Hello. As the title says, I am having issues generating a random 4 digit number for my 4 digit display. It works via multiplexing. My code works as expected for a single digit 7 segment display, but when I want to take in account multiplexing it just doesn't work. First of all, there is my code:
A
F | | B
| G |
E | | C
| D |
int pinA = 2;
int pinB = 3;
int pinC = 4;
int pinD = 5;
int pinE = 6;
int pinF = 7;
int pinG = 8;
int D1 = 9;
int D2 = 10;
int D3 = 11;
int D4 = 12;
int punt = 13;
int counter = 1;
void numZero(){
digitalWrite(pinA, HIGH);
digitalWrite(pinB, HIGH);
digitalWrite(pinC, HIGH);
digitalWrite(pinD, HIGH);
digitalWrite(pinE, HIGH);
digitalWrite(pinF, HIGH);
digitalWrite(pinG, LOW);
digitalWrite(punt, LOW);
void numOne(){
digitalWrite(pinA, LOW);
digitalWrite(pinD, LOW);
digitalWrite(pinE, LOW);
digitalWrite(pinF, LOW);
void numTwo(){
digitalWrite(pinC, LOW);
digitalWrite(pinG, HIGH);
void numThree(){
void numFour(){
void numFive(){
digitalWrite(pinB, LOW);
void numSix(){
void numSeven(){
void numEight(){
void numNine(){
void digOne(){
digitalWrite(D1, LOW);
digitalWrite(D2, HIGH);
digitalWrite(D3, HIGH);
digitalWrite(D4, HIGH);
void digTwo(){
digitalWrite(D1, HIGH);
digitalWrite(D2, LOW);
void digThree(){
digitalWrite(D3, LOW);
void digFour(){
digitalWrite(D4, LOW);
void numRandom(){
int choose = random(9);
switch (choose){
case 1:
numOne();
case 2:
numTwo();
case 3:
numThree();
case 4:
numFour();
case 5:
numFive();
case 6:
numSix();
case 7:
numSeven();
case 8:
numEight();
case 9:
numNine();
pinMode(pinA, OUTPUT);
pinMode(pinB, OUTPUT);
pinMode(pinC, OUTPUT);
pinMode(pinD, OUTPUT);
pinMode(pinE, OUTPUT);
pinMode(pinF, OUTPUT);
pinMode(pinG, OUTPUT);
pinMode(D1, OUTPUT);
pinMode(D2, OUTPUT);
pinMode(D3, OUTPUT);
pinMode(D4, OUTPUT);
pinMode(punt, OUTPUT);
digOne();
numRandom();
delay(4);
digTwo();
numRandom();
delay(4);
numRandom();
digThree();
delay(4);
numRandom();
digFour();
delay(4);
Brief explanation of why I did what I did + my issue: first of all I did functions for every different number, so "numZero()", "numThree()", etc, just sets the right pins to high and low to form said number. Second, since this is a 4 digit display, I needed to make functions to specify at which slot is this number going to appear. Those are "digOne()", "digTwo()", etc.
Those do work. If you hardcode a number in the main loop like this:
digOne();
numFour();
delay(4);
digTwo();
numSix();
delay(4);
digThree();
numNine();
delay(4);
digFour();
numZero();
delay(4);
it shows the number "3690" as expected. The random number generator is also very simple: it just chooses a random number between 0 and 9 and based on the plain number it got, it does a "num" function to show that specific number on the display.
This works correctly with a single digit display, or if you set all four numbers in this display to act like a single one (changing D1, D2, D3 and D4 pins to low).
The issue comes when I want to generate four random numbers and print them for a second. Since I'm doing this via multiplexing, I can't just put an "sleep(1000)" there because if you did it you would see only one digit on and keeping the loop on is not an option since everytime the loops reset I get a new set of 4 random numbers. I tried a couple things:
- Trying to assign the value of numRandom() to a new variable like randNumberOne at the setup so it would only generate a single number and store it in randNumberOne. I wanted to repeat this 4 times and voila 4 random numbers everytime you reset the board. The issue: I couldn't get a variable to save a piece of code. I kept getting errors saying that a void didn't have any value and that actually makes sense but I don't really know what to do.
- Using a "while" loop that adds or substracts one from the variable "counter" based on its value. Didn't work either because the while loop it's still a loop and it keeps generating a new set of four numbers everytime you run it.
So, what should I try now? I gave up on it after some hours thinking lol.
EDIT: I didn't add an image to show what are pinA-G and D1-4 variables actually pointing at. This is how my display (and I think every display?) works:
