ISL29125 RGB Light Sensor
I'm trying to create a code that turns an LED on when certain RGB values are read by the sensor. My starting code is below does anyone know how I can add to it to illuminate the LED when the RGB value is 000.
// Include I2C Library
#include <Wire.h>
// Include Sparkfun ISL29125 Library
#include <SparkFunISL29125.h>
// Declare sensor object
SFE_ISL29125 RGB_sensor;
// Calibration values
unsigned int redlow = 197;
unsigned int redhigh = 8103;
unsigned int greenlow = 158;
unsigned int greenhigh = 10195;
unsigned int bluelow = 162;
unsigned int bluehigh = 8807;
// Declare RGB Values
int redVal = 0;
int greenVal = 0;
int blueVal = 0;
  // Initialize serial communication
  // Initialize the ISL29125 with simple configuration so it starts sampling
  if (RGB_sensor.init())
    Serial.println("Sensor Initialization Successful\n\r");
  // Read sensor values (16 bit integers)
  unsigned int red = RGB_sensor.readRed();
  unsigned int green = RGB_sensor.readGreen();
  unsigned int blue = RGB_sensor.readBlue();
  // Convert to RGB values
  int redV = map(red, redlow, redhigh, 0, 255);
  int greenV = map(green, greenlow, greenhigh, 0, 255);
  int blueV = map(blue, bluelow, bluehigh, 0, 255);
  // Constrain to values of 0-255
  redVal = constrain(redV, 0, 255);
  greenVal = constrain(greenV, 0, 255);
  blueVal = constrain(blueV, 0, 255);
  Serial.print("Red: ");
  Serial.print(redVal);
  Serial.print(" - Green: ");
  Serial.print(greenVal);
  Serial.print(" - Blue: ");
  Serial.println(blueVal);
  // Delay for sensor to stabilize
  delay(2000);
There is no LED in your code, which I assume is ISL29125_basics.ino from the github library examples. So guess you mean how to get that 000 condition reported by the print statement?
I don't have that sensor so can't experiment, but I'm curious how you will test that physical light combination in practice?
