It says that I can't connect to my Arduino
Is something wrong with my code or I plugged it not tightly enough
#define lightSensor A5
int alarm=1;
int redLed=12;
int greenLed=13;
int j;
  pinMode(redLed,OUTPUT);
  pinMode(greenLed,OUTPUT);
  Serial.print("Starting.");
  delayMicroseconds(10000);
  Serial.print(".");
  Serial.println(".");
  int lightLevel = analogRead(lightSensor);
  Serial.println(lightLevel);
  if (lightLevel>=450){
    Serial.println("IT IS NOT OKAY!!!!!!!!!!");
    digitalWrite(redLed,HIGH);
    digitalWrite(greenLed,LOW);
  for (j=1;j<=100;j=j+1) {
    digitalWrite(alarm,HIGH);
    delay(10);
    digitalWrite(alarm,LOW);
    delay(10);
    delay(10);
    delay(10);
  else{
    digitalWrite(greenLed,HIGH);
    digitalWrite(redLed,LOW);
    Serial.println("It is Okay.");
here you connect something (probably LED) to pin 1. change this wiring to 2 and try again
Serial.println("IT IS NOT OKAY!");
And disconnect the sensor you have connected to pin 1.
Pin0 and Pin1 are the UART pins ands are used for programming the Arduino.
What model Arduino are you using?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
mega 2560
it worked
