Win 10 IDE 1.6.8 uno
HI
I have a sketch that works. now i am trying to add a prox switch to start the sketch. I copy "Change of state" from the examples in the IDE. Here is my copy of "change of state" with some changes that does work.
[code]
State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time,
but you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button or button changes from off to on
and on to off.
The circuit:
pushbutton attached to pin 2 from +5V
10K resistor attached to pin 2 from ground
LED attached from pin 13 to ground (or use the built-in LED on
most Arduino boards)
created 27 Sep 2005
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
int C = 0;
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int t = 1;
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// went from off to on:
digitalWrite (ledPin, HIGH);
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW then the button
// wend from on to off:
digitalWrite(ledPin, LOW);
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
[/code]
Now I add the "ledcontrol.h). the ledPin will come on. but the print out shows about sixty to seventy hits on the prox. switch. Why.
[code]
#include "LedControl.h"
and on to off.
The circuit:
created 27 Sep 2005
by Tom Igoe
int t = 1;
delay(50);
[/code]
